1. Livestream NOW at 9pm EST / 6M PST! Any Questions for Marc?
    Baldy + Alta CEO & Co-Founder Marc Fenigstein YouTube Live Chat here
    Dismiss Notice
Stroking my Banshee for Kenny.
Discussion in 'Some Assembly Required' started by Wildebeest90210, Jul 27, 2017.
  1. nickguzzi
    nickguzzi Long timer
    Feb 17, 2010
    8,103
    below the sea
  2. Wildebeest90210
    Wildebeest90210 Long timer Supporter
    May 24, 2013
    3,662
    I had looked at those but they only do 35mm, a little spindly for my peace of mind.
    Jim Lomas though probably more famous for expansion chambers, another thing I have to think carefully about down the line.
    Lomas moved from the UK to Czechoslovakia so I'm not sure how they would fit up for a one off.
    http://www.jl-exhausts.com/jl-yamaha-exhausts-410-c.asp
    I remember seeing an RD with hydroformed pipes years ago, they really have the anaconda that's swallowed a capybara look so I may well have a crack at that. The pipes will need to look slightly 'retro' though I think, we'll see, it's a way down the road yet.
    #22
  3. larryboy
    larryboy Stable genius.
    Jan 9, 2005
    26,070
    Über Alles,California
    I always liked how the stock Banshee chambers looked, not the best for power.
    #23
    Nixels likes this.
  4. Wildebeest90210
    May 24, 2013
    3,662
    Stripped the cases with only one minor incident.
    I had to weld double nuts and put a load of heat in to get studs out, they all went with a loud crack in the end though.
    The rubber engine mounts caused me a moderate amount of grief. I tried a press and damaged the front mount on the case slightly, this stuff is soft as sh1t. Then I tried pulling on stud bar with heat and no luck. They actually seem ok but being 30 years old they can't be in great shape really.
    Finally I went round each one (of four) with a drill until I could get grips and pull the middles out.
    Then very carefully hacksawed the outer sleeves.
    And out. You can see the damage here on the front lug. I'll dress it out a bit better but still pissed off. Could have been worse, both cases now have all studs and bearings out ready for cleaning up and some port matching.
    #24
  5. JCool
    JCool Long timer
    Oct 15, 2016
    3,686
    Seen this ?
    #25
  6. Wildebeest90210
    May 24, 2013
    3,662
    Nicely done.
    I started on port matching today but my compressor just can't keep up even with the smaller 3mm. I roughed out with a 6mm but that just killed the compressor, I'll have to visit another workshop down the road, there's a few hours in this and the cylinder.
    I fitted the new dowels and dremmeled the ally gasket to match the transfer ports on the base of the cylinder.
    Then transferred the dowels and gasket to the case and marked up.
    Then I started but gave up due to lack of puff. I'll carry on tomorrow using a shop with proper compressed air not my under powered garage flavour.
    #26
    Te Hopo, nuggets, waylongway and 4 others like this.
  7. Scoozi
    Scoozi Long timer
    Jun 6, 2016
    1,043
    London
    You carry on with the building, we'll keep putting up pictures to keep you motivated :D
    #27
    Te Hopo, GR0NK, nzrian and 5 others like this.
  8. cyclefreak13
    cyclefreak13 Been here awhile
    Aug 24, 2010
    219
    NC
    I'll just put this here.
    <iframe width="560" height="315" src="" frameborder="0" allowfullscreen></iframe>
    #28
  9. Fast Idle
    Fast Idle Since the Sixties Supporter
    Nov 9, 2012
    2,979
    The Great Land
    Somehow I just never get tired of watching Kenny ride that bike, it's just total bad-ass!
    Sure wish I had and RZ350 421 stroker project! Keep it coming!
    #29
    dpforth likes this.
  10. dpforth
    dpforth no inline fours
    Oct 22, 2010
    1,107
    YQQ
    Goosebumps every time. I love Vale's expression when the pack flies by. He can't be an easy guy to impress.
    #30
  11. villageidiot
    villageidiot Long timer Supporter
    Apr 29, 2010
    12,445
    Orange County, CA
    used to do a LOT of porting.....
    rough out with a 1/4 electric die grinder and a variable foot pedal, finish with the small air pencil. always left the walls sorta rough ish, 80grit, helped with atomization of the oil/fuel
    #31
    Wildebeest90210 likes this.
  12. Wildebeest90210
    May 24, 2013
    3,662
    :drif:viking
    I'll nickel plate if all works out for sure.
    #32
    Nixels likes this.
  13. Wildebeest90210
    May 24, 2013
    3,662
    Finished the transfer ports today.
    And they match really nicely.
    I did some work on the inlet and transfer ports on the cylinders, not much but the photos don't look anything like as much work as I put in. I wouldn't even post the transfer ones as it looks like I did F all in an hour.
    All I've done is clean up any flashing from the casting and knife edge the ports where possible. I'm not touching the port timing as I don't want to change it and don't have the confidence to tackle it anyway.
    #33
  14. waylongway
    waylongway madmax Supporter
    Dec 16, 2009
    4,092
    NorCal
    You can't ride that thing on the street .......:nono
    #34
  15. Kai Ju
    Kai Ju Long timer Supporter
    Jul 29, 2009
    4,262
    Long Beach, California
    The good thing about stickers is that they can be peeled off...not just stuck on.
    #35
  16. Kai Ju
    Jul 29, 2009
    4,262
    #36
    Makr and Wildebeest90210 like this.
  17. mach1mustang351
    mach1mustang351 Long timer Supporter
    May 12, 2014
    2,986
    Alaska
    Awesome!!! I have a TZ tribute on my bucket list of build bikes. Will be following this one!!
    #37
  18. lesman
    lesman Live easy, Brake Hard
    Sep 7, 2006
    4,023
    Baja Okahoma
    I'm jealous, your dremel works. I came from a tool deprived childhood.
    #38
  19. Wildebeest90210
    May 24, 2013
    3,662
    Yes my Dremel works, it's in its case with its key. I was tool deprived from an early age (although I had my first torque wrench at 14...) but that's why now I try to keep things in order.
    Exhibit A. Every time I look at this I think...' You know what, you're nearly a grown up'
    I've nearly finished this can and the red tube is attached !!!!!!!!!!
    #39
    Te Hopo, Nixels and waylongway like this.
  20. Roofchop
    Roofchop Hands up mother stickers, this is a f**k up!
    Jan 9, 2016
    680
    Carool, NSW
    Useful tip of the day...... I once complained to WD-40 as I never got the last bit out ( and not been spraying upside down.) They informed me to look on the top edge where there is an arrow (triangle) pointing up, you need to align the nozzle to it! Been doing that and now get empty cans!
    And they kindly gave me a free can as well!:-)
    Great work as usual Wilde!
    #40
