1. eNewsletter Sign Up
The Africa Twin CRF1000L Owners' Thread
Discussion in 'Japanese polycylindered adventure bikes' started by erey, Dec 20, 2015.
  1. sweetlou
    sweetlou small body, big balls
    Jun 22, 2008
    2,570
    Melville, NY
    Anyone need a Shad top case mount adaptor? Part #H0CR12ST fits 16-17 AT and the VRX. $45 shipped
  2. swimmer
    swimmer armchair asshole
    Oct 9, 2007
    16,405
    Tucson, AZ
    Thanks. I will be ordering this sometime soon. Just want to get more air to my helmet in warm weather. The OEM screen will work the other 4 months of the year.
  3. Greg the pole
    Greg the pole There are no stupid questions, only stupid people
    Mar 1, 2011
    2,125
    Calgary, AB
    no prob. Honestly, I'm far too lazy to remove it during riding season. It's fine in all applications for me.
  4. Greg the pole
    Mar 1, 2011
    2,125
    Calgary, AB
    report back.
    I went with a pcv. Far more involved as far as install, but fully transparent on what it does. Plus tunable..
    https://thetenerist.wordpress.com/2019/03/18/2017-honda-crf-1000-power-commander-v-install/
    after 10k km, i'm glad I did it.
    Wheelies...hell yes.
    Junglejeff1 likes this.
  5. swimmer
    Oct 9, 2007
    16,405
    Tucson, AZ
    Going back this this 2018+ battery replacement, it seems like the Shorai LFX14L2-BS12 might be a suitable replacement. I've sent them the spec sheet for the OEM battery made by ELllY Power so see if they think their battery is OK to use in this application.
  6. Barron
    Barron M0DAH0LIC Supporter
    Mar 24, 2006
    3,368
    Yokosuka, Japan
    What is the fastest you've had a set of tires go bad, not used up, but bad? The reason I ask is because I have a set of tourtecs on my twin that are about 8 months old. Yesterday I was riding out of my neighbor hood and the front felt soft so I stopped t get air at a gas station 1/8 of a mile from my house. As I was airing it up I noticed cracks along the rim that were deep so I stopped the air and took it home. I could feel it getting softer as I rode very slowly home. This is one of the reasons I prefer tube to tubeless. FWIW, two weeks ago the cracks weren't there and before that day the tire never lost air.
    -Barron
  7. Moshaholic2
    Moshaholic2 2017 CRF1000L Africa Twin , 2019 CRF250L
    Apr 16, 2018
    163
    Utah
    Lots of variables - what was the "date" on the tire when you got them? Were they old stock or fresh? high air temps? parked outside exposed to weather and sun?
    I've had a Michelin T63 crack in a couple months... But it was an old stock tire as it had been discontinued and was sitting for a bit.
  8. Amphib
    Amphib A mind is like a parachute....
    Sep 19, 2018
    2,882
    Wnc
    I quit buying bfgoodrich tires for my 4x4s because of this.
    I know if your bike gets parked around ozone producing things this can cause cracking.... Electrical fields, evaporating solvents.....
  9. Barron
    Mar 24, 2006
    3,368
    Yokosuka, Japan
    The bike is parked outside, no idea what the date was on them but what both of you guys says makes sense. I was just really surprised. It's been hot and there is a transformer very close (but higher) to my bike. The tires on my other bike and car cracked quickly, not to mention most of the rubber on my other bike was absolutely shot. I never put any solvents or "look pretty" stuff on my tires, but I'm going to look into it and see if there is a way to guard against the ozone thing.
    -Barron
  10. Smittyrunner
    Smittyrunner Been here awhile
    Jan 13, 2019
    153
    Orange county ca
    I have the same windscreen. It even helped my buffeting issue. I recommend it also. Plus it looks cool
    swimmer likes this.
  11. Smittyrunner
    Jan 13, 2019
    153
    Orange county ca
    Amphib likes this.
  12. Moshaholic2
    Apr 16, 2018
    163
    Utah
    PCV would be the real way to go (along with a dyno tune) ... or that place in the UK that can dyno tune and reflash the ECU.
    That would likey net the best results and likely would allow some tailoring to where you want the power gains.
    I went w/ the UpMap simply because it's an off the shelf tune for the full Termi exhaust I'm running with easy install.
    From my limited seat time today, there is no doubt a power boost through the entire rev range as advertised. Putting around, you won't notice anything different. But, pick up the pace and it is noticeable. If you rip it like a street bike it is very noticeable. Definitely added fuel as the exhaust was running cooler than before the flash (used to heat up really quickly being a touch lean)
    My bike is a 2017. So other things I may experiment with when it comes to change the air filters is dig deeper into the airbox and change out the throttle body snorkels for the longer 2018+ ones to get some more mid range pep (where I seem to ride the bike the most)
    *might* gear it down a tooth or two also.
  13. gve.mcmlxxiv
    gve.mcmlxxiv Been here awhile
    Sep 5, 2017
    326
    Arkansas
    I’ve got the antigravity 360 in my 2016.
  14. swimmer
    Oct 9, 2007
    16,405
    Tucson, AZ
    I don't see a model 360 listed. Maybe you are referring to the AG-1201? Either way, that battery won't fitand neither will the one they recommend for the AT.
    Shorai responded to my inquiry and said the battery rhat I suggested might work on the 2018+ bikes won't work and they don't have anything that will. The spec on that battery all seem adequate but they said "it's underpowered for that bike".
  15. Lost Cartographer
    Lost Cartographer Been here awhile
    Feb 7, 2011
    737
    AZ and CA
    Do you have a refrigerator in your garage?
  16. Amphib
    Sep 19, 2018
    2,882
    Wnc
    Nihon Newbie and 97707 like this.
  17. MillennialFalcon
    MillennialFalcon Improvement starts with self
    Apr 4, 2017
    838
    Rocky Mountains
    Sounds like something complicated developed specifically for regulations, not consumers/riders.
  18. Amphib
    Sep 19, 2018
    2,882
    Wnc
    Disagree...... cooler temps, more power, greater efficiency.
    Barron likes this.
  19. Greg the pole
    Mar 1, 2011
    2,125
    Calgary, AB
    A few things to note:
    -as you said, PCV gives the most flexibility, but is a pain to install
    -I do have K and N filters, and a staintune slip on only. PCV seems to have smoothed out the bike, and feels like it has more shove
    -DO NOT waste your time with Hilltop ECUs. Utter muppets. The people I dealt with (desk/email staff) couldn't get me actual numbers, a map after the tune, price etc..
    The local guy in Vancouver had no help from the mother ship (basically a franchise deal of sorts, with all the add costs, but zero support)
    -I went down one tooth on the front...didn't really like it. Speedo and odo error went up considerably. Yes it was snappier, but rev'd too high on the hwy, and didn't bring me the benefits I thought it would.
    Glad the upmap is working as you have hoped.
  20. Greg the pole
    Mar 1, 2011
    2,125
    Calgary, AB
    Might be a good idea. Looking at the pictures, they would go to one tb.
    But....honda car division is having all sorts of issues with their DI. The way it was explained to me is the pistons are dished, the injector squirts in the mixture at one edge, and the fuel/air atomizes as it goes over the piston surface. It works well when the piston surface is clean, but the minute any carbon builds up on the piston the path of the mixture gets all bumpy, and the system throws a mis fire code.
    I think ford had a similar issue on their 1st gen ECOboosts. That said, 2nd gen is largely sorted.
    Amphib likes this.
