Tenere 700 suspension info
Discussion in 'Japanese polycylindered adventure bikes' started by Motociclo, May 30, 2020.
  1. Denis7
    Denis7 Adventurer
    Oct 4, 2019
    10
    Slovenija
    Cheers, finally some suspension talk.
    Have a 2019, 15.5k km's on the clock.
    Got redirected here from tenere700 forum and thankfully, already subscribed here.x
    Around 80kg rider, first went for the 8.5 k tech spring, which I now swapped with 8 kg, zero preload, as like topic owner said, it is 245mm long so already has plenty preload when installed.
    my yt video.
    While making multiple purchases of various springs, I have an unused k tech 9 kg, brand new, never mounted spring available if someone interested, misorder.
    Also got a 50€ k tech shock kit installed, valve + both stacks, which is "compatible" with springs 8 - 9.5kg. Oil used was kyb k2c, basicly 2.5W shock oil.
    Stock N pressure was 6.5 bar, k tech data opted for 10 bar, so filled with 10.
    Currently doing forks, thanks for first topic info, will try that route with 17's.
    Have 5mm preload spacers installed.
    About fork oil...workshop manual (it exists) calls for 10W oil..the kyb G10, so stock valving, no matter how off it is, is based around tennish.
    K tech shock stacks are dual stage with a little less turbulent passage entries on valve, but actual holes "seem" the same.
    #61
    powder85, TimmyTheHog and Benduro like this.
  2. powder85
    powder85 Been here awhile
    Feb 22, 2019
    170
    Barcelona
    The Boano kit with 48mm CC Sachs forks is still in development. The one you link is just a basic Andreani cartridge.
    You could race a T7 and be competitive if you do a front fork swap and rear shock. The Rally Raid shock is top notch but the front fork will still be 43mm.
    #62
    Cruz likes this.
  3. ktmmitch
    ktmmitch Long timer
    Sep 29, 2009
    1,699
    uk
    The Open Cartridge & Closed Cartridge fork kits from Rally Raid use a class-leading 35mm piston, which gives a 270% increase in area over the OEM, and Adreani, 20mm piston.
    #63
  4. dzrtracin
    dzrtracin возьми
    Sep 28, 2004
    4,248
    the garage
    Has anyone here installed the Rally Raid suspension products on there bike? Front & rear?
    #64
    dirtytroll likes this.
  5. Johnnyboxer
    Johnnyboxer Long timer
    Oct 23, 2003
    1,404
    Yorkshire, UK
    Top work
    #65
  6. Johnnyboxer
    Oct 23, 2003
    1,404
    Yorkshire, UK
    Rode mine yesterday
    Front suspension on the road is crap
    #66
  7. Denis7
    Denis7 Adventurer
    Oct 4, 2019
    10
    Slovenija
    Just update for topic owner.
    Rebound,
    16x0.10,(4)
    10x0.10
    16x0.10,(2)
    14x0.10
    12x0.10
    10x0.10
    8x0.10
    Stock setting written in post #1 is not correct.
    One of two 2nd stage 16's is from the slow speed so it resembles compression arrangement.
    Correct stock rebound stack confirmed in both legs is:
    16x0.10,(5)
    10x0.10
    16x0.10
    14x0.10
    12x0.10
    10x0.10
    8x0.10
    #67
    powder85 and BygDaddee like this.
  8. Motociclo
    Motociclo Long timer
    May 18, 2017
    1,129
    Thanks. Typos i never rechecked.
    #68
    BygDaddee likes this.
  9. BygDaddee
    BygDaddee Where do I get a pie
    Oct 26, 2012
    11,668
    Brisbane Northside, OZ
    can shims weaken over time from all the flexing ?
    #69
  10. gone2seed
    gone2seed Been here awhile
    Jan 4, 2020
    141
    Upstate NY
    they will but unless you are doing supercross style jumping, cross country riding at a pro level,day after day, it is more likely that seal material, bushing material or crap will get stuck between them and harm damping .
    Fork oil does not brake down and get thinner ,it accumulates crap and increases in viscosity.
    #70
    Dirtnadvil and Benduro like this.
  11. BygDaddee
    Oct 26, 2012
    11,668
    So thats a yes to the question ?
    #71
  12. gone2seed
    Jan 4, 2020
    141
    Upstate NY
    Maybe?
    If your suspension guy, or gal, doesn’t look like he is performing surgery when taking forks or shocks apart , I would suggest finding another shop.
    When I work on my own stuff, I clean off the work bench, lay out one of grandmas clean towels and go for it.
    If you tell her where the towels are going,I will denie it.
    #72
    Benduro likes this.
  13. twinrider
    twinrider Pass the catnip
    Aug 20, 2002
    17,768
    日本
    Pro offroad racer and Dakar podium finisher Jimmy Lewis gives his opinion on the suspension after riding it 1,000 miles. :augie
    #73
  14. Denis7
    Denis7 Adventurer
    Oct 4, 2019
    10
    Slovenija
    Motociclo, I ve assembled your stacks, not yet mounted on the bike.
    Used 70-90 kg shim setting, stock spring, 5mm extra spring preload, 5W castrol synth oil, 90mm air gap..to give you full roundup.
    Reb and comp screws completely unwound.
    To my eye, rebound seems a bit too slow, mind this is the fastest click position.
    What was you initial feeling when floor compressing the 105 kg guy fork?
    #74
    Benduro likes this.
  15. powder85
    Feb 22, 2019
    170
    Barcelona
    Does anyone know if Ohlins is planing on a full fork for the T7 like it has for the Africa Twin?
    #75
  16. Bike Guy
    Bike Guy Long timer
    May 20, 2005
    1,188
    sierra foothills, hwy 49
    Would anyone have a recommendation for the oil/air gap dimension? Changing fork springs, collapsed, no springs, and with 5wt oil?, if I knew what I was doing and would also reshim the stacks. Hope the info helps abit
    Open to any insight
    #76
  17. Nostop
    Nostop Been here awhile
    Aug 25, 2012
    267
    GBR
    Are you planning on doing anything to improve it?
    #77
  18. amboss87
    amboss87 Been here awhile
    Oct 27, 2018
    257
    Lower Bavaria
    For those who changed to a 90N linear spring in the Back, what are your compression and rebound setting experiences?
    #78
  19. ktmmitch
    ktmmitch Long timer
    Sep 29, 2009
    1,699
    uk
    Generally, go up 3-4 clicks compression, 4-6 extra rebound over stock settings
    #79
    amboss87 likes this.
  20. powder85
    Feb 22, 2019
    170
    Barcelona
    @ktmmitch any news on the OC cartridges you are developing?
    #80
