TAT-Clayton, NM to Paradise Valley, NV
Discussion in 'Ride Reports - Epic Rides' started by PYG RYDR, Aug 15, 2014.
  1. PYG RYDR
    PYG RYDR Adventure-Dual Sport
    Sep 26, 2010
    595
    Southern VA
    Our plan is to start our ride Sunday, August 31 in Clayton, NM and ride 8 days on the TransAmericaTrail west to Paradise Valley, NV. Then return to Clayton on paved roads.
    For this adventure we decided not to camp and have reservations for each night to sleep in a bed! :clap
    My name is Galen, the PYG RYDR and I am riding my 2002 Honda XR650L.
    My 2 riding buddies can chime in with their introductions and more details! :deal
  2. thump!
    thump! Adventurer
    Jan 16, 2007
    4,577
    Northeast Tennessee
    Me two!!!! My real world name is Jim and I'll be on a DR650.
    This will be TAT adventure #2 for us. We rode from TN to NM in 2010. Pictures from TAT#1 are here.
    I am SO ready!!!!!
  3. pfestus1
    pfestus1 Slash 5er
    Dec 4, 2001
    679
    Roanoke , Virginia
    Wow, should be an epic ride! I'm looking forward to following you guys. Wishing you all a safe and fun time!
  4. i4bikes
    i4bikes Been here awhile
    Apr 16, 2007
    563
    I'm in. :ear
  5. mapuda
    mapuda Crash Tested
    Apr 12, 2007
    339
    Las Vegas, NV
    Subscribed :lurk
  6. NVTS
    NVTS Are you ennen oh eff tee Supporter
    May 18, 2006
    1,135
    Big Lick Virginia
    Back in 2010 I ran the TAT from Tellico Plains to the OK-NM border, solo. The pic below denotes where my trip ended, precisely on the border.
    A clogged fuel filter led to a two day stress fest with a detour through Colorado Springs before heading back home.
    When Pyg Ryder told me they were going to run the TAT again starting in Clayton, NM I got the green light from Mrs. NVTS.:D.
    This time I'll be on the ugliest KTM Adventure in history, so away we three go, headed for "BIG FUN".
  7. thump!
    thump! Adventurer
    Jan 16, 2007
    4,577
    Northeast Tennessee
    My ride:
    This DR650 is the second one I've owned and has about 24,000 miles on it. It is a sturdy, durable and reliable MULE well suited for this kind of adventure IMO. The engine and exhaust are completely stock. The OEM BST40 carb has been retrofitted with an Euro-spec adjustable fuel needle and extended fuel mixture screw. It's certainly no rocketship but it will comfortably cruise at 75 and tops out around 100. That's fast enough for me and it provides tractor-like torque for thumping along on two tracks and trails with 200 pounds of me and 60 or 70 pounds of gear on board. In my previous experience the OEM carb fueled reliably from sea level to 13K feet without requiring jet changes. I am using an IMS 4.9 gallon tank and with the stock carb I can count on 50+ mpg (usually 55-60) so I have a range of at least 250 miles which is important for riding in the remote sections of western states. My seat is from Renasco Racing and I have found it to be good for repetitive all day riding. The rear shock is a custom built Cogent Dynamics unit with a higher rate spring. The forks have been retrofitted with Ricor Intiminators (drop-in cartridge emulators) and straight rate springs. I also have Ricor Vibranators in the Renthal bars. There are lots of other minor farkles but that's the big stuff. I'll run 14/42 gearing outbound on the TAT and 15/42 (stock) for the return on pavement. For safety I prefer soft luggage when dual sporting so I use the large Dirtbagz on custom built bag racks, a 30 liter roll-top dry sack on the Suzuki luggage rack and a small Wolfman Expedition water proof tankbag.
    Preparation:
    Oil change, valve adjustment, fresh NGK plugs, cleaned and oiled the TwinAir primary filter and secondary BST filter.
    Fresh brake pads and DOT4 fluid front and rear
    Grease swingarm bearings (has zerks)
    New tires - front: IRC TR8 rear: Duro HF904
    General end-to-end check of fasteners, fittings and components
    Spares and Repairs:
    A breakdown "out there" can be serious. In addition to my tools I carry front and rear inner tubes, patch kit and pump, clutch and throttle cables, clutch and brake levers, shift lever, ignition pickup, wheel bearings, fuses, a selection of carburetor jets, a small selection of metric fasteners, a siphon hose, a tow strap, oil, JB Weld, Loctite, Gorilla tape, steel wire and twine. I run a full-time voltmeter on the bike and carry a small multi-meter. I also carry an emergency "space" blanket and lightweight tarp just in case.
    Electronic Aids:
    When we rode the eastern part of the TAT in 2010 one of our crew laboriously converted the paper roll charts into a hand-drawn GPS track (in Mapsource) which was vastly better. So, this time instead of paper route sheets we will be following Sam's GPS track. Galen is our "leader" in this regard. All of us have GPS receivers (I carry two), a SPOT GPS locator/tracker and a smartphone (2 different carriers). There will be one netbook for route/track management. In addition to random photographs there will be one GoPro camera (helmet or handlebar mounted) and one retired Android phone running MobileWebCam programmed to automatically shoot a picture of whatever it sees every 5 minutes or so. Should be interesting.
    Nine days to departure. Oh yeah, I'm ready.
  8. JIMsDAUGHTER
    JIMsDAUGHTER n00b
    Aug 20, 2014
    1
    Go Dad! :freaky
    #8
  9. thump!
    thump! Adventurer
    Jan 16, 2007
    4,577
    Northeast Tennessee
    Alright now, I have a posse!
    #9
  10. Rusty Rocket
    Rusty Rocket Life behind "Bars"
    Dec 22, 2005
    14,810
    Tri- Cities TN
    subscribed.
    how old is everyone?
    #10
  11. dirtymartini
    dirtymartini Shaken, Not Stirred
    Aug 20, 2004
    2,693
    Harveys Lake, PA
    Subscribing...
    #11
  12. thump!
    thump! Adventurer
    Jan 16, 2007
    4,577
    Northeast Tennessee
    I'm the oldest. I'll admit to 68.
    #12
  13. joefromsf
    joefromsf Dark Happens Supporter
    Apr 28, 2005
    1,931
    San Francisco
    I thought that was a lot a space allocated for spare parts, until I saw Post #1 which mentioned you were moteling it every night, so a lot less gear than the folks that plan on a lot of camping.
    Good luck from a fellow DR rider, and hope you make it further than I did (Eagle Canyon in Utah).
    And with this post I am now subscribed. :lurk
    #13
  14. fanatic291
    fanatic291 Desert Tortoise
    Mar 5, 2013
    1,125
    Mesa, by Usery
    Subscribed. Good luck on your trip.
    #14
  15. atomikchicken
    atomikchicken Miles Matter
    Oct 28, 2013
    9
    Sky Islands of South East Arizona
    I hope you would be so kind as to chronicle what works and does not in you kits and on your bikes. I am a decades long daily motorcycle rider and avid backpacker. With the DR650 now in my shop I am looking to combine the two activities.
    Subscribed and waiting for the trip reports.
    #15
  16. thump!
    thump! Adventurer
    Jan 16, 2007
    4,577
    Northeast Tennessee
    My "kit" has evolved over several years of multi-week adventure trips. I know the bike and luggage work for me. And at one time or another someone in our group has needed every spare or repair item listed except the ignition pickup (which I included because of failure reports here). Those are mostly machine-specific components (not readily available) that wear out or get broken in a minor crash and they are things you usually can't go on without. After investing a chunk of money and time to get there you really don't want to be grounded by a failed or broken $50 part.
    #16
  17. thump!
    thump! Adventurer
    Jan 16, 2007
    4,577
    Northeast Tennessee
    Camping requires hauling a LOT more gear and consumables plus about 2 hours per day of setup and breakdown. Not to mention dealing with weather issues. Fortunately we were able to find lodging (motel, B&B, "dude" ranch) at convenient intervals.
    I've camped. I prefer a bed, a roof and walls and HVAC.
    #17
  18. psmcd
    psmcd Long timer
    Aug 27, 2012
    1,493
    foot of Olympus
    :lurk
    #18
  19. PYG RYDR
    Sep 26, 2010
    595
    Southern VA
    I am in the middle-earned 60 last month! :D
    #19
  20. NVTS
    May 18, 2006
    1,135
    Big Lick Virginia
    38 greenhorn?:lol3
    #20
