Strongest Loctite?
Discussion in 'The Garage' started by Vinz Klortho, Sep 19, 2021.
  1. Vinz Klortho
    Vinz Klortho Square Peg
    Nov 11, 2014
    1,483
    Fort Worth
    So what's the strongest, commercially available thread lock fluid? Looking for the sort of stuff that comes with an "Are you sure?" warning. Asking for a friend.
  2. Urbandrag
    Urbandrag KLiM Beotch!
    Oct 27, 2011
    384
    Motorcycle Heaven
    Depending on bolt diameter... Sometimes welding works best.
    9Realms and VX Rider like this.
  3. 1greenmachine
    1greenmachine Long timer
    Aug 28, 2010
    6,622
    green bay, wi
    Crossthreading is free and the strongest.
  4. Mongle
    Mongle Knuckle dragger
    Dec 4, 2009
    15,044
    North Carolina Y'all
    Green.
    Stasher1 and Bounder like this.
  5. Strong Bad
    Strong Bad Former World's Foremost Authority Supporter
    Oct 29, 2007
    13,893
    Omicron Persei 8
  6. anotherguy
    anotherguy Long timer
    Jun 18, 2009
    17,133
    the hills
    To give a good answer what are you going to be using it on?
    MrVvrroomm and ZoomerP like this.
  7. Vinz Klortho
    Nov 11, 2014
    1,483
    Fort Worth
  8. TripleTriples
    TripleTriples Long timer
    Feb 6, 2019
    1,936
    OH
    I dunno, have you tried JB Weld?
    #8
    1greenmachine likes this.
  9. david61
    david61 Queue, a word with 4 silent letters....
    Jan 15, 2013
    4,174
    Western Australia
    Red Loctite shouldn't be sold to the general public, it just fucks shit up. Blue or green.
    Refer to below.
    #9
  10. Urbandrag
    Oct 27, 2011
    384
    Motorcycle Heaven
    My weapon of choice is 273, when I install cheap thread inserts when I break a thread.
    LOCTITE 273 is a red, fluorescent, medium viscosity, high strength, dimethacrylate ester acrylic threadlocker designed for the permanent locking and sealing of threaded fasteners. Typical applications include the locking and sealing of large bolts and studs (M25 and larger).
    #10
    phreakingeek likes this.
  11. PeterW
    PeterW Long timer
    Nov 11, 2005
    5,452
    Gold Coast
    The horrible black stuff intended to set studs PERMANENTLY.
    That really does need warning labels, and labels to not screw round and get the job done fast :). You don't get a second chance when you realize that you should have chased the threads FIRST and made sure everything does go smoothly before using it.
    #11
  12. YesRush
    YesRush Long timer
    Aug 17, 2014
    4,662
    Va
    I had some red that releases at 200* - 220*
    #12
  13. Mongle
    Dec 4, 2009
    15,044
    You can't go by just the color really. There are 2-3 blues, 3-4 reds, 2-3 greens... Knowing the application really does make a difference in which one to use.
    #13
  14. anotherguy
    Jun 18, 2009
    17,133
    the hills
    Don't bring facts into this you'll only confuse things.
    #14
  15. Rider2
    Rider2 Been here awhile Supporter
    Jul 20, 2014
    696
    Delaware
    Whatever you use, clean the threads first. Nothing works well on oily threads.
    #15
  16. SoManyFish
    SoManyFish Been here awhile
    Apr 18, 2017
    988
    Canada
    True, but the characteristics of the variants within each color are close enough that a DIYer can choose by color. So, the answer to the original question: red loctite is the strongest to the point where the manufacturer considers it PERMANENT. Note: A few years ago Loctite introduced an orange which is much stronger than blue but still permits the fastener to be removed with hand tools. I've used it a few times and can attest that it does seem stronger than blue but also allows fasteners to be removed.
    EDIT - CORRECTION: I wrote "Loctite Orange" when I meant "Permatex Orange". AFAIK Loctite does not make an orange threadlocker.
    #16
    concours likes this.
  17. Mongle
    Dec 4, 2009
    15,044
    Not true. I'm not going to explain every one, but as an example of how wrong you are: blue 242 will not work well with stainless or aluminum. Blue 243 will.
    #17
  18. victor441
    victor441 Long timer
    Jul 27, 2009
    3,258
    Sonoma Co., Calif.
    Actually there is a surface insensitive version of threadlocker for situations where is is not possible or practical to get the parts perfectly clean...
    #18
  19. SoManyFish
    Apr 18, 2017
    988
    Canada
    Yeah, whatever dude. I'm not going to get into a p****** contest over Loctite. I'm not going down the "I'm right, you're wrong" road. Have a great day :-)
    #19
  20. SoManyFish
    Apr 18, 2017
    988
    Canada
    And the truly dumb thing is that all Loctite bottles are red with only a small rectangle indicating the color / strength so it's easy to make a mistake and grab the wrong bottle with disastrous results!
    #20
    pkat, 9Realms, spokester and 6 others like this.
