The 650 Dakar Thread
Discussion in 'Thumpers' started by underwaterguru, Mar 10, 2009.
  1. Clay-doh
    Clay-doh Been here awhile
    Oct 8, 2016
    174
    Illawarra, NSW Australia
    Probably due to the buildup of carbon within the combustion chamber. More carbon = less free space to compress the burn mixture (air/fuel) = higher measured compression.
  2. Gedrog
    Gedrog 1000 mile stare a 1000 stories to tell
    Oct 20, 2013
    2,831
    Lost in the Sahara
    Maybe the point I am trying to make is eluding you so I will try to explain again
    If you overlay the anchor points of the extension on the 1spark fender you will see it anchors between two mounting points on the lower fender
    and on top of the lower part of the 1 spark fender
    What @Don Coyote suggest is to mount it like so
    Which I suspect will look like something this.
    Now see what happens with your anchor points, and although it might weigh nothing, but longer levers needs less power to deliver higher forces right?
    And as you can see the 1 spark fender on-top of the 2 spark fender in the configuration @Don Coyote suggest there is literally no support and a massive lever
    I long distance and the front beak will crack through and snap off
    hopefully now you see what I see
    Gravel Seeker and eakins like this.
  3. eakins
    eakins Butler Maps
    May 29, 2002
    34,828
    Fort Collins, Colorado
    Thanks for the post.
    I'm still willing to try as the 2 rear mounts are in the strong sub fender...and my top fender is all rashed to hell where that Dakar would cover it.
    I'd even add a small support bracket for the center bolt connecting to the sub fender.
    If it falls off, oh well...
    Thanks for the better detail pics.
  4. wpoll
    wpoll Been here awhile
    Sep 19, 2008
    209
    South Island, New Zealand
  5. Don Coyote
    Don Coyote Long timer
    Oct 3, 2008
    3,156
    Upper Midwest, US
  6. WayneC
    WayneC Long timer
    Oct 3, 2008
    5,117
    Sydney, Australia
    Direct links to pdf's are meant to work for Advrider but intro of https has caused a problem which I will resolve, better to link to a page though
  7. djroszina
    djroszina Long timer Supporter
    Jan 30, 2006
    2,742
    Midwest
    Low fender, no thanks. 5D106658-7A73-4709-9FDB-C34E075EA36F.jpeg 1D081697-E0B1-40CA-9883-97099FBC88B4.jpeg
    The fender brace is bad enough.
    Singulano, eakins, mehoww and 2 others like this.
  8. WayneC
    WayneC Long timer
    Oct 3, 2008
    5,117
    Sydney, Australia
    Well said, there have been serious injuries with low fenders in muddy conditions here in Oz, a chopper ride out to hospital is no fun
    Gravel Seeker and djroszina like this.
  9. Don Coyote
    Oct 3, 2008
    3,156
    Upper Midwest, US
    So you already have the extension lip mounted on a 2 spark. Did you just drill holes and mount it with the included hardware? How much have you ridden with it?
    eakins likes this.
  10. Gedrog
    Oct 20, 2013
    2,831
    Lost in the Sahara
    Fully agree there I would not ride off-road with a lower fender, even the fork brace is a nightmare in the mud, I love my low fender for my daily motorway commute keeps the spray away from me and my helmet much happier.
    I like the new Tenere lower fender the mid section can be easily removed I will be waiting for the GEN 2 of the T700 but this is definitely a bike that appeals to me
    djroszina likes this.
  11. djroszina
    Jan 30, 2006
    2,742
    Midwest
    I just mounted it with supplied hardware. I have around 12 thousand miles with it installed. I also installed the metal underfender brace by Aquatic. One thing the Dakar is susceptible to is its radiators clogging on wet gravel roads from the roadspray.
    eakins likes this.
  12. mehoww
    mehoww Adventurer
    Jul 20, 2011
    26
    PL
    no low fender= no problem
    Or actually the only problem left, is to steer this heavy lump to ride to the direction you want in such a conditions :D
  13. eakins
    eakins Butler Maps
    May 29, 2002
    34,828
    Ah there is a 2 spark front fender with a 1 spark Dakar fender extension added!
    Any issues, cracking, breaking etc or is it all holding up well with off-road use?
    Got any pics of it from bottom all bolted together?
    I removed my lower fender too on my 2 spark.
    I upgraded to the Happy Trails fork brace which is less of a dirt catching shovel like the OEM. It comes with 2 sets of bolts - GS & Dakar.
  14. eakins
    eakins Butler Maps
    May 29, 2002
    34,828
    Missed this post at first, thanks.
    Still live to see a pic from below.
    So these 2 braces
    https://advrider.com/f/threads/rate...dakar-sertao-yz-wr-suspension-upgrade.952045/
  15. Don Coyote
    Oct 3, 2008
    3,156
    Upper Midwest, US
    Never noticed that brace before, thought it was for adapting other forks to the OEM fender. Why is it needed? Not seeing what it has to do with the radiator...
  16. djroszina
    Jan 30, 2006
    2,742
    Midwest
    Nothing to do with the radiator(s). Just that with the high fender and how the aerodynamics are, the roadspray containing stone dust collects and eventually blocks the radiator fins. A few times on my AK trip I had to stop and hose down the radiators softening and flushing the accumulation off of them to prevent overheating.
  17. eakins
    eakins Butler Maps
    May 29, 2002
    34,828
    I think those are both 1 spark inner fender brackets from the pictures but maybe the lower 1 spark bracket fit a 2 spark inner fender too?
  18. djroszina
    Jan 30, 2006
    2,742
    Midwest
    Hooter, Aussie speak for horn.
  19. eakins
    eakins Butler Maps
    May 29, 2002
    34,828
    So this bracket fits under the 2 spark inner front fender and strengthens the whole assy after you added the 1 spark Dakar fender extension. Is that how I understand it?
    Does that reduce the fender moving up and down and potential damage to the 2spark outer fender as Gedrog is concerned about?
  20. eakins
    eakins Butler Maps
    May 29, 2002
    34,828
    So on the 1 spark the horn is up in the inner fender? And thus a hooter brace.
