1. AVOID SCAMMERS!
      (1) Do not transact without protections in place! Different payment options may limit your payment protection
      (2) Use a payment service like PayPal WITH (!) purchase protection.
      (3) Terms like 'Friends and Family' are a warning that NO payment protection exists.
      (4) Avoid transactions with new members with no history and "family or friend of friend" offers.
      (5) If you do not understand the payment method you're being asked to use; stop and do not proceed until you do
      (6) If you receive a suspicious private message, click the "report" link and let us know!
    LISTINGS MUST INCLUDE: Price, Location, Product Description(s) and NO Links to CL or EBAY or your post will not be allowed. Read the rules!
For sale Suzuki DR250/DR350 part out
Discussion in 'Bike Parts and Accessories' started by [email protected], Mar 19, 2020.
Thread Status:
Not open for further replies.
  1. Jeff@TheQuadShop
    [email protected] TAT survivor
    Nov 28, 2004
    8,125
    Crestwood, Kentucky
    I'm parting out a 91 DR250S, most all of the parts are interchangeable with DR350's. I'll be adding more parts to the list as I pull them from the bike. All prices are shipped to the lower 48 states only, I'm near Louisville KY if you'd like to pick something up.
    Complete headlight with ADVmonster LED conversion. Way better than stock! SOLD
    OEM muffler, needs to be sanded and repainted but it's solid and unmodified. SOLD
    OEM header, needs to be sanded and repainted but it's solid and unmodified. SOLD
    Aluminum guard set F&R rotor, R master, R caliper. Not beat up at all, would polish out like new. Hardware included SOLD
    SE matched case set, great condition. $135 shipped
    DR250SE bottom end, spins and shifts smooth, a little chain derailment damage but no leaks. $225 shipped
    DR250SE head and valve cover with rockers. The rockers and cam journals are excellent. This motor dropped a valve and scuffed up the chamber some but it doesn't look like it got into the valve seats. $125 shipped
    Left side side cover with stator for SE models with stator and starter gears. $89 shipped
    Rear grab bars, the 3 on the bottom are aluminum. Blue one is sold. $25 shipped
    Rear brake caliper, bracket, master cylinder and hoses. Works good, no damage. $35 shipped
    Left side plate from the 98 dirt model, very nice condition other than the one small mark near the back. It's not a hole, just a divet. SOLD
    Brand new seat cover for all 1990-1999 DR250 and DR350's. SOLD
    Rear wheel with rotor and sprocket. As I understand it, this is a nice 18" upgrade for DR650's. It is true and the bearings spin smooth, it does have 1 missing spoke. The rotor has some wear but still lots of life left. There is scuffs on the rim from tire levers. Spacers are included. SOLD.
    Front wheel in really nice condition, the scuffs are very minimal. No cracks, bends or loose spokes. The rotor has lots of life left, bearings feel pretty good. SOLD
    Passenger pegs with bolts. Good shape but could use a coat of paint. SOLD
    Headlight shroud. Excellent condition, 9 out of 10, no scratches, just a slight sticker chip. SOLD
    Right side number plate. Very good condition except for a couple small scuffs. SOLD
    Kick start conversion assembly. This is the parts that you need to add a kick starter to your e start DR250 or DR350. The only other things that you will need are a new shaft seal 09283-20044 $3.87 and a clutch cover gasket 11482-14D03 $13.03. This is an easy swap with basic hand tools, I can provide instructions if you need them. SOLD.
    DR250 complete head and cam with manual decompression in very good condition, came from a good running bike. No signs of oil starvation, did not smoke. SOLD
    Clutch assembly from 91 S model, great shape. The plates are in spec and there's no wear on the basket to speak of. Did not slip. SOLD
    Rear turn signal in great shape, no cracks or cut wires. SOLD
    Front fender in excellent condition, no scratches, stains or cracks. If this doesn't sell, I'll put it on my personal bike. SOLD
    Rear fender, not quite as nice as the front but still in very good shape. No cracks, just some very minor scuffs. SOLD
    Rear fender extension, excellent condition. SOLD
    Stator and cover from the 98 dirt model. SOLD
    Complete dirt model main harness. Nothing has been cut, removed or modified. $35 shipped
    Shifter mechanism. If your DR isn't going into gear easily, this is most likely your issue. $30 shipped
    Regulator rectifier, should work on any S model. SOLD
    CDI box for a dirt model. SOLD
    Clutch cover with bolts. No cracks or leaks but could use a coat of paint. SOLD
    Right side crank case half with oil pump, good bearings. No cracks or leaks. SOLD
    Unmodified air box with intake and cage. If you know these bikes, you know that these are getting very hard to find in original condition. Edit, side door found and included. SOLD
    Front fork assembly, good condition, not leaking as of right now but always a good idea to replace the seals. Compression and preload adjustable, 15mm axle. SOLD
    Dirt model tank, it's in really nice shape considering it's age. It does have a few light scuffs and very slight yellowing as seen in the pics. Comes with petcock, cap and brackets. SOLD
    Compression and rebound adjustable shock from a 98 dirt model. It's in excellent shape with no signs of leaking. These are a great upgrade if you have a street model DR. Hard to find SOLD
    Chain guide and guard from a dirt model. Far stronger than the plastic one that comes on the street models. SOLD
    TM33 Pumper carb, throttle, cables and boots from a 98 DR350 dirt model. This is everything you need to swap your street CV carb to a pumper carb. It came from a good running bike. Almost no wear on the slide. SOLD
  2. Alaska1WD
    Alaska1WD Long timer
    Dec 14, 2014
    1,389
    Alaska
    I suppose it's too much to ask for a transmission, but if by chance you are selling, I'll buy. Dibs :)
  3. Jeff@TheQuadShop
    Nov 28, 2004
    8,125
    Crestwood, Kentucky
    PM sent
  4. brownvv
    brownvv Been here awhile
    Sep 23, 2012
    966
    colorado
    I bet that's why he is parting it out....
    [email protected] likes this.
  5. brianpeck
    brianpeck Been here awhile
    Apr 9, 2017
    332
    Santa Barbara, CA
    Might have an extra airbox door if someone purchases your airbox assembly and needs the door...
  6. mentolio
    mentolio King of the island of unwanted toys...
    Jul 14, 2016
    1,487
    I'll take that right side crankcase half for $45 shipped!
    PM sent.
  7. deaconjones
    deaconjones Been here awhile
    Jun 5, 2004
    452
    West TN
    Off topic, sorry but what camera/lighting are you using? Great detailed pics!
  8. Jeff@TheQuadShop
    Nov 28, 2004
    8,125
    Crestwood, Kentucky
    It just an iPhone 11 Pro
    #8
    deaconjones likes this.
  9. Inquilino
    Inquilino Adventurer
    Apr 21, 2019
    13
    Buenos Aires
    I want the Front and Rear fender, also the CDI
    #9
  10. Jeff@TheQuadShop
    Nov 28, 2004
    8,125
    Crestwood, Kentucky
    Great, sending PM
    #10
  11. Paranoid_android74
    Paranoid_android74 Adventurer
    Jun 22, 2016
    15
    SE MI
    Dang it! Right side cover is already sold?
    #11
  12. Jeff@TheQuadShop
    Nov 28, 2004
    8,125
    Crestwood, Kentucky
    No, the clutch cover is still available.
    #12
  13. Paranoid_android74
    Jun 22, 2016
    15
    SE MI
    Sorry, I meant the side number plate.
    #13
  14. Jeff@TheQuadShop
    Nov 28, 2004
    8,125
    Crestwood, Kentucky
    Oh yeah, that was the first piece that sold.
    #14
    Paranoid_android74 likes this.
  15. Jeff@TheQuadShop
    Nov 28, 2004
    8,125
    Crestwood, Kentucky
    Do you still want these @Inquilino ?
    #15
  16. mentolio
    Jul 14, 2016
    1,487
    Got the engine case half yesterday, very happy with the condition of the oil pump (main reason I bought it). I think the rear-most transmission bearing (which I also need) may clean-up nice too. Great deal man, thanks a lot!
    #16
  17. Jeff@TheQuadShop
    Nov 28, 2004
    8,125
    Crestwood, Kentucky
    Your welcome, thank you!
    #17
  18. Alaska1WD
    Dec 14, 2014
    1,389
    Alaska
    I think I have a right side plastic fairing in really good shape, pm me!
    #18
  19. thechief86
    thechief86 jack of all daniels
    Sep 5, 2015
    1,991
    Bethpage, TN
    I'd love to have a stock muffler if you have one? My bike is a 99 dirt model 350...
    #19
  20. Jeff@TheQuadShop
    Nov 28, 2004
    8,125
    Crestwood, Kentucky
    Sorry I sure don't.
    #20
Thread Status:
