    Dismiss Notice
Stupid trials question thread...
Discussion in 'Trials' started by Garthe, Nov 2, 2014.
  1. grizCP
    grizCP RMTA
    May 9, 2010
    755
    Chipita Park, CO
    What defines a disaster if replacing the case (both sides) and input shaft doesn't? I guess it could have been way worse if this happened in the Ute Cup halfway through the loop. I was 30 feet from my garage when it happened, so I'm pretty lucky there.
    Mike D likes this.
  2. lineaway
    lineaway Long timer
    Oct 1, 2011
    11,890
    nm
    It was more like this.
    :dhorse:bash:doh
  3. Takataka
    Takataka Been here awhile
    Sep 26, 2014
    578
    NZ
    When I was still working as a toolmaker we used the soap method for annealing aluminium/aluminum alloys
    http://www.technologystudent.com/equip1/heat3.htm
    I'm going to do some tests with scrap to see how close to melting point the soap turns. Maybe it will work as a warning when burning out gummed up exhausts.
    jonnyc21 and Junglejeff1 like this.
  4. y4m4
    y4m4 Calvin
    May 24, 2009
    573
    Federal Heights, CO
    This would probably work really well, but you need to be careful. Caustic soda is sodium hydroxide, AKA lye, and it can dissolve aluminum. Just be careful.
    You can buy sodium hydroxide in solution as Super Clean at Walmart. It's useful, but don't use it on your motorcycles.
  5. Junglejeff1
    Junglejeff1 Long timer
    Oct 20, 2016
    4,811
    Upper Michigan
    20200423_165116.jpg on the fantic I corked it up and filled it almost full with diesel fuel.The fuel desolved much of the spooge in the packing and then I rinsed out with water a few times.The diesel pulled a lot of the oil caught in packing out and when done pipe was quite a bit lighter. Did not want to chance using heat on a hard to get pipe.
    Brewtus, GTC, Huzband and 3 others like this.
