1. eNewsletter Sign Up
The Africa Twin CRF1000L Owners' Thread
Discussion in 'Japanese polycylindered adventure bikes' started by erey, Dec 20, 2015.
  1. cblais19
    cblais19 Long timer
    Nov 3, 2017
    2,646
    NoVA
    Haven't heard of widespread DI issues on the Honda car engines; do you have a specific model? Only major light vehicle issue I'm aware of is the oil dilution thing with the 1.5T in cold climates and short run times.
  2. Amphib
    Amphib A mind is like a parachute....
    Sep 19, 2018
    2,900
    Wnc
  3. Greg the pole
    Greg the pole There are no stupid questions, only stupid people
    Mar 1, 2011
    2,158
    Calgary, AB
    yep, the 3.5L ridgeline (2nd gen)
    Buddy is a mechanic at Honda Calgary. He's my source.
    Another guy we ride with has his ridgeline in the dealer for two or three months. Ended up replacing complete wiring harness and some other shit.
  4. cblais19
    cblais19 Long timer
    Nov 3, 2017
    2,646
    NoVA
    I'll PM ya!
    Huh, I would've thought that any 3.5L DI issues would show up in the Pilot first since there's SO many more of those. Odd regardless. My DI 2.4L Accord is a gem. Anyway, I'll end the derail :p.
    Amphib likes this.
  5. swimmer
    swimmer armchair asshole
    Oct 9, 2007
    16,419
    Tucson, AZ
    Yeah, that one also won't fit. Not that it matters since what you have works, but Shorai suggests a different model than that for the '16-'17 AT.
  6. swimmer
    Oct 9, 2007
    16,419
    Tucson, AZ
    The Toyota DI engines with D4-S technology have a cleaning cycle they periodically go through at hot idle to deal with carbon build up issues on the injectors and also supplemental port injectors used a low load to help keep the valves clean.
    Nihon Newbie, neanderthal and Amphib like this.
  7. Greg the pole
    Mar 1, 2011
    2,158
    Calgary, AB
    I have limited experience with newer honda cars.
    Besides, I hang out with dudes that have trucks...almost bought a ridgeline myself, but it was out of my range for what I could spend.
    have owned my share of good hondas...prob my fav was a 1986 Accord LX.. Bulletproof, and extremely well built. POP UP headlamps!!!
    :D
  8. neanderthal
    neanderthal globeriding wannabe
    Nov 26, 2006
    4,721
    Here, but lost. Am I lost if i know i'm here?
    The 2nd gen ecoboosts now also have port injectors.
    gve.mcmlxxiv and sweetlou like this.
  9. neanderthal
    Nov 26, 2006
    4,721
    And lower emissions.
    Amphib likes this.
  10. sweetlou
    sweetlou small body, big balls
    Jun 22, 2008
    2,570
    Melville, NY
    And all reports of intake valve coking on first gen Ecoboosts have yet to be substantiated... always just post pictures of 1980s era European boosted engines!
  11. gve.mcmlxxiv
    gve.mcmlxxiv Been here awhile
    Sep 5, 2017
    327
    Arkansas
    its actually called the atz-10, 360 is part of the name and is the cranking amps. one of the reasons i got it was the restart button. if you have a parasitic drain on your Lithium battery and it gets below 10V the battery is dead forever. this disconnects that and leaves enough juice in the battery to restart.
    this is something you need to understand before you get any lithium battery.
    watch the Lemmy video here:
    https://www.revzilla.com/motorcycle/antigravity-restart-lithium-ion-battery
    heres the one i bought for 2016
    https://www.cyclegear.com/parts/antigravity-atz-10-restart-360ca-lithium-ion-battery
  12. swimmer
    Oct 9, 2007
    16,419
    Tucson, AZ
    Unfortunately nothing from Antigravity fits the '18+ AT.
    I hope that the revised 2020 AT uses this same ELIIY Power Lithium battery so that the production numbers can justify one of the aftermarket battery guys to produce a suitable substitute.
  13. gve.mcmlxxiv
    Sep 5, 2017
    327
    Arkansas
    Yeah, I was actually looking at Ford engines this morning. They are calling it PDFI port -direct-fuel injection. Port injection have the self cleaning of carbon going on is the reason.
  14. gve.mcmlxxiv
    Sep 5, 2017
    327
    Arkansas
    There probably is something. If you call them with your battery number they can probably recommend. It’s probably not indexed. The 360 cranking amps va the factory 220 turn it on immediately
  15. swimmer
    Oct 9, 2007
    16,419
    Tucson, AZ
    No, nothing fits into the battery box. The lithium battery doesn't have a standard case size.
  16. Junglejeff1
    Junglejeff1 Long timer
    Oct 20, 2016
    4,356
    Upper Michigan
    Maby they should apply some technology to making fuel tanks with out welding slag and forks that don't wear out before they do this.
  17. Junglejeff1
    Oct 20, 2016
    4,356
    Upper Michigan
    Besides never buying another honda ever again I will run from this eco crap.Will go back to my older bikes that are much easier to service and run just fine.I guess motorcycles and cow farts are causing global warming or cooling now(take your pick).I just got a paper from my electric company saying that the electricity I use is over 80% from coal.same in 4 surrounding states.China spews the crap out so much they have to wear masks there.And the idiot's think coming down on motorcycles is going to help.As long as it makes people feel better lol.
    twinrider and ex_MGB like this.
  18. cblais19
    cblais19 Long timer
    Nov 3, 2017
    2,646
    NoVA
    To be fair, the 2 wheeled emissions controls are out of Europe, where there are vastly higher numbers in the urban areas - and particulates are of far more concern. Only
    CA really gives a crap over here, and you should remember how bad the air pollution was in the major cities there before they clamped down on vehicle emissions.
    It’s not all climate change concerns.
    Maybe if we were a much bigger market, the import brands wouldn’t economize by giving us Euro 4/5 compliant emissions systems.
    swimmer likes this.
  19. gve.mcmlxxiv
    Sep 5, 2017
    327
    Arkansas
    I agree with both you guys. China pollution images are horrific. I remember the first time I went to Los Angeles in 1983, vehicle air pollution was so thick visibility was obscured to half a mile on a clear day. It was like the Beijing pictures you see now.
    Most these choices will be made for us in time so I don’t worry too much.
  20. twinrider
    twinrider Pass the catnip
    Aug 20, 2002
    17,311
    日本
    I'm all for climate change if it means a longer riding season. Did my part by decatting my bike.
    Bhart89 and Junglejeff1 like this.
