swing-arm as leading link
Discussion in 'Hacks' started by mantree, Sep 6, 2017.
  1. mantree
    mantree Been here awhile
    Oct 17, 2012
    886
    Has anyone ever considered using a swing arm from a motorcycle as part of leading links? I was thinking of using the swing arm from a CB750k. This would greatly simplify construction as well as make for a bit of adjustment.
  2. Pigeon
    Pigeon because white owl was taken
    Apr 30, 2007
    364
    taos new mexico
    yeah I have considered how it could be done since I have just the fork from an earles setup.been looking on ebay at older sportster swingarms as they are symmetrical and can be easily modified. However I've concluded nothing.
  3. Old Mule
    Old Mule Long timer
    Mar 24, 2013
    1,364
    Overland Missouri, home of 1950s sidecar tech.
    Usually rear swing arms are too long. You don't need chain adjustment, so the slots are redundant. The shock mounts might not be in the right place. Neither would caliper mounts. If you stantions are designed right, you won't need to adjust trail. A fab shop or local hot rod shop could make you a swing arm that was juuussssst right for not much money.
  4. davebig
    davebig Another Angry Hun !
    Jan 19, 2004
    9,106
    Minnesota
    Sportster swingarms
    Forged joints and heavy are what I see, since most US builders use tube within a tube for double wall construction of LL legs the finished forks are way heavier than what they are replacing easily 2x as heavy. They are hard on shocks so keeping unsprung weight down may be a value.
  5. vortexau
    vortexau Outside the Pod-bay
    Feb 18, 2008
    1,905
    Just off the Warrego, S.E. Queensland
    I have seen fork leg lowers (sliders) hollowed out and converted into Leading Links. The original axle and brakes go back into place, unless the calipers are to be anchored so as to not cause front-end rise under braking. It may be possible to use a heavy-duty fork brace as the "U-bend" section of the build, but some reinforcing may be required as a normal Fork Brace was not designed for this sort of loads.
    Here's a pic (lower leg with fork brace) to start the mind working :
    Pigeon and Hookalatch like this.
  6. Pigeon
    Apr 30, 2007
    364
    taos new mexico
    WELL... That opens up a slew of possible scenarios
  7. claude
    claude Sidecar Jockey
    Mar 17, 2002
    5,756
    Middleburg, Pa. (Snyder County)
    Build it stout. VERY important. ,......................................................................................................................................................................[​IMG]
    BWeber, Pigeon, davebig and 1 other person like this.
  8. Bobmws
    Bobmws Curmudgeon At Large
    Jun 6, 2005
    3,109
    Same trailer, different park, FL
    ^^^ I guess the low seat option wasn't low enough! :dunno
    #8
    FR700 likes this.
  9. FR700
    FR700 Heckler ™©®℗
    May 4, 2007
    15,789
    Your imagination.
    Ask AL‐58, it's his old K'.
    #9
  10. Bobmws
    Jun 6, 2005
    3,109
    AL-58 what was the cause of the failure?
    #10
  11. mantree
    Oct 17, 2012
    886
    I was planing on a lot of bracing to avoid that type of failure
    Sent from my SM-G900V using Tapatalk
    #11
  12. davebig
    Jan 19, 2004
    9,106
    Minnesota
    Did I forget to say most of the US sidecar builders use double wall tube within a tube construction on leading links
    #12
  13. mantree
    Oct 17, 2012
    886
    I was actually thinking of doing something similar to what Cleatusj did for his legs
    #13
  14. BigFatAl
    BigFatAl Long timer
    Aug 24, 2016
    1,053
    Gordon Scott did a set of leading links for his XS650 several years ago using a XS650 swing arm, ( modified of course )worked great.
    #14
    Pigeon and claude like this.
  15. claude
    Mar 17, 2002
    5,756
    btw rear swingarms includng bmw mono levers have been used to build leading link ftont ends.
    #15
    BigFatAl likes this.
  16. claude
    Mar 17, 2002
    5,756
    Actually, if I recall, he had been out or a ride and had just pulled into a place (bidy shop if I recall?) when the front end broke. Thin tubing.
    #16
  17. FR700
    FR700 Heckler ™©®℗
    May 4, 2007
    15,789
    Your imagination.
    "Thin tubing" pretty much as I recall, although, I seem to remember it happened in his own drive. Stripped it, then made one outfit of the two K's that he had.
    http://advrider.com/index.php?threads/leading-link-designs-post-pics.308801/page-8#post-10835768
    #17
    claude likes this.
  18. claude
    Mar 17, 2002
    5,756
    I used to have some close up pics of the break. The tubing was thin. Thank God it happened the way it did and not on the road.
    #18
  19. mantree
    Oct 17, 2012
    886
    My plan was to use dom tubing. I have used it in rock sliders on my trucks a lot and I have seen it used in roll cages. Then I will brace everything with 1/4 inch thick plate
    #19
  20. bk brkr baker
    bk brkr baker Long timer
    Jul 19, 2006
    8,813
    The Bluegrass
    Dom inside Dom is the ticket.
    #20
    pennswoodsed and claude like this.
