Switch issues
Discussion in 'Airheads' started by flatlandmoto, Jun 18, 2019.
  1. flatlandmoto
    flatlandmoto vigilant adventurer
    Jul 30, 2011
    247
    NE SD
    I’m stumped. New keyed switch from bobs for my 79 R65. First position tail light and parking light. Second position the tail light turns off and headlight on.
    What am I missing?
    Also. . . Does the switch itself have to be grounded to mount to work correctly?
  2. Warin
    Warin Retired
    Aug 30, 2012
    7,584
    No.
    How many positions?
    I suspect that you have
    1) every thing off - key removable
    2) parking position - tail and parking lights on - key removable?
    3) run - engine on - key fixed
    Do you have more positions? I think you have the european switch - 4 positions. The US switch should only have 2 positions... ???
  3. bmwrench
    bmwrench Long timer
    Nov 10, 2006
    6,648
    Sounds like a bad headlight relay. This relay has two 87; one for the headlight, the other for park/tail.
    Steve W. likes this.
  4. Steve W.
    Steve W. Boxer Pilot
    May 14, 2005
    738
    Upstate South Carolina
    ^^^^^What 'wrench said.... and the hl relay coil is provided - neg. from the starter solenoid circuit. This drops the relay when starting. You could have a issue with the starter or wiring causing the hl relay not to close. Find a schematic for your bike and chase through it with a test light, with the switch on, I find a test light is better in these apps than a meter due to circuit loading. Cheers
