That's not a pillion box, THIS is .... ;-)
Discussion in 'GS Boxers' started by MirthfulThylacinator, Oct 11, 2019.
  1. MirthfulThylacinator
    MirthfulThylacinator Tinker
    Feb 21, 2018
    538
    Tassie
    ... so, the support struts for the old light-duty topbox cracked & broke during last trip through Tassie's offroads around Fingal. I thought surely there could be a better way to utilize that empty pillion space? ebay and moto-accessory makers only offer crummy little cosmetics cases. But if I'm not going to use a topbox - makes that 2nd level carry rack superfluous, right? Off with it then. Suddenly there's all the space freed up, already designed to carry the weight of a person, so loading it up shouldn't be a problem ... hmm? Had a bit of 3mm aluminium sheet left over, cut/shaped the locators from 12mm thick bits of poly sheet to clone those thingomagics under the OEM pillion seat. Drilled & tapped & bolted on with M6 mushroom-head in-hex bolts. Now it's only a matter of swapping out the seat-locking-pin if I want to take a pillion along. Took a day to make it. Yeah, it's a bit on the big side. About 550mm long x 280mm wide x 150mm high (21.5" x 11" x 6"). But I haven't yet heard anyone complaining about too much onboard storage capacity on a bike. :-)
    Fits like a glove. Snaps into the same locator/locking pin arrangement as pillion seat. Simple removal with key. Only need to sort out thin self-adhesive foam liner for inside, and some type of varnish to stop the aluminium blackening everything on the outside ...
    Yellow Dog, mrsdnf, ER70S-2 and 12 others like this.
  2. JimVonBaden
    Feb 11, 2005
    87,895
    Alexandria, VA
    Nice work! :thumb
  3. Bikerboy108
    Bikerboy108 Pat from Jersey
    Sep 22, 2004
    4,751
    Jersey "Land of the Lane Closure"
    Coffin for when you run over a squirrel or groundhog?
    LPKA, elcabong, Oeths and 13 others like this.
  4. Reno1
    Reno1 Can't get lost if you don't know where you'er goin
    Mar 9, 2013
    47
    Very nice
    MirthfulThylacinator likes this.
  5. TUCKERS
    TUCKERS the famous james
    Dec 23, 2005
    19,640
    Villa Maria Sanitarium, Claremont, CA. USA
    I love it! Great job you did.
  6. GS Addict
    GS Addict Pepperfool Supporter
    Sep 24, 2006
    6,879
    Sunshine Coast B.C.
    Nice job!
    The coffin look may attract Harley riders tho' :evil
  7. 9mm
    9mm Been here awhile
    Apr 18, 2006
    553
    "Southeast of Disorder"
    Just in time for Halloween. Awesome job BTW.
  8. ObiJohn
    ObiJohn Screaming Banshee Supporter
    Jul 22, 2010
    1,206
    Seattle suburbia
    I would warn you to redesign your box so that it doesn't have a small point of contact closest to your spine. There's an awful lot of spinal injuries from being rear-ended while having a top box mounted. I only run with a soft large BMW tailbag for that reason.
    If it were me I'd have a rear-opening box, and have the end closest to my back have an additional section so the angle changed by 45 degrees, had an inch or two flat, then the remaining 45 degrees... and I'd pad it well.
    #8
  9. slipperyeel
    slipperyeel Been here awhile
    Sep 29, 2012
    136
    UK
    That looks great. Really useable space . But I'm a little unclear why the curve that meets the riders seat doesn't run parallel with the riders seat? I mean, you put a curve in, but chose to mirror the riders seat,?
    As for the comment from Obijohn... Yikes! I've noted that one!
    #9
  10. MirthfulThylacinator
    Feb 21, 2018
    538
    Tassie
    Obijohn, thanks for the warning - I never even thought of that. Good point. Ouch.
    Slipperyeel, the thought of matching the rider's seat curve went in the too-hard basket. Reasons: 1) the pillion seat base profile fits over that ridge where the locking pin clicks in. To match that was outside my time & skill budget, lots of extra hours for only cosmetic gain. 2) I did think along Obijohn"s comment a little bit, and wasn't keen of having 2 forward pointing prongs/corners behind my back.
    3) adding a padded backrest now moved up on my to-do-next list :-)
    #10
    ER70S-2 likes this.
  11. slipperyeel
    Sep 29, 2012
    136
    UK
    Two pointed sides... Hmmm... good point (no pun intended!). I stand corrected!
    Still a bit concerned ref Obijohns comment. I mean, just top boxes were included
    #11
  12. jbuggyus
    jbuggyus Been here awhile
    Mar 26, 2011
    502
    washington
    Just curious, is this truly an issue with top boxes? I have not heard of spinal injuries due to topboxes?
    #12
  13. ObiJohn
    Jul 22, 2010
    1,206
    Seattle suburbia
    There was a rider up here in the PNW who was rear-ended on his GS (or GSA) with a hard top box. He's a paraplegic. There was another one on the West Coast. Both of these were reported on this site (maybe in the Face Plant thread?). Think about what happens with a hard case if you're rear-ended... what is going to hit you in the back? I hadn't really considered it until I read those reports... then decided I didn't need a hard top case.
    #13
    jbuggyus likes this.
  14. TUCKERS
    Dec 23, 2005
    19,640
    Contrary to this the fact is a top box may take some force of a crash BEFORE anything hits the rider. Remember motorcycles are dangerous...safer to wrap your self in cotton balls and sit on the couch watching TV.
    #14
  15. JimVonBaden
    Feb 11, 2005
    87,895
    Alexandria, VA
    Normal top boxes? It has happened, but it is not THAT common. This box is very close to the back, but a good jacket with a quality full back protector should be OK. Also, his mounts are plastic and easily dislodged.
    :thumb
    #15
    GS Addict and jbuggyus like this.
  16. JimVonBaden
    Feb 11, 2005
    87,895
    Alexandria, VA
    There are always examples of any possible permutation. Hell, you do not need a top case to have it happen.
    #16
    slipperyeel likes this.
  17. GS Addict
    Sep 24, 2006
    6,879
    Sunshine Coast B.C.
    +1 I was just going to point out the back protector.
    #17
  18. TUCKERS
    Dec 23, 2005
    19,640
    If it’s not a top box shoved up your ass it’s a passenger seat, a six pack of beer or a load of firewood. If you have nothing there then you get the grill of a Chevy Tahoe.
    #18
  19. ObiJohn
    Jul 22, 2010
    1,206
    Seattle suburbia
    Yep, it's always something... but I'd rather it not be a permanent spinal injury. A good jacket with a spine protector helps, but take the sharp edge off and pad the crap out of it.
    #19
  20. bikeroz
    bikeroz Long timer
    Oct 18, 2012
    2,166
    Sydney Lower North Shore
    :pot
    A GS in America without hard luggage? Sacré bleu!
    I think that is too tall an order.
    Great job @MirthfulThylacinator
    #20
    JimVonBaden likes this.
