Swapping wheels
Discussion in 'Trials' started by Beatprojim, Mar 28, 2020.
  1. Beatprojim
    Beatprojim Beatprojim Supporter
    Sep 2, 2015
    297
    Acme, PA
    A while back I acquired a spare rear wheel for my Sherco. The idea of keeping a competition tire fresh and sharp and then having a practice tire/wheel sounded great. Easy enough to throw in the van as a back up too. Well, the Sherco was sold and replaced with a TRS. I discovered that the Sherco wheel would fit the TRS with just a 1mm washer on both sides of the wheel. The most important thing is to get the brake disc to roll free between the brake pads. Now, I am playing with a Montesa and it makes me cry to think that expensive Michelin is going to wear out just practicing. So, on goes the Sherco wheel. This time I need a 3mm washer on the disc side and a 1mm washer on the sprocket side. Now I have a Montesa practice wheel. Just for fun, sized up the TRS wheel to fit the Montesa. I needed to use the TRS wheel spacer on the sprockets side plus 4mm of washers and the stock Montesa wheel spacer plus a 1mm washer on the disc side. You can get 1mm washers and 3mm washers and mix and match. Moral of the story is it is very likely most current trials wheels can be swapped with one another with the help of some washers - they all seem to have a 17mm axle . Sprockets, of course vary so they may have to be swapped but that isn't too hard. Besides saving my good tire, my spare has already saved the day on far away ride for a friend that that had a flat. Grabbed it out of the van, swapped sprockets, and off he went. Here are a few pics.
    y4m4, BikePilot, Huzband and 3 others like this.
  2. Yinzer Moto
    Yinzer Moto Sloppy 300 rider Supporter
    Jun 13, 2008
    40,317
    Pittsburgh PA
    I am a bad person, I was hoping this was going to end in that you were unable to swap wheels, so I could buy that spare wheel from you....
  3. MATTY
    MATTY BORDER RAIDER
    Jun 23, 2014
    4,990
    England On the Scotish border
    Do not feel ashamed its exactly how my mind works as well.
    Yinzer Moto and Huzband like this.
  4. Huzband
    Huzband Team Dirt
    Oct 4, 2006
    11,118
    Cowford, Fl.
    You guys have been reading too many of @Brewtus posts. :D
    y4m4, Yinzer Moto and MATTY like this.
  5. MATTY
    MATTY BORDER RAIDER
    Jun 23, 2014
    4,990
    @Brewtus is hardcore like a diving duck, we are just like dabblers. :lol2
    jonnyc21, Huzband and Yinzer Moto like this.
  6. Yinzer Moto
    Jun 13, 2008
    40,317
    Pittsburgh PA
    I spot that wheel every time I am over his house. Either on the back of his TRS or sitting in the corner of the garage. I always think, “damn, I need to get a spare wheel.”
    jonnyc21 and MATTY like this.
  7. MATTY
    MATTY BORDER RAIDER
    Jun 23, 2014
    4,990
    Im exact same you can never have enough spares, but you already know that. :lol2
    jonnyc21 and Yinzer Moto like this.
  8. irishgb
    irishgb Adventurer
    Jan 31, 2014
    52
    can you tell us where you get the washers ?? thanks
    #8
    Norman Foley likes this.
  9. motobene
    motobene Motoing for 49 years Supporter
    Mar 9, 2013
    7,487
    ABQ NM & Wichita Mountains OK
    That's good info! Now I wish I had a spare wheel:bow
    If it works on a 4RT it could also work on the 315R, and that bike has an issue, I think, of using an oddball rear sprocket that is hard to find. A modern wheel with no old-style rim sealing band would be a great upgrade.
    #9
    Beatprojim and Huzband like this.
  10. Beatprojim
    Sep 2, 2015
    297
    Acme, PA
    #10
  11. Beatprojim
    Sep 2, 2015
    297
    Acme, PA
    Sorry, a top end is all you can get this week.
    #11
  12. irishgb
    irishgb Adventurer
    Jan 31, 2014
    52
    thank you for the washer source Cheers !!
    #12
  13. Beatprojim
    Sep 2, 2015
    297
    Acme, PA
    My Sherco practice wheel just founds it's way onto a Vertigo. One, 1mm washer between the swing arm and the left wheel spacer was all it took to fit perfectly.
    #13
  14. Bronco638
    Bronco638 Nobody Home
    Dec 1, 2004
    5,734
    Elk Grove Village, IL
    You need to pack up the various washers into "kits" for each manufacturer. Then, sell them for exorbitant prices....
    Wait, too late. You posted all your R&D info. :bluduh:D
    Good on you for sharing.
    #14
    Beatprojim likes this.
  15. Yinzer Moto
    Jun 13, 2008
    40,317
    Pittsburgh PA
    I have thought about having some new bearing spacers turned up so that the washers don’t need to be used.
    #15
    Beatprojim and Boom Boom like this.
  16. grizCP
    grizCP RMTA
    May 9, 2010
    761
    Chipita Park, CO
    :hmmmmm If you swap wheels with a Beta, you can run down your nubs evenly, since it would be backwards!
    #16
  17. motobene
    Mar 9, 2013
    7,487
    The WR450F I worked on and rode had a spare set of wheels. One set with a smaller rear sprocket with trials tires, another geared down with knobby tires. I fit the latter and converted to Tubliss to be able to run the stiff knobbies at lower pressure (7 - 10 psi). Very handy to have two sets of wheels!
    #17
  18. Yinzer Moto
    Jun 13, 2008
    40,317
    Pittsburgh PA
    You can also even out sprocket wear!
    #18
    grizCP and Huzband like this.
  19. Thesolidman1
    Thesolidman1 Been here awhile
    Dec 15, 2011
    123
    Nor Cal
    Friday Fun Fact, replacement Beta rear wheel is bare, just rim/ hub/ spokes, replacement Sherco / Scorpa wheel is the whole enchilada, disc, sprocket, even IMG_8763 2.JPG the coveted X11, and priced accordingly ha ha.
    #19
    motobene and Huzband like this.
  20. Huzband
    Huzband Team Dirt
    Oct 4, 2006
    11,118
    Cowford, Fl.
    Hubba hubba on the X11. Bestest grippiest tar I've ever ridden on.
    #20
