Stranded in Coldfoot
Discussion in 'Alaska' started by JGuz, Jul 24, 2019.
  1. JGuz
    JGuz Been here awhile
    Aug 21, 2013
    100
    Sherman Oaks, CA
    Never thought I’d have have to post here but here I am. Rode up the dalton to deadhorse, on the way back my clutch completely died when I got to coldfoot, can’t get into any gear and will need a rebuild.
    I’m currently just waiting in Coldfoot to see if someone with a truck is heading down to Fairbanks, but it’s not looking great so far. Will post on Craigslist Fairbanks as well, but if anyone knows of any other options to get the bike out of coldfoot, I would be extremely appreciative. Thanks!
  2. UncleRandy
    UncleRandy Been here awhile
    Aug 29, 2012
    119
    Alaska
    You could try contacting Lynden Transportation Services or Carlile Transportation Services to see if they have room on one of their trucks that is heading to Fairbanks. Those companies drive the route nearly every day and will often stop in Coldfoot. It's worth a shot!
    Phoenix101 and JGuz like this.
  3. Ullr
    Ullr C+ Racing
    Feb 18, 2006
    474
    PAMR
    Shouldn't need the clutch to get it into gear. Definitely don't need it to shift gears.
    Tom S likes this.
  4. JGuz
    Aug 21, 2013
    100
    Sherman Oaks, CA
    Thank you! Just called both of them and they both said they’d get back to me. Fingers crossed. Otherwise just waiting for anyone else who might be passing through
  5. Ringosdad
    Ringosdad Pennsyltucky hillbilly Supporter
    Jun 16, 2019
    195
    SW Pa
    Hope you get help! Just remember, sometimes when you least expect it a great memory is born!
    JGuz likes this.
  6. Solarmoose
    Solarmoose electric Supporter
    Sep 9, 2009
    1,092
    Fairbanks
    Does the clutch slip or can't disengage? If its not disengaging I would start it in first gear and power shift up through the gears. Shifting down is a bit harder but with practice you can do it. Stopping means shutting off the engine. Starting to go again means starting in first gear. Nice if you park pointing downhill slightly. And if it won't disengage, why? broken clutch cable or master cylinder low on fluid? Hope you can find a way back. I don't have a way to get there at the moment.
    JGuz and Tom S like this.
  7. JGuz
    Aug 21, 2013
    100
    Sherman Oaks, CA
    Update: it’s been all day and I’m still in Coldfoot for the night, but the problem has been found. The amazing Jeff Fredette happened to roll in with a few other advriders, helped me take take apart the clutch, found no problems, until we realized the that my front sprocket was missing it’s locknut somehow, which must have fallen off somewhere between deadhorse and coldfoot. Magically, a 27mm locknut appeared, I can shift my bike into gear again. I’m going to limp along to anchorage and get everything properly fixed, but this has easily been the most amazing thing that’s happened this whole trip. Thank you everyone! This community rocks.
  8. PistonPants
    PistonPants Crankcase Scavenger
    Jun 11, 2008
    760
    Cantwell, AK
    Jeff Fredette is in AK?!?! ISDE legend! So awesome!
    Piston
    #8
    dirtdoug and BikePilot like this.
  9. simestd
    simestd Packet plumber Supporter
    Sep 16, 2010
    751
    Anchorage, AK
    I believe that happened to @outdoorsman on his Alaska trip this summer also.
    #9
    Phoenix101 and Bigbob1 like this.
  10. outdoorsman
    outdoorsman Lets Ride! Supporter
    Jan 19, 2011
    393
    Elk Grove, California
    Close. But wrong highway Tom. I was on the Dempster. LOL
    #10
  11. simestd
    Sep 16, 2010
    751
    Anchorage, AK
    Different highway, but two riders on Tigers stranded by a sprocket retaining nut going AWOL in one season may indicate a problem. That nut doesn't need much torque to do its job, but it does need to stay put.
    Edit: Just spoke to a co worker who rides a Tiger and he said there are YouTube videos and even some dealer staff telling folks that the tab washer doesn't need to be bent up to secure the nut when changing the sprocket. Empirical evidence from Alaska this season indicates that isn't true.
    #11
    wilsonjw42 likes this.
  12. outdoorsman
    Jan 19, 2011
    393
    You're right, Tom. I didn't read the other posts. LOL. Yup, and it happened to @MapMaster on his tiger in 2015 trip to alaska as well.
    @JGuz get ahold of Sam @mach1mustang351, he's in Anchorage and helped me out with getting the OEM parts for me bike.
    #12
    mach1mustang351 likes this.
  13. Beezer
    Beezer Long timer Supporter
    Oct 26, 2004
    9,385
    Anchorage, formerly Spenard (hub of the universe)
    fuck it.... get 2 tabs :rofl
    #13
    JGuz likes this.
  14. JGuz
    Aug 21, 2013
    100
    Sherman Oaks, CA
    I still can't believe that Jeff Fredette worked on my bike. It's hallowed now, definitely can't sell it anymore :rofl
    The bike is holding together, but both fork seals blew out on the way down from coldfoot today. I'm leaving a trail of fork oil all the way down to Anchorage :D
    I've been on the phone with the folks from the motorcycle shop in Anchorage and they're waiting for me.
    Hearing about other tigers with this issue is crazy. Whoever thought it was a good idea to not secure the tab has clearly never been up here. I'm just going to make a sacrifice to the motorcycle gods for my good fortune in getting me this far.
    #14
  15. Tim McKittrick
    Tim McKittrick Long timer
    Dec 29, 2003
    2,284
    Wasilla Alaska
    Very often you can clean the dirt from your fork seals and stop the leak. Use a thin piece of plastic sheeting (in the olden days a snippet of 35mm film stock) as a wiper and run it between the seal and fork tube.
    #15
    SunshineTom and PistonPants like this.
  16. quentin80
    quentin80 Adventurer
    Jul 8, 2016
    12
    That's awesome! So the real question.. Was he riding a kdx?
    #16
    BikePilot likes this.
  17. jeepmedic
    jeepmedic Adventurer
    May 30, 2017
    22
    Cashton WI
    lol...he was riding a KLR 650. I was with him on the trip for two weeks.
    #17
    BikePilot and quentin80 like this.
  18. jeepmedic
    May 30, 2017
    22
    Cashton WI
    Glad you made it back safe. It was great meeting you and seeing to make it to the shop with the bush fix Jeff did. What did they all end up replacing @ the shop in Anchorage?
    #18
  19. JGuz
    Aug 21, 2013
    100
    Sherman Oaks, CA
    Same here! They replaced chain and sprockets (and the missing nut) and fork seals and oil.
    #19
