Super Enduro Vacuum Fuel Pump
Discussion in 'Dakar champion (950/990)' started by Midnightsun, May 20, 2011.
  1. Midnightsun
    Midnightsun Adventurer
    Mar 11, 2008
    10
    I think I've read all of the threads related to the vacuum fuel pump upgrade, but could find where you guys are picking up a vacuum source for the stock emission bikes. The threads refer to SAS free bikes. Did I miss something? What would you all recommend?
    Thanks.
  2. David P.
    David P. Been here awhile
    Sep 2, 2007
    356
    Kalmar, Sweden
    There are 4 holes on the intakes. 2 on each intake. Clearly visible without removing anything. Replace a bolt with a connector and you are set..
  3. Qwik
    Qwik Adrenaline Addict
    Apr 27, 2008
    8,457
    Aspen Colorado
    as David P said. Use one of the barb fittings on the manifold below the carbs. Make sure it has a large diameter opening. (Front left side one on my 950 Adv) and be sure to close your petcock when you are done riding.
  4. veetwo _tls
    veetwo _tls RENOVATIO:
    Nov 14, 2005
    2,832
    THE MALLEE OUT BUSH IN Sth Oz
    what's the correct size of these fittings ? i'm searching for some on ebay.
    i need one for my rear intake for the SER so i can sync my carbs.
  5. triplenickel
    triplenickel Long timer
    Jul 9, 2008
    2,910
    Campbell River, BC. Fantasy Island
    6x1.00 I think.
  6. Midnightsun
    Mar 11, 2008
    10
    Having difficulty finding one locally. Anyone have an online source? Is the correct size 6mm ? Haven't had as chance to pull the manifold bolt yet.
    Thanks, appreciate the info.
  7. cpmodem
    cpmodem Orange Caveman
    Nov 29, 2004
    7,130
    masa yee yah tee 59° 14' 9" N / 135° 26' 42" W
    TN gave the correct thread size. Don't you have some vacuum hoses on your SE already? Lotsa guys just add a "T" fitting in one of those.
  8. Midnightsun
    Mar 11, 2008
    10
    I must be be blind!! Here is a phot of the LC8. Can someone please ID the bolt holes David has referred to? Please note, I am running the stock SAS.
    Thanks again.
    #8
  9. David P.
    Sep 2, 2007
    356
    Kalmar, Sweden
    And of course the same for the other side...
    #9
  10. Midnightsun
    Mar 11, 2008
    10
    Duh.........I finally got it.
    #10
  11. Midnightsun
    Mar 11, 2008
    10
    Haven't been able to source the metric threaded hose barb locally and went to the KTM dealer to get a price on the OEM part.
    $31.00 dollars!!!! Really. :eek1
    #11
  12. cpmodem
    Nov 29, 2004
    7,130
    Don't you already have a couple on the bike?
    #12
  13. veetwo _tls
    Nov 14, 2005
    2,832
    using the vacuum pump you will use one of the barbed fittings for the vacuum on the pump. so you still need to purchase another so you have 2 x barbed fittings free for carb syncing.
    yes you can T off one barb fitting for the pump & syncing but you get a false/uneven reading when u sync compared to the other free intake vacuum.
    E.G. your better to sync direct to each intake vacuum so your carbtune gets a correct reading on each chamber.
    NOT try & sync with a T in the line because you be syncing the intake & pump when the time comes to do it.
    maybe David P could add a brass fitting to his vacuum pump kits ? as that part is really needed when you do this mod for future sevices
    #13
  14. cpmodem
    Nov 29, 2004
    7,130
    Oooops, forgot about syncing with the vacuum lines. Its been so long since I've done it that way :norton
    #14
  15. veetwo _tls
    Nov 14, 2005
    2,832
    regarding the brass fitting sizes
    in the MUNN online manual it shows the front is a different size to the rear (quoting on the 07 super enduro) is that correct ?
    MUNN Racing:
    Cylinder Head Front - (OEM came fitted on the bike new)
    ITEM 8 - 58336020190 VACUUM CONECTION M6/3MM '97 $3.31 (left side)
    ITEM 8 - 58336020190 VACUUM CONECTION M6/3MM '97 $3.31 (right side OEM)
    Cylinder Head Rear -
    ITEM 10 - 60036023000 VACUUM CONECTION M6/1MM M-GROOVE $27.93 (right side OEM)
    #15
  16. Qwik
    Apr 27, 2008
    8,457
    Aspen Colorado
    You need the larger one. Smaller one doesnt allow enough flow to actuate the pump
    #16
  17. veetwo _tls
    Nov 14, 2005
    2,832
    yes that's correct i used the rear intake barb that was fitted to my bike & swapped it over to the left side. (pic above)
    ITEM 10 (munn online manual 07 950 super enduro) - 60036023000 VACUUM CONECTION M6/1MM M-GROOVE $27.93
    what about when syncing the carbs ? do you use 58336020190 VACUUM CONECTION M6/3MM on the right on each intake so there equal sizes for vacuum flow readings ?
    OR
    use the same sizes that came with the bike for syncing ?
    ITEM 8 (munn online manual 07 950 super enduro) - 58336020190 VACUUM CONECTION M6/3MM '97 $3.31
    #17
