The Africa Twin CRF1000L Owners' Thread
Discussion in 'Japanese polycylindered adventure bikes' started by erey, Dec 20, 2015.
  1. Junglejeff1
    Junglejeff1 Long timer
    Oct 20, 2016
    4,660
    Upper Michigan
    I am guessing they are the same 10mm shims as cr450 but will not know till a do the same as you.Honda only uses 2 shim diameter sizes from my experience. As for your forks just pull caps and dump.I flush forks with atf(cheap and safe)It is around a 10 wt and stays thin in cold weather like fork oil.Therefore if there is a bit left after flush no harm done.I highly recommend cogent for springs and it is worth for us big strong American dudes. I never had problem with stock seals but I run zip on seal savers.I did use sks black seals when I rebuilt (7200 miles)that I got from race tech.Those goofy zip on things have saved me a lot of labor since i started using them.I would replace the seals on my offroad bikes at least once a year and after i started using them i never had another seal go.
    misterk and Amphib like this.
  2. Lost Cartographer
    Lost Cartographer Been here awhile Super Supporter
    Feb 7, 2011
    756
    AZ and CA
    Intake valves adjust using shims.
    Exhaust valves have screw adjusters.
    I'm wiling to bet that you won't need to adjust the intakes, they generally don't move nearly as much as the exhausts. At 15,000 miles only 1 of my exhausts needed adjustment, all of my intakes were perfect.
    Has anyone out there needed to adjust intake valves yet?
    Not really. Yes you COULD just unscrew the fork cap and pour the old oil out, then flush with ATF and refill with fork oil.
    BUT
    When doing it that way there is no way of knowing exactly what your new oil height is. You could measure the amount of oil that you pour out and if you are really meticulous you might get the same amount of oil back in, but there is no telling what was in there in the first place. As someone else has pointed out on here, there is good evidence that some forks were overfilled from the factory (a large number of bikes blew fork seals the first time they went off road, which generally is a sign of overfilled forks). If there were some overfilled ones, there were probably some underfilled ones as well.
    ALSO
    New fork springs and a revalve make a big improvement.
    If you are going to keep the bike I'd just do the whole thing at once.
    windowto, 97707 and Amphib like this.
  3. Amphib
    Amphib A mind is like a parachute....
    Sep 19, 2018
    3,461
    Wnc
    Same as you, 14,000 I found this but am not confident it's the right one. I'd like to have shims on hand when I do this, whether it needs it or not. I just want some confirmation from someone who knows or has already done the valves.
    https://www.partzilla.com/product/aftermarket/10BD-HOT-CAMS-HCSHIM02
  4. Amphib
    Sep 19, 2018
    3,461
    Wnc
    I may just dump and refill this time. I've got a trip at the end of the month. I may sacrifice some other purchases and do a complete job on the forks within the next couple of months. This is not going to be nearly expensive as I thought.
    Junglejeff1 likes this.
  5. Amphib
    Sep 19, 2018
    3,461
    Wnc
    Yeah, I totally agree.
  6. Amphib
    Sep 19, 2018
    3,461
    Wnc
    I've screen shotted all this great advice. Thank you all. I'm sure I'll have many more questions.
  7. Junglejeff1
    Oct 20, 2016
    4,660
    Upper Michigan
    I fully agree on most of what you say.My suspension is fully tricked out.The only thing I don't agree on is oil height. Drop the springs in and set oil height at 55mm with suction tool.Motociclo and me went through the extra work to find this info.Using volume method on forks is pretty useless.At 55mm you end up with stock air gap no matter what springs you use.I just suggested the oil change and seal savers to keep his forks in good shape till he is ready to tackle the whole thing.
  8. Amphib
    Sep 19, 2018
    3,461
    Wnc
    55mm from oil to the top of fork?
  9. gve.mcmlxxiv
    gve.mcmlxxiv 2016 Africa Twin DCT No.272
    Sep 5, 2017
    416
    Arkansas
    $300 for springs overall. You want to do the shock at the same time or you will have geometry dissatisfaction. I used the motion pro seal seater thingy for the forks and two tusk spring compressors for the rear. Cheap and Worked just fine.
    I recently had my shock revalved and rebuilt by Konflict. But before that I put a 10.3 spring on it from cogent and rode 2500 miles with inappropriate rebound and compression damping for the spring. Even with the wrong valving it was STILL a huge improvement from stock. Getting to the right sag is huge. We talk a lot about suspension valves here but oh man getting to the right sag I think does even more. I came to this opinion by doing this in steps.
    Step 1. .72 straight rate springs in forks. Dive goes away which helps but now I have geometry instability because back is still low. Also did ATAS uppers at this point. Drive 2000 miles between 1 and 2.
    Step 2. Stronger spring in rear. Stability came back. Bike is transformed but can kick like a mule on aggressive washout ruts on dirt. drive 2500 miles between step 3 and 4
    Step 3. Revalve rear shock by a true pro. Suspension shop. Bike feels like a million bucks. Now the imperfections in the fork damping are spotlighted because everything else is iron out.
    Step 4. Revalve forks. This will be in December.
    Don’t follow in my footsteps. Do all the springs at once!!! Make step 1 and 2 simultaneous. Geometric instability feels dangerous at high speed. This is my opinion from my experience on my bike that sag is more important than damping.
  10. Merlin44
    Merlin44 XR400R & Africa Twin Supporter
    Jun 17, 2016
    191
    Spring, Texas
    Yes, 55mm when forks are verticle. That measurement is after the springs are dropped in.
    windowto, Amphib and Junglejeff1 like this.
  11. Junglejeff1
    Oct 20, 2016
    4,660
    Upper Michigan
    Fork fully compressed,damper rod all the way down and bled out.A Turkey blaster with I hose with marks work as a oil sucker.I use big plunger type things I got from tractor supply that farmers use on there cows.
    windowto and Amphib like this.
  12. gve.mcmlxxiv
    Sep 5, 2017
    416
    Arkansas
    As far as my advice goes remember that I’m a noob. I got my first motorcycle when I was 38. Although sometimes the best person to help a 1st grader is a 3rd grader. Lol. There are some pro level peeps on here that have literally saved me thousands of dollars with their instructions and time so I’m happy to help anyway I can.
    Amphib likes this.
  13. swimmer
    swimmer armchair asshole
    Oct 9, 2007
    16,966
    Tucson, AZ
    Also, just removing the fork cap and pouring the old oil out doesn't allow you to purge out the old oil in the cartridge, or bleed the air out after refilling.
  14. Junglejeff1
    Oct 20, 2016
    4,660
    Upper Michigan
  15. Amphib
    Sep 19, 2018
    3,461
    Wnc
    I'm amazed by all this great info. I just broke the news to my wife about my upcoming purchases. :lol3
    I'm about 195lbs
    .72 and 10.3 sound appropriate?
    Nihon Newbie and gve.mcmlxxiv like this.
  16. Merlin44
    Jun 17, 2016
    191
    Spring, Texas
    That's right where I am at and what, 190-200, :) Cogent suggested. But then, they only have one rear spring rate. Konflict uses a little softer rear spring. I did Cogent front and back. But yes, the front at .72 is good. They have a heavier spring, but you wouldn't need that one.
    Junglejeff1 and Amphib like this.
  17. Junglejeff1
    Oct 20, 2016
    4,660
    Upper Michigan
    I have a 10.3 on mine and good all around spring.I just leave it set for 2 up.I ride quite a bit more sporty 1 up so never bother twisting preload down anymore.The .82,s in forks are slightly stiff and have my compression backed way out.I am down to a slim trim 203lb stealthy american body now.I should have listened to Rick and went with .72,s.Going to revalve gold valve,s a tad in front to take better advantage of those heavier springs.
    Amphib likes this.
  18. Junglejeff1
    Oct 20, 2016
    4,660
    Upper Michigan
    I purchased bike to ride wifey around so she is always behind me on spending $$ on it.Not so much on my vintage bike rebuilds.Says I spend to much time in garage playing with my toys.
    Amphib likes this.
  19. Junglejeff1
    Oct 20, 2016
    4,660
    Upper Michigan
    My 1st spring was from konflict.Custum 10.4.Cogent then built a custom shock for me to beta test and sent it with a 10.3.Sent him my original shock with gold valve in it with konflict spring.Quite shocking how well Rick made the stock steel body shock work.Of course he gutted it and put his own piston in it and added a high speed adjustment. I was going to save and get a aftermarket shock but his upgrades changed my mind.
    Amphib likes this.
  20. welder
    welder Long timer
    Feb 10, 2008
    1,546
    paradise
    Hey guys, just a quick question for those AT owners with a standard shift transmission. I bought a new old stock 2017 standard bike new in May last year. I love the bike but it is very clunky and notchy shifting from 1st to 2nd gear and a little bit from 2nd to 3rd gear, the rest of the trans shifts fine. If I am at low revs it is not to bad, but if I shift in the 3-5 rpm range it is pretty bad. Is this normal for these bikes? Is this a know issue? are there any fixes available? I have it scheduled to be looked at by the dealership but wanted to hear your opinions first.
