Tewster's 2018 Mercedes Sprinter Adventure Van Build
Discussion in 'Shiny Things' started by Tewster2, Aug 26, 2018.
  1. Tewster2
    Tewster2 Long timer Supporter
    Jun 17, 2011
    7,791
    DeLand Flatistan
    In my travels to and from the American Southwest and Alaska over the years I've longed to just be able to stop anytime I wanted at a beautiful sight for the night then move on...I've longed to be able to go someplace, spend a few weeks riding around the area without having to find a campground, a cheap motel, or mooch off friends.
    So...during my last ride up to Alaska this summer I decided to build another bike primarily for touring...and...build me a tiny house to live in for the next few years.
    Here's my new 2018 170 inch wheelbase hightop turbo diesel Mercedes Sprinter Van...got 31 miles on her so far :-)...she's got all the goodies...just like me.
    I'll be doing all the conversion work with the exception of the cabinetry...my sister works for a custom cabinet maker so they'll make it real purdy.
    Let's get started...
    pceire32, Daveham, SKT and 29 others like this.
  2. slimy
    slimy Wanabe Adventurer
    Nov 22, 2006
    310
    Flatland Florida
    IN :thumb :lurk
  3. teamkabob
    teamkabob Adventurer
    Oct 14, 2016
    43
    Motovan! Lurk
  4. Stubanger
    Stubanger Adventurer
    Dec 11, 2012
    47
    South Australia
    This is going to be more awesome than that van is big! :lurk
  5. Dexmeister
    Dexmeister Been here awhile
    Jan 21, 2017
    110
    Denmark
    And now you can bring momma along too..
    Tewster2 likes this.
  6. PA Dewayne
    PA Dewayne Adventurer Supporter
    Jul 12, 2016
    87
    SW PA
    IN
  7. Maggot12
    Maggot12 U'mmmm yeaah!!
    Feb 21, 2010
    20,485
    Canada's ocean playground
    Awesome stuff..
    I yearn for the same, but not quit yet in a position yet to jump in. I've watched dozens of build vids on utube, but when it comes time I'll likely buy an already purpose built rv with plumbing...
  8. DakarNick
    DakarNick Swabee
    Oct 14, 2005
    9,589
    Colorado
    Awesome. I was debating a Sprinter but I've decided to go a different route.
    I look forward to your build!
    #8
  9. 51%
    51% ReadyToRide
    Nov 17, 2011
    543
    Somewhere in North America. Probably.
    Lead on!
    #9
  10. ktjim
    ktjim longtime n00b Supporter
    Aug 16, 2004
    190
    so. maine
    In!!
    #10
  11. Bad Dad
    Bad Dad Been here awhile
    Apr 30, 2007
    969
    On board! This is in my near future!
    #11
  12. DPgoodness
    DPgoodness n00b
    May 18, 2018
    5
    Houston
    I have a few simple questions on your layout plans. Fixed bed or fold up bed? Toilet? Shower? Or are you going more simple? Are you planning solar at all? Looking forward to following you!
    Sent from my iPad using Tapatalk
    #12
  13. Kyron
    Kyron Oncler Inds
    Jun 11, 2007
    1,172
    Phoenix Arizona ATR > Pacifica Ca PMA
    Done yet?
    #13
  14. Bigbob1
    Bigbob1 Rain Rider Supporter
    Sep 20, 2009
    1,070
    Juneau Alaska
    This is going to be good!
    #14
  15. XpressCS
    XpressCS Must. Have. Lumens..
    May 22, 2012
    2,036
    Tucson, AZ
    Also IN. I've got my eyeball on this exact model (is it a 4x4?), and intend on doing the same.
    #15
  16. Tewster2
    Jun 17, 2011
    7,791
    DeLand Flatistan
    I'll be posting the floorpan I'm thinking about soon....200watt/400 amp hour solar system...composting toilet but no shower as places to shower are everywhere...custom cabinetry...full sized bed...120 volt shore power also...roof A/C...I expect the build to cost around $12,000...hopefully
    4x2
    #16
    pceire32, djroszina and DPgoodness like this.
  17. Tewster2
    Jun 17, 2011
    7,791
    DeLand Flatistan
    Using the flooring that came with the thing as a base...took out all the tied downs and filled the bolt holes with silicone...made floor battens with 3/4"x2 inch strips....screwed them to the OEM base...will cut 3/4 inch thick R-5 solid polyiso insulation and fit it between the battens...then seal everything with 2 inch foil A/C tape over the battens and polyiso to create a floor vapor barrier...I'll tie the walls and ceiling into the flooring to create a complete vapor barrier as I go along.
    Battens done today...insulate and seal tomorrow...it's hot in FL and I need a nap.
    #17
    Passim, BillUA, Brucester and 6 others like this.
  18. Dexmeister
    Jan 21, 2017
    110
    Denmark
    Told you.... proper job.
    #18
  19. gonefirefighting
    gonefirefighting Surrounded by Police
    Apr 28, 2009
    494
    Seesterz, Orygun
    couple things to note after doing 3 of these myself for friends, do not skimp on insulation and wiring. use the best insulation you can find and as much of it as you can stuff through the rig. It will make a huge difference in either climate. Run your wiring and plumbing through some sort of conduit. solder and shrink wrap all of your connections and use pex for plumbing. it makes it a ton easier to troubleshoot and replace (or modify) down the road as the constant vibrations and movement of the chassis will eventually cause issues to wiring and plumbing. On my last build, I elevated everything about an inch off the floor and opted for a one-piece rubber floor that can be removed and washed. It also insulated the floor much better and was easier to clean and maintain than the standard pergo/laminate flooring trend. Wire your electricity source for a Honda type 3000 watt generator on a 50 amp service option as most rooftop AC units will need at least 50 amp and the generator is simple and easy to use and all places can work on them, this is a must if you are planning on frequenting high temp parts of the country. Wherever you decide to mount your battery bank make sure it is easily accessible and large enough to accommodate at least twice the batteries you need in case of failures and mods upgrades down the road. If I think of any other tips I will chime in now that I am subbed.
    #19
    MarkC, PappaBear, Baccadon and 6 others like this.
  20. Tewster2
    Jun 17, 2011
    7,791
    DeLand Flatistan
    Stuff arriving today...I love Amazon...I've decided to use 2, 100 watt Renogy Solar panels with their charge controller and 4, 100 amp hour AGM batteries. Will use a 2000 watt Pure Sign Inverter to power all the 120 volt stuff when I'm off the grid.
    #20
