1. Livestream NOW at 11AM PST / 2PM EST!
    Baldy Interviews + Noraly "Itchy Boots" from Youtube YouTube Live Chat here
    Dismiss Notice
Stroking my Banshee for Kenny.
Discussion in 'Some Assembly Required' started by Wildebeest90210, Jul 27, 2017.
  1. Wildebeest90210
    Wildebeest90210 Long timer Supporter
    May 24, 2013
    3,694
    True that, but if you can hear a dry clutch over the wail of the exhausts then I'll have got something very wrong :D
    #81
  2. Bigbore4
    Bigbore4 Long timer
    Oct 21, 2010
    2,005
    Andover MN USA
    Ahh Grasshopper, you only hear it when she's pulled in.
    #82
  3. Wildebeest90210
    May 24, 2013
    3,694
    Yep, even then!
    #83
    Bigbore4 likes this.
  4. Bigbore4
    Bigbore4 Long timer
    Oct 21, 2010
    2,005
    Andover MN USA
    OK so now you are on the hook for High Def Audio. Keep it coming!
    #84
  5. larryboy
    larryboy Stable genius.
    Jan 9, 2005
    26,070
    Über Alles,California
    Flap disc on a grinder will clean that edge down fast to the point where you want to go slower with a file.
    #85
  6. dpforth
    dpforth no inline fours
    Oct 22, 2010
    1,107
    YQQ
    Loud Clutches Save Lives
    #86
    Dino de Laurentiis and Bigbore4 like this.
  7. Wildebeest90210
    May 24, 2013
    3,694
    No pics on this page! I been doing some boring non-photogenic jobs but....
    New studs in the top crank case..
    A nice pic of my billet thermostat housing from MBD.
    Oil sealed up the crank and dropped it in to the cases. I'm waiting for titanium case bolts to arrive tomorrow before I close the cases, 53 fasteners in Ti ordered, I had to pour a large one :photogbefore hitting 'confirm' on the order....
    For Banshee/RZ/RD nerds, the pins in the outer races of the main bearings that usually locate in the cut outs front of the case on the standard RZ are replaced on the Hot rods crank by o' rings. They stop the outer race from spinning in the case and also centralise at the same time! Now where is that bored as f#ck emoji,...:snore
    #87
    waylongway, lesman and larryboy like this.
  8. Kai Ju
    Kai Ju Long timer Supporter
    Jul 29, 2009
    4,279
    Long Beach, California
    How is an O-ring going to stop the bearing from rotating ?
    On my '77 RD400 the pins went into the holes in the upper case half, as seen in the first pic of the above post.
    Where the o-rings go was a half circle circlip to prevent the bearing from moving side to side.
    I'd be freaking out about now putting your engine together.
    #88
    villageidiot likes this.
  9. waylongway
    waylongway madmax Supporter
    Dec 16, 2009
    4,106
    NorCal
    :drink.......:cob........:knary
    :jjen........:bueller........:augie
    #89
    Wildebeest90210 likes this.
  10. more koolaid
    more koolaid Been here awhile
    Nov 5, 2015
    474
    Bel Air Md.
    Looks like a gearheads wet dream
    #90
  11. Bigbore4
    Bigbore4 Long timer
    Oct 21, 2010
    2,005
    Andover MN USA
    <snip>
    And I suppose that the heathen you are you didn't put ice in it when you poured it? Good whiskey needs some ice and a tad of water to bring out the smooooooth.
    #91
  12. nickguzzi
    nickguzzi Long timer
    Feb 17, 2010
    8,141
    below the sea
    I think it's most likely whisky, not whiskey. Adding ice is a rare affectation here.
    #92
  13. Wildebeest90210
    May 24, 2013
    3,694
    This from FAQ on the Hot rods website...
    'The OEM PTO main bearing has a small set pin (actually a ball) that must be located in the proper location in the cases. Failure to locate this pin will force the bearing out of round when the cases are clamped. This is not an issue with the Hot Rods Banshee cranks. Hot Rods has eliminated these locating pins and replaced them with o-rings. These o-rings help keep the cases sealed around the entire surface of the bearing and keep the bearing from spinning.
    O-Rings are much better than set pins as the O-Ring will help stabilize the bearings in engine cases that are becoming worn.'
    The drive side does not have the o'ring but both gearbox and that side main have the half circlips for location. The crank and seals all fit perfectly and all feels good so it's all bolted up. I did though take heed of the loss of pin from that main and added a smear of Loctite 641.
    With the help of my titanium obsession.....
    My friends for this stage...
    All the bolts top and bottom have cast numbers for torque sequence, I forgot why I always was Yamaha :D
    And we are all together now :beer All topped off with some lovely flanged Ti nuts :dukegirl
    #93
  14. Wildebeest90210
    May 24, 2013
    3,694
    I have access to these scales (no it's not a meth lab) so I thought I'd weigh my pistons with a view to maybe static balancing them. I didn't expect them to need anything but I got 0.1544 gram difference so I weighed some ally swarf and found it to be a relatively large amount so I set about the heavy one with file and drill. Never done this before so why not give it a go.
    So I got it to here, scales set to measure difference. This will do I think, lets not get too OCD:loco.
    I started by filing off some little casting lugs by the wrist pin, you can just see inboard of the two pin lube holes. That removed practically nothing so I gradually drilled the two casting lumps where the two ring pegs are located and eventually got there, a little nerve wracking but good fun. Will it make any difference, maybe 0.0021 HP :lift
    #94
  15. waylongway
    Dec 16, 2009
    4,106
    NorCal
    #95
    nwgeezer1 likes this.
  16. Wildebeest90210
    May 24, 2013
    3,694
    This is my new 5 axis milling facility. This roughed out and may be allowed in to the garage for hand finishing, that sounds wrong...happy finishing, no that's worse :fpalm
    And this my al fresco hole manufacturing plant.
    #96
  17. Wildebeest90210
    May 24, 2013
    3,694
    #97
  18. waylongway
    Dec 16, 2009
    4,106
    NorCal
    :tb
    #98
  19. Wildebeest90210
    May 24, 2013
    3,694
    Squish time, I'm going for 1.4mm as that's what I did on my last big 2T Husky with no probs for 97 octane pump and a quick google tells me this is probably good for this motor.
    Pistons in with base basket and cylinders nipped. No rings yet, also need to investigate the small end clearance, do I need thrust washers on the wrist pin?
    Heads on and nipped tight the solder goes in through the plug hole out to the squish band and the crank turned over TDC by hand. First pot with my solder twist gives between 1.21mm and 1.25 measured in a few places.
    Second one between 1.03 and 1.05
    So as you see from my squiggles on the bench I'll take the lowest one and then get the difference up to 1.4mm machined off the squish band in the domes. They are separate from the head to allow them to be swapped for a different size (mine are 21cc) and for ease of maintenance etc. I repeated the whole tightening and measuring process twice with the same results so happy to machine these measurements.
    #99
    Te Hopo, nuggets, larryboy and 2 others like this.
  20. Kai Ju
    Jul 29, 2009
    4,279
    I'm surprised by the large difference between the two. Is the error in the combustion chamber, or how the chamber sits in the head casting.
    I'd be curious to swap inserts left to right and remeasure the squish. If the squish remains the same then I'd suspect an error in the headcasting. If it moves with the insert then the error is in the insert.
    But is it in the combustion chamber side or the headcasting side ?
    Anyway, thanks for the step by step. Really enjoying this, and making me look on Craig's List for RDs and RZs.
