Switched Power source 2014 R1200GSLC
Discussion in 'GS Boxers' started by McBoxer, Feb 7, 2014.
  1. McBoxer
    McBoxer Duct Tape Engineer
    Mar 7, 2012
    42
    Santa Ana
    I am looking for some specific help wiring my new Amber Rigid Industries LED Fog lights to a "SWITCHED" power source on my 2014 R1200GSLC.
    I asked my dealer to wire up my after market driving lights to a switched source.(Rigid LED SRQ DualLED Spot). They took the easy way and just wired to the battery. At the price they charge, I should have just asked this question on the forums first and saved the 200$ .
    Can anyone help me with the new CANBUS system to tap into a switched source. I know the error light will go on but I would rather pay the dealer to fix the error signal than do the electrical hookup at dealer prices.
    Thanks in advance :thumb:
  2. ShaftEd
    ShaftEd Long timer
    Nov 6, 2001
    4,188
    San Diego, CA USA
  3. McBoxer
    Mar 7, 2012
    42
    Santa Ana
    I an still trying to find a switched source to control my Rigid Industries Driving Lights & Fog Lights. I bought the ALTRider Rowe Electronics PDM60 Programmable Controller with 6 circuits so ech can be programmed differently. All i need is a swathed source that will shut down with my ignition.
    Another thread on this forum identified a red/brn wire in the harness right ehind the seat bracket that is suppose to be ignition switched. I spliced into that wire for my signal and the results are crazy. Once or twice the circuits shut sown in a few seconds which is what i want. Other times, the dam cuircuit stays live for 20 minutes.
    Does anyone really understand the logic behind these fused circuits and more importantly how I can find a simp[;e switch source for my driving and fog lights.
    Help:kboom
  4. funinthesun
    funinthesun Been here awhile
    Oct 30, 2009
    296
    so cal
    I just used the power to the power port on the dash. Spliced into the power wire to run a relay straight from the batt. Works great on my 2014 GSA. And all the wires are short as there is only the two power wires ran to batt and the wires to the lights and one short wire from power plug to relay. Does not through codes and is switched. Although it does take about 45 seconds to turn off the lights after the key is off. But I like it that way.
  5. Beecher Snipes
    Beecher Snipes Fool
    Sep 2, 2002
    877
    Mount Vernon, WA
    The double fuse box under the front seat has four wires. You can take your VOM and figure out which one but one comes on when key is turned on and goes off right away when key goes off. It is the red with thin green stripe wire. Use a posi tap not a 3M trailer tap. If you look a little further yesterday a poster referred to a nifty way to tap the green power wire in the computer connector. I like that one too. And if you really want to do it right here is an article about why you need to have a diode on your relay coil. About page 12 is the good part.
    http://www.autoshop101.com/forms/hweb2.pdf
    And some interesting stuff on GS electrics and related stuff:
    http://www.motorcycleinfo.co.uk/index.cfm?fa=contentGeneric.nvxszdkebklxuaer
    Posi taps:
    http://www.amazon.com/Posi-tap-Conn...UTF8&qid=1393196500&sr=1-1&keywords=posi+taps
  6. mefly2
    mefly2 Long timer
    Jun 28, 2010
    1,241
    Big Sky Country
    I went right to the headlight plug at the housing ...
  7. kendives
    kendives Been here awhile
    Nov 4, 2007
    467
    Virginia
    I tried using the dash plug on my '14 GSWA as a temporary power supply for my XM. I thought it would go off automatically after turning off the bike. Wrong, at least on mine. Went back out to the bike two hours later to see the XM merrily spitting out tunes with power still flowing from the dash plug.:huh Was I right to think this plug is supposed to turn off like on my '07. Or do they stay hot now?
  8. funinthesun
    Oct 30, 2009
    296
    so cal
    Well that sucks. Here I thought I was giving a great option and it won't work for everyone. My 2014 GSA shuts it off every time. Maybe not on the gs.
    #8
  9. kendives
    Nov 4, 2007
    467
    Virginia
    Mine is a 2014 Adventure. I am going to take it by the dealer and have it check it out to see if there is a setting that can be changed.
    #9
  10. funinthesun
    Oct 30, 2009
    296
    so cal
    Yep let me know I even went out and tested mine again to be sure.
    #10
  11. szazbo
    szazbo Been here awhile
    Oct 15, 2010
    233
    Which XM unit are you using?
    #11
  12. Astolfo
    Astolfo Wicked Slow
    Apr 29, 2008
    808
    The Mental Asylum
    Why would you cut into your wiring instead of using a mini fuse tap?
    I have used the posi-taps in my boat but after a couple of years I have found my wires corroded mostly, I assume, galvanic corrosion despite using dielectric grease.
    The wires I taped using the Posi-taps are inside the boat so are not exposed to the elements as much as they would in a bike.
    if you use the fuse taps which brand do you use?
    #12
  13. kendives
    Nov 4, 2007
    467
    Virginia
    Skyfi2 - Damn near indestructible
    #13
  14. mefly2
    mefly2 Long timer
    Jun 28, 2010
    1,241
    Big Sky Country
    My experience as well - tried to share that here, but it seems most of this forum is in love with the P-taps. I am sure that the particular environmental exposure factors into the result ... mileage, rain, snow, ice, ambient temperature, location of the tap, degree to which the insulation was pierced and filled by the point as well as the current load seen by the tap. It is hard for me to understand the need to expedite the electrical mod / installations on $20k+ machines ... if any of the quick taps available were meant for long term use, why would the factories go to the expense and engineering to design and implement the various circuit connectors when they could just "tap" into the required circuit for factory installed accessories? Trading speed of install or "ease of changing the mod" for long term reliability is hard for me to understand. However, if you trade your ride frequently or don't actually ride a lot, the point may be moot for the initial installer.
    Puncture the insulation on (a piece of) similar wire with a pin ... hang it under your vehicle bumper for a few months and then cut near the piercing or peel the insulation back. It would be rare in all but the driest of states to not see noticeable corrosion if you were to cut it open ... at least around here. That as been my experience as well as that of several local service techs. To each his own; YMMV.
    #14
  15. szazbo
    Oct 15, 2010
    233
    Well Said! Totally agree. No manufacturer of any vehicle or watercraft will use these or include them with any factory accessories for a reason.
    #15
  16. funinthesun
    Oct 30, 2009
    296
    so cal
    I did electrical work on high end cars for over 10 years. The only way I've had hold up is solder and seal.
    Strip, solder together and cover with a weatherproof wrap of choice. I like a silicone dielectric and heat shrink. Nothing else seems to last in harsh conditions.
    #16
  17. Beairmo
    Beairmo Keeping it real Supporter
    Jul 14, 2012
    434
    Indianapolis, IN
    Bringing this back up again.
    I am a little confused. On my 2013 F800GS there is a factory wired plug that is switched. I used it to plug in my Garmin 665. It is under the top plastic near the battery but definitely part of the factory wiring.
    Did they not do the same for the R1200GS? I have searched the internet looking for a thread that might describe where this is hiding. Looking to wire a switched permanent power line to my second GPS, SPOT, and tank bag. Don't need a lot of watts but really want it switched.
    #17
  18. JimVonBaden
    Feb 11, 2005
    96,322
    Alexandria, VA
    Just tap the mini-fuseblock!
    #18
  19. Beairmo
    Jul 14, 2012
    434
    Indianapolis, IN
    I think I will just add the PDM60.
    #19
