1. Livestream NOW at 11AM PST / 2PM EST!
    Baldy Interviews + Noraly "Itchy Boots" from Youtube YouTube Live Chat here
    Dismiss Notice
Stroking my Banshee for Kenny.
Discussion in 'Some Assembly Required' started by Wildebeest90210, Jul 27, 2017.
  1. Wildebeest90210
    Wildebeest90210 Long timer Supporter
    May 24, 2013
    3,694
    I'll try that. The head is CNC machined so unlikely, the cylinder block is cast (but machined faces), maybe, accumulative tolerancing from rod and piston? I'll take some measurements but won't lose too much sleep over it, I'll machine them right anyway.
  2. Wildebeest90210
    May 24, 2013
    3,694
    A new page, I'm not sure how to make pages longer, post less?
    Anyway, a page without pictures is crap. I took a nasty injury from a piston circlip under the fingernail today so I'm treating it by sipping the Rhubarb gin that has been living in the garage for a few weeks. Very enjoyable!!! :pimp
    I am left un-supervised tonight....
    larryboy likes this.
  3. Bigbore4
    Bigbore4 Long timer
    Oct 21, 2010
    2,005
    Andover MN USA
    Can you post up a couple pics how the chamber fit in the heads please?
    I have a jar of Bourbon and Cherries in the fridge a riding bud gave me for use of my NoMar. Mmmmmmm. You put any sugar or other in? Rhubarb is TART!
  4. Wildebeest90210
    May 24, 2013
    3,694
    I'm using this, a bit too drinkable on a school night......
    http://www.theboywhobakes.co.uk/recipes/2017/2/23/rhubarb-gin
    Bigbore4 likes this.
  5. nickguzzi
    nickguzzi Long timer
    Feb 17, 2010
    8,141
    below the sea
    Here's a really technical question - do you suck on the rhubarb once the gin is gone, or make a crumble?
    I make the occasional jar of morello cherry (cheapest lidl own brand) vodka - they aren't much use for anything else - and after everyone is paralytic, I make a boozy clarfoutis.
    Does the rhubarb gin look less like piss once poured? - or do you drink straight from the jar?
    villageidiot likes this.
  6. nickguzzi
    Feb 17, 2010
    8,141
    below the sea
    @Bigbore4: the morello vodka I make and also the sloe gin that is fairly commonly made at home here, from the fruit of the blackthorn, is usually sugared. The amount depends on how sour the fruit, and what your intended outcome is. The vodka ends up sweet and I use it as a digestive or liqueur. Roughly equal weights of fruit and sugar.
    You will not be smitten down if you try other ratios.
  7. Wildebeest90210
    May 24, 2013
    3,694
    Straight from the jar red neck style tonight, I can't comment on much else tonight. Like the sound of the crumble, temp may evap the alc though so probably go for suck. Hang on, I'll go to garage and try one.....
  8. nickguzzi
    Feb 17, 2010
    8,141
    below the sea
    We wouldn't expect anything else - a true pioneer and willing experimenter.
    The clarfoutis does loose the most of the alcohol, but the taste is sublime. Sufficient hint of naughtiness to excite...!!
  9. Wildebeest90210
    May 24, 2013
    3,694
    No Gin tonight....:fishie
    Two piece manifold allows the balance pipe to be junked, shame I quite like it, especially with a boost chamber....
    O'rings seal it up with a little vac grease.
    Two small countersunk screws hold the two parts.
    A bit of work to match to the reed blocks. Have done that now with a craft knife and also smoothed the joint between the two ally parts.
    juicy flawless and larryboy like this.
  10. Wildebeest90210
    May 24, 2013
    3,694
    So before I go for a 1.4mm squish I Email Roger at Wicked ATV Ca.
    Hi Roger, my 421 Serval parts all came through to the UK from my friend in Ca. Engine is coming together really well thanks, one question, what squish clearance would you recommend for this motor using 95 or 97 octane pump gas and road use in a bike?
    Thanks.
    Alright! that's good to hear. Anywhere from .036-.050 is fine. 165 under ibs of compression
    Thank you,
    Roger Arreola
    Wicked Motorsports Inc.
    Great, thanks. I got one measured at .041 and one at .047 so I'll machine the smaller one up to .047 to match.
    Cheers.
    So there you have it :deal
    JCool and larryboy like this.
  11. lesman
    lesman Live easy, Brake Hard
    Sep 7, 2006
    4,023
    Baja Okahoma
    I love the aluminum porn.
    more koolaid likes this.
  12. more koolaid
    more koolaid Been here awhile
    Nov 5, 2015
    474
    Bel Air Md.
    ^^^ Wanker :rofl
  13. lesman
    Sep 7, 2006
    4,023
    Baja Okahoma
    If Wanker means that I love the Aluminum Porn then Yo soy un Wankerista.
  14. Wildebeest90210
    May 24, 2013
    3,694
    Dome fit...like this with O'ring....
    I'm going to build up and fit rings, torque down cylinders and then measure squish. Further email from Wicked questions the difference between pots and I agree, I'll make whole rings of solder to drop in to the bores to measure proper. So now measuring and adjusting ring gaps.
    lesman and Roofchop like this.
  15. Roofchop
    Roofchop Hands up mother stickers, this is a f**k up!
    Jan 9, 2016
    682
    Carool, NSW
    Like the rings of solder, I thought the pistons could rock fractionally if "squished" on one side!
    Dave
  16. Wildebeest90210
    May 24, 2013
    3,694
    Indeed...
    Double check it. because they are both machined at same time. possible piston just rocked forward
    Thank you,
    Roger Arreola
  17. Bigbore4
    Bigbore4 Long timer
    Oct 21, 2010
    2,005
    Andover MN USA
    You have to be on the center line of the wrist pin or it will cock. I spent a short stint working on large 2-strokes (EMD). We pulled the inspection covers, and inserted a tool holding a piece of lead wire on either end through the inlet ports. Turned to align with pin and barred the engine over. It was a good way to quantify wear in the entire power cylinder.
    @Wildebeest90210
    Thanks for posting those pics. It's now clear how it works. Pretty cool. And as big a PITA as it will be I agree with your vendor on assembly at final torque to make this measurement.
    ETA not sure I would use a ring. I would use 2 pieces, opposed on either side of the piston on the wrist pin center line, held in place with a dab of assembly grease like Lubriplate 110 or similar. The ring might be too much to crush easily.
    dpforth, Kai Ju and JCool like this.
  18. Kai Ju
    Kai Ju Long timer Supporter
    Jul 29, 2009
    4,279
    Long Beach, California
    what he ^^^ said. In regards to just using two smallish pieces in line with the wrist pin. One on each side to prevent even the possibility of rocking in the wrist pin bore/rod.
  19. dpforth
    dpforth no inline fours
    Oct 22, 2010
    1,107
    YQQ
    Technique I use is a single piece of solder bent into a kind of 'omega' shape. Top loop on front of piston (but not into squish band) and ends over and parallel to the pin.
    tripodtiger and Bigbore4 like this.
  20. Kai Ju
    Jul 29, 2009
    4,279
    Clever, keeps it from moving during head installation and removal, but only gets squished where it needs to be.
