The 650 Dakar Thread
Discussion in 'Thumpers' started by underwaterguru, Mar 10, 2009.
  1. Don Coyote
    Don Coyote Long timer
    Oct 3, 2008
    3,605
    Upper Midwest, US
    Well that's like the weatherman saying we will have weather tomorrow- you have to be a little more specific for your guess to count.
    The holes went fine, the grip tube is mounted. I couldn't get the screw to self tap into the 1/8" hole, but the 4mm tap worked on it and the screws went in easy then. The two muck ups: in routing the heating wires through the left control cluster, I made a specific hole in the housing next to the grip for them to go in. If I ever want to adjust the angle of the cluster/clutch lever, I'll have to modify that whole thing. Fingers crossed it is at a good angle now...
    On the other side, I routed the wires down into the plastic of the throttle tube so they could exit into the cluster under the kill switch instead of loop around the outside like on the G. I made sure to do it in a spot with no conflict through the entire arc of rotation, but it looks like the wires want to bend back and forth at the exit point instead of making the whole wire bundle move around like I'd hoped. I'll give it a shot to see how long it works, but seems it will eventually just fray the wires there. I'll double check that I have a 4a fuse on the circuit and not 5...
    Gravel Seeker likes this.
  2. velo-hobo
    velo-hobo *_*
    Jan 13, 2018
    258
    Oakland, CA
    Also I prefer a #40 for M3 tap drill. Less likely to strip out.
  3. Don Coyote
    Oct 3, 2008
    3,605
    Upper Midwest, US
    I think when it was printed they were still on version 0.9 of the metric system or something, so it was all good back then.
    The standard table is what got me. Took me forever to realize there were two sections side by side. Competent table makers usually use the same columns and headers for various parts. Though I absolutely understand how difficult it can be to differentiate between fractions and decimals if everyone is pounding beers in the office all day...
  4. Gravel Seeker
    Gravel Seeker Old, growing older.
    Apr 27, 2002
    9,892
    Dreary old Norway, dreaming of adventures past
    I bought a simple tap & die set and that came with two thread gauges, one metric and one freedom, but the set is only to make metric threads I think (been a while since I used it now)
    This type
  5. Gravel Seeker
    Apr 27, 2002
    9,892
    He could just go up a size and buy a new screw too
    Could even go freedom :D
    If the hole is threaded a regular fine pitched screw would work the same as the stock I reckon.
  6. velo-hobo
    velo-hobo *_*
    Jan 13, 2018
    258
    Oakland, CA
    I work in a place that regularly uses both systems, sometimes mixed in the same piece of equipment. For client work a drawing might have decimal inch and metric on the same page. Then there is CAD translation. It does probably lead to more beer consumption on my part.
  7. Gravel Seeker
    Apr 27, 2002
    9,892
    A drop of cutting fluid (or just wd40) is always better.
  8. Gravel Seeker
    Apr 27, 2002
    9,892
    Like that is possible in the Divided States of Confusion in 2020 ?! :jack
    Given a choice people won't change. Just look at the pandemic. Suggest that people mask up and they won't. Command them to (like some countries have, mine not among them) and they will.
    I'm sure you know this, but you were given a choice to step into modern age in 1866, but except for US defense, you chose not to.
    2 months and 1 day from now it's 45 years since the US put into law that metric is the way to go, but people were still given the choice and we know how that works..... :fpalm
    The Metric Conversion Act is an Act of Congress that U.S. President Gerald Ford signed into law on December 23, 1975 declared the metric system "the preferred system of weights and measures for United States trade and commerce".
  9. velo-hobo
    velo-hobo *_*
    Jan 13, 2018
    258
    Oakland, CA
    yeah well we've got other things to be concerned with at the moment, i think system of weights and measures can be on the back burner. for sure it is the system used by the scientific/academic and medical world, at least.
  10. Gravel Seeker
    Apr 27, 2002
    9,892
    But those mix ups can usually be fixed at a needless and unwanted cost, right? That's not always the case..... :fpalm
    NahdarVebb and puchyyla like this.
  11. Gravel Seeker
    Apr 27, 2002
    9,892
    Of course, just putting it out there - why this is even an issue still?! Ironically, the size of all the freedom units are based off of metric anyway :lol3
    And of course, I hope you guys fare well the next few months. Looks like there are uphill struggles on all sides right now. Good luck.
  12. velo-hobo
    velo-hobo *_*
    Jan 13, 2018
    258
    Oakland, CA
    ah yes, well thankfully what i am doing is not literal rocket science.
    and then there was the matter of misumi sending 73" of linear shaft when i had ordered 73mm for wp project, so can't lose em all
    NahdarVebb and Gravel Seeker like this.
  13. Gravel Seeker
    Apr 27, 2002
    9,892
    oh yes, that was funny. Maybe not :lol3-funny, but :scratch:fpalm-funny for sure. In my early career I once shipped 175 boxes of rifle ammo to a store that ordered 175 cartridges.
  14. velo-hobo
    velo-hobo *_*
    Jan 13, 2018
    258
    Oakland, CA
    some photos then:
    Clay-doh and Gravel Seeker like this.
  15. puchyyla
    puchyyla Adventurer
    Oct 7, 2015
    62
    CZ
    Reminded me an old joke:
    There are 10 types of people. Those who understand binary and those who don't.
  16. TobyG
    TobyG SlothRacing.eu - Travel and Racing Products
    Dec 27, 2011
    1,525
    Germany
    Is that a fucking zebra?
    Surely these photos were not taken on the same ride...?
    The again, there is that curious case of a herd of hippos in Colombia...
  17. Clay-doh
    Clay-doh Been here awhile
    Oct 8, 2016
    222
    Illawarra, NSW Australia
    It's a "Zebra Crossing"...
    NahdarVebb and Don Coyote like this.
  18. TobyG
    Dec 27, 2011
    1,525
    Germany
    I had it coming, no?
    :dirtdog
    Clay-doh likes this.
  19. Sparqq
    Sparqq Been here awhile
    May 25, 2011
    437
    Amsterdam -> Hong Kong
    Let me add a photo too, after work ride to prevent myself from buying a KTM990;
    mehoww, NahdarVebb, Clay-doh and 5 others like this.
  20. velo-hobo
    velo-hobo *_*
    Jan 13, 2018
    258
    Oakland, CA
    Not only the same ride, but on the same day! It wasn't even a long day...
    There is apparently a herd of zebra and maybe some zebra hybrids on a ranch outside Petrolia. I think this one got loose, it was wandering around on the road mostly unconcerned with me or my business. I think there are also zebras down at Hearst Castle.
    I have also seen camels and unless I'm completely misremembering, giraffes on the side of the road here in California, whilst out traveling on two wheels.
