Suzuki TS Thread
Discussion in '2 smokers' started by wfopete, Oct 10, 2012.
  1. Hellracer.nl
    Hellracer.nl What the hack???
    Aug 25, 2012
    1,345
    Netherlands
    Nice one!
    I've just returned from a small late night ride around the neighbourhood:
    #81
  2. KX50002
    KX50002 NooB, my ass
    Mar 18, 2012
    2,079
    NEPA
    I had a TC 100 and a TC 125 when I was a kid, wish I still had them.
    Sent from my SAMSUNG-SGH-I847 using Tapatalk 2
    #82
  3. LWC3077
    LWC3077 Been here awhile
    Apr 4, 2014
    137
    South Australia
    Thanks for reply, that should help me. 46T is pretty big so i assume you dont do much open road riding, mostly tight stuff?
    You forgot to answer question about tyre size, but i think i will try 120/90 x 18
    Do you like the quicker steering? A magazine test i got says they are pretty raked out from std and 400mm is a full 40mm longer than the stock shocks.
    #83
  4. Hellracer.nl
    Aug 25, 2012
    1,345
    Netherlands
    I've been riding last sunday, clearly not enough speed....
    #84
  5. telmo744
    telmo744 n00b
    Jun 2, 2014
    5
    Portugal
    Yesterday I've got my bike borrowed back from a friend. :clap
    '89 TS125R (SF15A), about 85000km driven and still on original rear shock...
    He liked her a lot, but says he suits best its (much newer) Triumph Scrambler. :jack
    Whatever... :fpalm
    Love my TS, not a racing machine but sounds wonderful...Not in a million years I would sell this cute Suzi!! :raabia
    #85
  6. Motodeficient
    Motodeficient Been here awhile
    Jul 5, 2011
    479
    Maine
    Hey guys,
    Just picked up a 72 TS125 today... I've always wanted a 2-stroke that I could ride on the road, they just sounds cool.
    Seems to run pretty good but I think with a carb clean and some fresh gas it should run even better. I plan to ride this mostly on the road around the neighbor hood.
    I got the tail light working today but the headlight is toast. Those are hard to find. Anyone have one they want to part with? Thinking about retrofitting a different socket into the headlight so I can put a more standard bulb in there without having to replace the entire sealed unit.
    Ordered a few things off ebay for it tonight. New tach cable, bulbs for the speedo/tach, new 6v battery, mirrors.
    What does the battery actually do on this bike? The tail light is working without a good battery hooked up. The horn works, but it is very very weak.
    #86
  7. wingdog
    wingdog n00b
    Aug 3, 2014
    5
    Reno, NV
    My wife had this ts when I met her in 84. We still have it. 1973 td 250.
    #87
  8. Motodeficient
    Jul 5, 2011
    479
    Maine
    Does anyone know what GE type bulb would go in the taillight of a 72 TS125? I popped a GE 1157 (12v) in there by sanding down one of the contact pins, but it was only a single filament bulb. I need a dual filament single contact 6v pin that fits into the same socket as a GE 1157?
    #88
  9. Miguel Sanchez
    Miguel Sanchez VD #103 Supporter
    Jun 21, 2010
    2,317
    Bend(over), OR
    GE 1154 is what you need... I found an LED version on line that works really nice - bright and low current draw.
    #89
  10. farmer58ZA
    farmer58ZA Adventurer
    Nov 25, 2008
    14
    Johannesburg, South Africa
    Bought a '72 TS250 a couple of years ago and turned into a VMX mount for the Pre-75 class:
    Complete with Montesa forks and home made pipe!
    Regards
    David
    #90
    The Flyin Hawaiian likes this.
  11. Miguel Sanchez
    Jun 21, 2010
    2,317
    Bend(over), OR
    Nice job! Did you do the math and design your expansion chamber for a particular power characteristic, or just wing it?
    #91
  12. farmer58ZA
    Nov 25, 2008
    14
    Thanks Miguel
    I did the calc's off Gordon Jennings formulae. Drew and made up the templates on my dining room table, cut the sheet with a jigsaw. Bent the sections with a rubber hammer over a pipe mandrel. Header is from an auto shop. Practical issues always mean that the pipe is never really as per formula. Bike goes well but is no fire breather. Needs a bigger than stock 28mm carb to wake it up now.
    Regards
    David
    #92
  13. Miguel Sanchez
    Jun 21, 2010
    2,317
    Bend(over), OR
    Shave about 2lbs off that flywheel (go to an internal rotor), raise the exhaust port about 1.5mm, open the transfers as much as possible, and put a 36mm Mikuni on it. It'll run hard!
    #93
  14. slideways
    slideways EspaƱa
    Mar 1, 2003
    15,365
    Spain
    Try to find one of the factory hop up kits. I did a few of these in 1970 it turned the docile TS into what eventually became the TM250.
    [​IMG][/IMG]
    #94
  15. Miguel Sanchez
    Jun 21, 2010
    2,317
    Bend(over), OR
    Those are like gold! I wish I could find one of the hop-up kits for a TS185...
    In the meantime, I have a '71 185 running a Kawasaki snowmobile piston that displaces 220cc. It pulls pretty good for a 185 ;-)
    #95
  16. ADVill
    ADVill Been here awhile
    Sep 9, 2013
    612
    West Tn, USA
    Picked up a little gem
    #96
    slideways likes this.
  17. Old Queenslander
    Old Queenslander Been here awhile
    Jun 30, 2013
    245
    Townsville Queensland
    I posted this elsewhere but this was one of my favourite bikes.
    #97
    zone47 likes this.
  18. Dansrc51
    Dansrc51 I need a cape....
    May 14, 2008
    2,525
    Eugene, Oregon
    They'll run if you let 'em
    #98
  19. Pocketsprocket
    Pocketsprocket Been here awhile
    Oct 21, 2015
    218
    Oregon
    Nice TS185. I put many a mile on one back in the 70s, great motorcycle! looks like Oregon woods in the background?
    #99
  20. Dansrc51
    May 14, 2008
    2,525
    Eugene, Oregon
    It's actually a TC 185 and it's in the Bohemia mining area above Cottage Grove, Or. If you're in Eugene, come play with us some time. look at the regional forums.
