Stupid trials question thread...
Discussion in 'Trials' started by Garthe, Nov 2, 2014.
  1. Hoss Cartright
    Hoss Cartright 219.474.6657
    Oct 23, 2016
    951
    Galapagos Islands
    Last September I was "balked" for the first time since the 1970s. There was a big rock outcropping and there were a bunch of people in the section. They were so numerous, they had no place to go as I approached them. I called-out "BALK" and everyone knew it was legit. Got the re-ride, got the clean and moved on..
  2. alpineboard
    alpineboard Been here awhile
    Mar 2, 2016
    705
    New Hampshire
    I replaced one on my beta, the grooves worn in it were at an angle, so it held the chain briefly and released with a snap, which made a slap noise when the chain hit the swing arm guard. It is not reversible . I probably could use a new tensioner guide arm.
  3. D2W
    D2W Been here awhile
    Jun 8, 2017
    277
    Summerland, B.C., CANADA
    How important to a recreational rider is the state of the carcass of the front tire? From the date code, the front tire of my GG is from the fall of 2007 (and likely OEM). The sidewalls are somewhat cracked yet the knobs are reasonable. Would there be a noticeable change in the ride if I were to replace the tire with a new one? The current tire is a Michelin.
  4. Feel the knobs. If they're pliable and soft, it's fine. If they're really hard, it's garbage and I'd change it.
  5. lineaway
    lineaway Long timer
    Oct 1, 2011
    11,322
    nm
    For a recreational rider you would feel no difference. At the 2016 Colorado National I rode a 1976 Cota 348 with 20 year old tires. Traction was never an issue. Of course from a competitive view, replace them. I just rode the Donner National and I was going to install a new Michelin. Fortunately I ran out of time to change it, my worn out Dunlap did just fine. Being a Gasser I would spend the money on clutch plates or a shift shaft.
    Bronco638 likes this.
  6. Bronco638
    Bronco638 Nobody Home
    Dec 1, 2004
    5,635
    Elk Grove Village, IL
    Something similar happened to me a couple of years ago. I had no idea about the Balk Rule but there were a few folks in the section while I was approaching my first obstacle. A friend, not in my class, step into the line and I dabbed. He apologized immediately and the scorer awarded me a re-ride. I would hope that this is something that's just common sense but, at the same time, you should be OK with others in the section, as long as they're not impeding you.
  7. Ditch
    Ditch Long timer
    Sep 9, 2004
    1,710
    abq,nm
    One of our trials clerks was in a section I was riding earlier this year and while attempting to clear out kept running in the direction of my line. I was laughing so hard I almost fell over, but cleaned the section regardless (one of very few). He was really sorry.
    Norman Foley and Huzband like this.
  8. Buschog
    Buschog Long timer
    Nov 13, 2015
    1,227
    Carson City, NV
    Do you have any drills for me to get my weight off my hands and onto my feet.
    I know it seems stoopid, but I cannot seem to shift my weight back off from my hands. At least not for more than a few seconds or minutes.
    So, I obviously need to put some more dedicated effort into it.
    gravityisnotmyfriend and sceep like this.
  9. Gordy
    Gordy SUPPORTER
    Dec 30, 2001
    32,250
    NM
    One of Ray Peter's (look it up) main coaching tips it to ride one handed. Simply take your clutch hand off, hover it if needed, and ride. Try circles and figure eights. You will soon feel how the pegs control the bike. I've seen him ride some of our intermediate lines with one hand. :bow
    This reminds me.....I need to work on that drill some more.
  10. lineaway
    lineaway Long timer
    Oct 1, 2011
    11,322
    nm
    I think that is why I liked the curve foot pegs. It forces your weight back, but the first ride or two are hard on the ankles.
    Norman Foley and Gordy like this.
  11. Gordy
    Gordy SUPPORTER
    Dec 30, 2001
    32,250
    NM
    Agreed. They seem to help keep your weight back (where it belongs) but do put some pressure where you are not used to it. My new TRS doesn't have them but it feels to me that the new pegs act similarly as the old curve. :dunno
    Brewtus, riabma77 and Norman Foley like this.
  12. riabma77
    riabma77 Been here awhile
    Nov 29, 2018
    425
    Ruidoso, NM
    I have the bad habit to put too much pressure in the handlebars. What it seems to help (for me) is riding tight corners over steep terrain. It forces me to move my weight back, and learn to turn using the pegs. I guess it works because I don't dab so much, and my arms / shoulders aren't so tired after 2 hours.
    Interesting the technique to ride one handed. Maybe one day I will try it.
  13. D2W
    Jun 8, 2017
    277
    A question/comment from a novice/recreational rider >>> who does not want to start a flame-war <<<, might higher bars and/or bar-risers promote a more upright riding position, and hence have less weight on your hands?
  14. sceep
    sceep Long timer
    Jun 15, 2010
    1,491
    Edgewood NM
    Now you've gone and done it...
    Might bending your knees thus lowering your shoulders/arms achieve the same goal?
  15. lineaway
    lineaway Long timer
    Oct 1, 2011
    11,322
    nm
    :hair
    Nothing wrong with a taller bar, :baldy except you loose leverage. A taller rider might get by, but risers belong on CHOPPERS.:doh
    Gordy, Huzband and Hoss Cartright like this.
  16. Dorian
    Dorian huge carbon footprint
    Jul 7, 2004
    948
    WA State
    I think like sceep suggests, alter your riding position. I attended a riding school with James Lampkin a few years ago. The subject of bar risers came up in conversation. James said if you're somewhat proportionate bar risers are not needed (tall riders have proportionate leg/arm lengths for example). I fit in that tall category at 6'3" and with the proper stance, remembering to bend my knees, I see his point.
  17. Buschog
    Buschog Long timer
    Nov 13, 2015
    1,227
    Carson City, NV
    PERFECT!!! That is exactly what I was looking for. Know what I'm doing after work as a part of my warm up now. I'll have to remember that for 15 minutes or so of warm up for every ride.
    Seriously, thank you. I thought I was truly asking a stupid question.
  18. Buschog
    Buschog Long timer
    Nov 13, 2015
    1,227
    Carson City, NV
    I thought Curves tilted forward... so more flat footed when in a wheelie (vertical) position. Wouldn't that make it more difficult get my weight back, when in a normal riding position?
    lineaway likes this.
  19. lineaway
    lineaway Long timer
    Oct 1, 2011
    11,322
    nm
    You would think that, but I think the angle puts the weight on the back edge of the peg. Which makes the front end feel easier to come up. That is why it is uncomfortable the first ride.
  20. riabma77
    Nov 29, 2018
    425
    Ruidoso, NM
    Interesting review from Pat Smage:
    alpineboard and Norman Foley like this.
