TFT retrofit
Discussion in 'GS Boxers' started by Gone Troppo, Mar 21, 2018.
  1. Max72
    Max72 Been here awhile
    Jun 8, 2019
    140
    Italia
    Which esys version are you using ?
    Which i-step are your psdzdata?
  2. Max72
    Jun 8, 2019
    140
    Italia
    Are you using icom dcan in round obd or a enet interface on new obd 16 pin?
  3. Jose_JN
    Jose_JN n00b
    Jun 21, 2020
    6
    Spain
    E-SYS 3.27.1 Plus 2.8
    Psdzdata v.4.23.21
    How can I check the i-step of the PSDZDATA?
  4. Max72
    Jun 8, 2019
    140
    Italia
    For ESYS :
    Psdzdata 4.23.21 should be good.
    Esys 3.28 i am not sure , but seems too old....i am using esys 3.34.
    For VIN you have send me:
    There isn’t 6AB in FA. If you have certainly that bike have TFT , this mean that 6AB is not good for TFT.
    Please try to remove 6AB from modified FA and add 6AE + 6AC just for verify if is accepted to generate FP.
    For 1200RS tft is only in combination with 6AE and 6AC that are respectively TELESERVICE and INTELLIGENT SOS CALL , and this mean that K54 R1200RS have also telematic box. The trick should be to encode tft with this two option and successively disable emergency call and teleservice coding manually the tft.
    In any case send me original FA , SVT , FP and all CAFD OF bike.
    My mail is in your PM .
  5. Mladen72
    Mladen72 n00b
    May 18, 2020
    4
    Serbia
    Hi Max,
    Im also new to this forum , like you Im most in retrofit in the car (vw-audi, and for some bmw,!
    I have R1200GS, 2014 and also like to try retrofit TFT and some other stuff!
    I try to contact you via pm but without any luck
    Have you manage to solve engine light problem on your bike?
    Regards from Serbia,
    Mladen
  6. Lead Wrist
    Lead Wrist Mehr Gelände Weniger Straße
    May 26, 2007
    13,630
    Zer0-Zer0-Zer0-Zer0
    Or, you two can get together somewhere half way btw Italy and Serbia, say on the coast of Adriatic sea, take care of retrofit business, and then enjoy the ride along side the coast... :D
    Welcome aboard and to the asylum btw...:-)
    Mladen72 likes this.
  7. DocPFFP
    DocPFFP Fat kid on a little bike...
    Jul 27, 2019
    206
    Maryland
    I'm legit waiting for something that is a plug/play for the 2013-2018's GPS prep. I mean, if the Garmin sled is putting out all the codes and WonderLync has figured out the interface for a phone on middleware, a rugged 7" touchscreen with Android Auto and the same middleware natively doesn't seem to be a far cry ask.
  8. redCattledog
    redCattledog Adventurer
    Jul 11, 2018
    49
    Seacoast NH
    I use a Wunderlinq on my 2018 TFT r1200gs. Better functionality that the TFT, just not as pretty graphics. My music doesn't skip, phone calls are a non issue, and Google Assistant works correctly. Also no stupid special syncing order for the equipment. It functions the way BMW should have... $250, best purchase yet for the bike.
    regnock and scottdc like this.
  9. DocPFFP
    Jul 27, 2019
    206
    Maryland
    I tried on on my 2015 R1200R with a Galaxy S7, and just didn't like it. Laggy, app kept crashing, etc... I really, really, really wanted it to be awesome. But it didn't do well for me. I don't care as much about the wheel, more about protecting my phone and getting away from a "special gloves" touchscreen.
  10. redCattledog
    Jul 11, 2018
    49
    Seacoast NH
    What version of the firmware and software were you using? They are updating it every few months or so. Never had an issue with lag or function.
  11. DocPFFP
    Jul 27, 2019
    206
    Maryland
    None. I sold it about 5 months ago because I didn't like it.
  12. regnock
    regnock WunderLINQ Developer
    Jan 24, 2010
    313
    Colorado Springs
    @Max72 Thanks for all your hard work on this. I'm awaiting the parts to attempt the retrofit on my 2017.5 1200GS. I'll post my results to the group.
    Dave Young likes this.
  13. regnock
    Jan 24, 2010
    313
    Colorado Springs
    Has anyone identified the mechanical pins used in the OBD port on the newer bikes? I'd like to populate the empty pins with the ethernet wires from the TFT cluster.
  14. ealcazar
    ealcazar Adventurer
    Apr 6, 2020
    11
    Albacete, Spain
    From the page 4 of the thread (thanks @Max72):
    This is TFT pinout
    PIN 1 = 30F1 (alimentazione)
    PIN 2 = CAN_H (canbus alta)
    PIN 3 = CAN_L (canbus bassa)
    PIN 4 = 31 (terra)​
    PIN 5 = K_RX - (ricezione ethernet meno)
    PIN 6 = K_RX + (ricezione ethernet plus)
    PIN 7 = WL_S
    PIN 8 = KS_LIN (bus Lin)
    PIN 9 = SZ_LIN (bus Lin)​
    PIN 10 = K_ACTIV (attivazione di ethernet)
    PIN 11 = K_TX - (ethernet tranmission meno)
    PIN 12 = K_TX + (ethernet tranmission plus)
    Missing the mapping from the OBD...
    Best regards
  15. regnock
    Jan 24, 2010
    313
    Colorado Springs
    Hi @ealcazar
    I'm actually looking for the physical OBD pin part numbers, I would like to wire the Ethernet lines into my existing OBD port's empty pins.
    I just ordered the following TE parts to test as the connector is a TE part, I'll report back with my findings.
    776001-1
    1123721-1
    UPDATE
    These two didn't work, TE 929027-1 however fits and looks near identical. :)
  16. regnock
    Jan 24, 2010
    313
    Colorado Springs
    @Max72 and group. I've successfully retrofitted the TFT to my 2017.5 GS. Everything works perfectly with the TFT.
    The only outstanding issue I have at the moment is a GM fault for the LED headlight. The fault I get is: "S2006 GM: Group fault, LED headlight control unit communication interrupted." ISTA+ diag indicates the GM indicates the LED headlight is not the right version.
    I'm not sure if I did something incorrectly while coding/updating the GM module?
    Does anyone have any ideas on what I may have done wrong?
  17. Max72
    Jun 8, 2019
    140
    Italia
    Control unit communication interrupted mean that canbus is not communicating with module. Have you encoded all ecu with 6AB FA? Have you perform a scan with ista or others? GM is red or yellow in control unit tree?
    regnock likes this.
  18. regnock
    Jan 24, 2010
    313
    Colorado Springs
    @Max72 Thanks for responding. Everything is Green in ISTA accept the GM shows as yellow with just this one fault. I'm using ISTA+ to read this fault.
    I changed my FA according to your previous post and applied by highlighting each ECU and clicking the "Code" button. Each ECU coded the FA successfully but errored on apply the FP, not sure if that is normal. Here is the message from coding the BCO:
    Caf's suchen
    Tal wird generiert
    Abarbeitung wird gestartet
    Read SVT before TAL execution started.
    Read SVT before TAL execution finished.
    ExecutionID=2020/08/21-06:49:05.845[] prepareTALExecution started [PROGRESS]
    [] prepareTALExecution finished [PROGRESS]
    [] prepareVehicleForCoding started [PROGRESS]
    [] prepareVehicleForCoding finished [PROGRESS]
    [X_BCO - 72] prepareECUforCoding started [PROGRESS]
    [X_BCO - 72] prepareECUforCoding finished [PROGRESS]
    [X_BCO - 72] authenticateECUforCoding started [PROGRESS]
    [X_BCO - 72] authenticateECUforCoding finished [PROGRESS]
    [X_BCO - 72 - cafd_00002a57-012_001_030] Transaction type: cdDeploy; Message: TA started [TRANSACTION]
    [X_BCO - 72 - cafd_00002a57-012_001_030] Transaction type: cdDeploy; Message: TA finished [TRANSACTION]
    [X_BCO - 72] finalizeECUCoding started [PROGRESS]
    [X_BCO - 72] finalizeECUCoding finished [PROGRESS]
    [] finalizeVehicleCoding started [PROGRESS]
    [] finalizeVehicleCoding finished [PROGRESS]
    [] finalizeTALExecution started [PROGRESS]
    [] finalizeTALExecution finished [PROGRESS]
    TAL execution finished [TAL_EXECUTION_FINISHED]
    TAL-Execution finished with status: "Finished". [C207]
    TAL execution finished. Duration: "13s". [C206]
    Read SVT after TAL execution started.
    Read SVT after TAL execution finished.
    MSM update: Read current SVT. [C194]
    MSM update started. [C215]
    [] There was an error, please check the log files. [WARN]MSM update finished with error. [C217]
    Error in MSM Update:
    Error during MSM update. [C214]
    could not retrieve ECUIdentifier for SystemFunction MSM_D_CAN [1929]
    VCM Update: Write FA to VCM. [C188][] - [Exception - UNKNOWN] could not retrieve ECUIden
    VCM Update: Write FP to VCM. [C190]
    MCDDiagService<id=256649, job=com.bmw.psdz.jobs.uds.vcm.MCD3_WriteFPtoVCM, service=WDBI_FP_VCM - WriteDataByIdentifier FP, description=error: negative response : requestOutOfRange, link=VCM_D_CAN> [DIAGSERVICE]VCM Update: finished with error. [C196]
    Error in VCM Update:
    [] - [Exception - VCM - 12] job failed with negative response error:
    code: service returned global negative response
    description: Service WDBI_FP_VCM returned a negative response with response code requestOutOfRange; LinkName: VCM_D_CAN
    severity: ERROR
    Write FP failed! [C063]
    severity: ERROR
    [433]
    Abarbeitung beendet
    The only other thing I notice is that any time I try to calculate a software update in ISTA, it wants me to remove the KOMB.
  19. luca9277
    luca9277 Been here awhile
    Feb 25, 2012
    350
    Singapore
    This guy id having a fund raise for a TFT unit for the OC models, I am hoping he'd look at the LC ones as well..
  20. Max72
    Jun 8, 2019
    140
    Italia
    Ok, try this:
    Before encoding BCO , deactivate VCM and MSM update.... bike haven’t they.
    On esys menu’ hit OPTIONS >>>>
    Then again OPTION>>>>>
    Deactivate update VCM and MSM after TAL execution. ( remove the two flags), and then encode BCO.
    regnock likes this.
