Suzuki TS Thread
Discussion in '2 smokers' started by wfopete, Oct 10, 2012.
  1. slideways
    slideways España
    Mar 1, 2003
    15,998
    Spain
    Pull the sparkplug, kick the motor over a dozen times to dry it out. Put in a new sparkplug and see what happens.
  2. traffic.cones
    traffic.cones Adventurer
    May 29, 2017
    23
    Could be, although it mostly leaks onto the ground.
    I'll check that.
    Think it's more than just flooded. New plug wouldn't hurt though.
  3. How much air is in that fuel it's getting?
  4. traffic.cones
    May 29, 2017
    23
    Whatever the supplier put in the 91 octane.
  5. All fuel, no air makes a dull bike.
  6. Twnspin
    Twnspin Been here awhile
    May 29, 2018
    163
    Pennsylvania
    Sooo... I swapped the engine from my 74 ts250 for a "known" good engine, because the clutch was slipping ...and I was going to rebuild the original. I had riden this bike with the known good engine in it and everything worked and ran fine. Upon reassembly I cannot get the bike in first gear. All the way down seems to stop as if it's in, but it rolls free. Pull up to 2nd and it's locked in gear.
    I pulled the wet cover off and verified the shift rod and spring where installed correctly, all seems free but no first? Any ideas??
  7. Twnspin
    May 29, 2018
    163
    Pennsylvania
    So I decided to fill the trans and run it to see what happens. It has only neutral and second gear. Will not go up or down from there. Just hits the end of lever travel ...and nothing happens. Any one out there deal with this on anything similar before?
  8. PFFOG
    PFFOG Richard Alps-aholic Supporter
    Aug 19, 2005
    7,640
    Western NY, further from NYC than 6 entire states
    Is the detent spring and ball in place (looks like a drain plug on the bottom of the motor)
  9. Twnspin
    May 29, 2018
    163
    Pennsylvania
    Yes it is. I ended up taking the clutch off and found I must have let the shifter "gear" slip from the shift drum mechanism. It was clocked one tooth up from center on the drum side, allowing to only catch 1 position up or down. After reinstalling all seems good now.
    PFFOG likes this.
  10. 85 Tenure TT
    85 Tenure TT Adventurer
    Jul 21, 2018
    19
    Leaburg, OR
    Evening all. Pick up a pair of basket case ‘74 TS185s off craigslist for $100 a couple days ago. The Orange one will be the keeper, less rot, and should have enough parts between the two to make a good bike. Both engines are a bit tough to turn over but luckily were stored under cover and the guy put a little oil in the cylinders before he stored um. Will free um up and see what we get for compression then move on to the rebuild. Never had one of these and they seem like a great, simple bike. Will keep y’all posted. Cheers 625D58F6-38D5-49BE-A710-F69EBBAD3C53.jpeg 11A03AD0-F69B-4543-ABEF-0A8EF1C190A7.jpeg
    zone47, spo123, spokester and 4 others like this.
  11. Miguel Sanchez
    Miguel Sanchez VD #103 Supporter
    Jun 21, 2010
    2,318
    Bend(over), OR
    Good score! I saw those over in Alsea and was tempted, but I’ve got too many projects as it is. Glad they went to a good home!
  12. 85 Tenure TT
    Jul 21, 2018
    19
    Leaburg, OR
    Those are the ones. Where are you outa?
  13. sleazy rider
    sleazy rider Green thumbed fool
    Mar 6, 2007
    5,407
    Snowbird in Houston, TX
    Heh, glad I found this thread. This is sitting in my basement awaiting winter's end. It needs a good goin thru again as it hasn't been used in about 10 years. It was bought to teach my sons to ride back in the early 2000's for a couple hundred bucks running and just over 1000 miles on the odo. I replaced the ignition switch, a fresh battery and a bit of general maintenance over the years since.
    All cleaned up and running after purchase.
    From the CL ad that set the hook in me. :lol3
    Needs a side cover, the exhaust de-rusted and coated and some general clean up again. I have a proper rear fender sitting in storage for the re-fit.
    zone47 and spokester like this.
  14. Miguel Sanchez
    Jun 21, 2010
    2,318
    Bend(over), OR
    Over the hill in Bend. I ride with no fewer than 5 other guys with TS/TC’s. Reliving those early days of our youth, when those bikes were brand new, is a hoot!
  15. 85 Tenure TT
    Jul 21, 2018
    19
    Leaburg, OR
    My brother lives in bend. Next ride I do with him out there we’ll see if y’all are up for an outing. If you find any parts you don’t need let me know, I have a list going already for the 74
  16. 85 Tenure TT
    Jul 21, 2018
    19
    Leaburg, OR
    716BC69F-3E8B-46BD-9CCF-7692A181D86E.jpeg 86AC7052-ECAC-4ED5-869D-EAAAAFC6B587.jpeg Alright so I got one engine freed up (soaked top end in sea foam overnight and gave a few swift kicks) After cycling it for a few minutes with plug out did a compression test and it came out at 110psi! Top end showed just serface rust on the rings and cylinder. After draining/a bunch of powerwashing/sandblasting/scraping/
    polishing/painting/and beer drinking... engine and carb are throughly cleaned inside and out and clutch has been cleaned in kerosene and put back together. Top end is all polished up inside too. Next I move onto suspension.
  17. 85 Tenure TT
    Jul 21, 2018
    19
    Leaburg, OR
    Suspension and triple/controls done. Looking to order the new body stuff. Question I have for anyone, will 71/72 front and rear fenders fit on a 74. Or does anyone have body parts they wanna sell me. 65C52552-AA51-48C1-B4C9-DB4BFCA6E961.jpeg 1E9C9421-975C-47C7-8F98-21B0B9D4E1B5.jpeg
  18. HMP
    HMP Adventurer
    Jun 13, 2017
    24
    Looking at a 74 ts100, just like I had a pre-teen.
    Question - what would one of these, realistically, do on the highway? 50mph? 60?
    Any way of getting a few more hp out of these?
    Any engine swaps that are pretty straight forward/easy?
  19. JKady
    JKady Adventurer
    Sep 17, 2018
    61
    Auburn, WA
    My 125 is starting to come around. I ended up buying a pretty complete parts bike for $100, robbed it of pretty much everything suspension wise, engine was complete so I swapped that over as well after getting it to sort-of run. This one is going to end up dirt only since most of the street gear was already gone from both bikes. May try my hand at the local vintage MX races if I get it working well. [​IMG]
    Brtp4, aptbldr, travlin and 1 other person like this.
  20. b56tc
    b56tc Adventurer
    Aug 28, 2014
    80
    midwest flatlands
    It appears this thread is still active and monitored - can you help a restoration noob out - where to source a owner's manual, FSM, parts outlet for a '74 TS 185?
    thank you. Reading this forum has inspired me - I've had this one since new but it has been sitting since 1978 - about 2,000 mi on it - I'm committed to seeing it move again on its own power
