Suspension Compatibility - 2009 to 2011 R1200GS ESA
Discussion in 'GS Boxers' started by GHO100, Sep 16, 2019.
  1. BJMoose
    BJMoose that trick never works
    Oct 15, 2018
    586
    Hamilton Montana
    ^ The bike is equipped with ESA and I would keep that. Thanks.
    #21
  2. Bill-66
    Bill-66 I don't even know... Supporter
    Sep 13, 2009
    9,850
    The Northwet..
    I change shocks on all of them, my 17.5 , the day after bringing it home.
    Klause at EPM and Hyper Pro is my go to set up..including on my ‘08 with DMC side car...
    #22
    BJMoose likes this.
  3. (I^2)R/746
    (I^2)R/746 Rider
    Oct 12, 2012
    539
    Santa Cruz Mountains, CA
    So I replaced the suspension on my '11 with some Tractive front and rear. With ESA. Interestingly they abandoned the preload stepper on the front as it makes no difference (which I can attest to). I wanted to keep the ESA for basically one purpose: when the pillion jumps on I push a button instead of cranking a knob. For this convenience I gave up being able to really dial in the compression and rebound to suit my taste. It's pretty close and does suit my needs it's just not ..... really custom. I purchased them from Beemershop after a talk with Ted (I live 2.8 miles from there). From what I understand it's similar with Ohlins, Touratech and other "high profile name brands". Ted was very curious as to why I wanted to stay with ESA and not have the adjustability but at the end said the Tractive was what he had on his daily rider.
    The Tractive setup was about $2k. Third bike I've used Beemershop to set up. Happy with all of them. Spent more on my F800GS (but it really is quite good). Do all the install/uninstall myself. Give them a ring get an honest answer.
    #23
    Bill-66 and BJMoose like this.
  4. Tractive Suspension
    Tractive Suspension Adventurer
    Apr 2, 2012
    14
    Shock Absorber Valley, the Netherlands
    A reply to the original question. I know you already found the answer. The ESA units of all GS / GSA prior to 2010 and past 2010 are not interchangeable. Before 2010 Showa manufacturer, after 2010 WP manufacturer. The damping stepper motors are indeed from 2 different generations. The number of stepper motor incremental steps is double for similar damping change compared to prior 2010 (stronger motor).
    Good luck with yr choice. Any technical questions feel free to ask.
    #24
    BJMoose and GHO100 like this.
  5. Woland
    Woland Wannabe adventurer
    May 3, 2009
    274
    Gothenburg Sweden
    Not sure if that's correct, when I had my Showa units from my 2010GSA redone by Wilbers, I mounted used WP units as an interim solution and they worked just fine. Didn't throw any errors and worked as expected.
    #25
