Steering Stabilizer and Cushioned Bar Mounts
Discussion in 'Parallel World (790/890)' started by DustBuster, Apr 28, 2020.
  1. jesusgatos
    jesusgatos fishing with dynamite
    Nov 17, 2006
    2,911
    santa cruz mtns, ca
    Yeah, personal experience related in previous posts.
    #61
  2. 1coolbanana
    1coolbanana Long timer
    Aug 25, 2009
    6,825
    NW Sydney, Australia
    @Tripleclampmoto Im assuming the answer is a resounding no?
    #62
  3. keener
    keener Speed changes you.
    Feb 24, 2010
    2,264
    Toronto, Canada
    #63
  4. 1coolbanana
    Aug 25, 2009
    6,825
    #64
    keener likes this.
  5. TrailTrauma
    TrailTrauma Nemophilist Supporter
    Jan 17, 2012
    6,495
    Ontario .. Superior
    What was the bike that @Camel ADV snapped in two? I thought it was a T7 or something...
    #65
  6. windblown101
    windblown101 Long timer Supporter
    May 17, 2010
    8,017
    Star Tannery, VA
    I think he snapped the handlebar in two. Not sure if there was damage to the clamps or not, but the clamps are like 4+ inches tall based on the photos I've seen. Eek!
    #66
  7. TrailTrauma
    Jan 17, 2012
    6,495
    Ontario .. Superior
    Yeah, bars and not sure what else suffered on the T700.
    #67
  8. Thumper Dumper
    Thumper Dumper Been here awhile
    Apr 13, 2016
    474
    Durban South Africa
    Yes I have them on my bike with the KTM PHDS handle bar mounts. If you want the handlebars as close to you as possible then they won't work for you. Because the mounts are bulkier you need to remove the pointer on the knob to turn it, unless you have the handlebars further forward. Untitled.jpg
    #68
  9. windblown101
    May 17, 2010
    8,017
    Star Tannery, VA
    #69
  10. brianbrannon
    brianbrannon They'll ride up with wear
    Dec 15, 2009
    3,234
    Denver, CO
    The Hyperpro CSC allows you to adjust how much damping you get total. The RSC only allows you to adjust when the high speed damping starts to work but the amount of damping stays the same. So the CSC is better for off road because you can adjust it to match the conditions. With the caveat that neither one is truly off road because they damp both directions but it's still better than the stock one
    #70
  11. jesusgatos
    Nov 17, 2006
    2,911
    santa cruz mtns, ca
    Think Fastway's System 5 may offer more adjust ability than any other stabilizer. Super high quality units, like them a lot. Only downside is they've very tall.
    #71
  12. Wheelie junkie
    Wheelie junkie Adventurer
    Apr 24, 2019
    32
    Victoria B.C.
    Looking for the correct link arm length when using the Hard parts mount for the Scotts damper, powerparts catalog
    Part number 63512905150 didn't come with the link. I already had the damper but with a incorrect link arm for a different application. Anyone have some insight or experience with a solution?
    #72
  13. windblown101
    May 17, 2010
    8,017
    Star Tannery, VA
  14. Thumper Dumper
    Apr 13, 2016
    474
    Durban South Africa
    You need the +8mm stepped arm. Part # LMK-4032-48 That's a Scotts part number not KTM.
    #74
    Wheelie junkie likes this.
  15. nibby
    nibby Been here awhile Supporter
    Feb 22, 2009
    572
    U.K. - Liverpool
    XRC from N.Z. is another option, they come with damping and dont use risers which is what I liked about it. Great bit of kit. I think Birch uses the same one. Kelly the guy who owns XRX and his wife are also great to deal with. Recommended.
    #75
  16. Wheelie junkie
    Apr 24, 2019
    32
    Victoria B.C.
    Humm, looks like it needs to be strait? But the +8. mm seems legit. Triple Clamp list one @+12 and Rottweiler show +8. The stupid thing is the Hard parts kit comes with everything except the lever, the damper is a separate item and number but no guarantee it comes with the correct link either as it's used on multiple applications in KTM's listings.!
    #76
  17. Wheelie junkie
    Apr 24, 2019
    32
    Victoria B.C.
    Thanks, but I'm not looking for a new system just need the correct link for the Scotts damper unit to work with the KTM hard parts mount kit which I already have both of.
    #77
  18. windblown101
    May 17, 2010
    8,017
    Star Tannery, VA
    Maybe if you throw it all on the bike you can verify how much if any drop you need to get it to ride where you want on the pin?
    #78
  19. Thumper Dumper
    Apr 13, 2016
    474
    Durban South Africa
    +8 and stepped is what you need. I have it on my bike, a straight one will sit too high on the pin. If you get the standard stepped arm and cut out the end of the slot it will also work. I did this while waiting for the correct one.
    #79
  20. Wheelie junkie
    Apr 24, 2019
    32
    Victoria B.C.
    Yes looks like you are correct the stepped one would be better for the reason you mention! Where did you get yours from?
    #80
