The Africa Twin CRF1000L Owners' Thread
Discussion in 'Japanese polycylindered adventure bikes' started by erey, Dec 20, 2015.
  1. WalterMitty2
    WalterMitty2 Been here awhile
    Sep 11, 2019
    210
    Chicagoland Area
    While I'd like to think I will become Charlie and Ewan, the realities of job and family will mean 2-3 small trips per year. So that means the other 99% of the time the bike will just be for putting around the neighborhood for mental health rides. Frankly, I could probably get a scooter and have a ball. I have no desire to bang out miles and miles on highways. Even my small trips will involve trucking bikes to places that are fun to ride versus highway miles, and those rides will be 50/50 road and light off road. Finally, I'm more of a "credit card" camper then a real outdoorsman. Given this, I think either bike will fit my needs...just trying to figure out which might be more fun. I'm a bit worried that the DS might feel a little tame compared to even my CR250 2stroke. But it's damn cool looking and a lighter bike. On the flipside, even thought the AT would be the DCT version...I would assume the bigger engine would still provide a lot of punch. Might just have to flip a coin.
  2. Vasbyt
    Vasbyt Been here awhile
    Aug 30, 2012
    187
    St Charles, IL, USA
  3. Barron
    Barron M0DAH0LIC
    Mar 24, 2006
    3,433
    Bethesda, Maryland
    Got a cave drawing of that bike? It might run on Baghdad batteries. lol
    -Barron
    Honda-50 likes this.
  4. swimmer
    swimmer armchair asshole
    Oct 9, 2007
    16,945
    Tucson, AZ
    FWIW, babbitts was the least expensive place I found selling the OEM battery at $484. Revzilla seems to price most of their OEM parts at full price. Not sure how they expect people to buy from them when every other online OEM seller is discounting their price.
  5. Nihon Newbie
    Nihon Newbie Weirdo
    Dec 13, 2012
    478
    SLO Cal
    I have the Puig touring one, same problem. It will fit if you use their little spacers and thread all the bolts in at the same time, and bend the screen a bit. IMO it's just a bad spec; install shouldn't require that much nonsense. The holes are off, period.
  6. NorskieRider
    NorskieRider Long timer
    Mar 19, 2011
    1,294
    Minnesota
    And 250-400cc enduro's. Can't hardly find anything made in the past 17 years for less than $2k if it's in good shape.
  7. NorskieRider
    Mar 19, 2011
    1,294
    Minnesota
    For those of you with more sensitive butts than I - what does the 'G' (gravel) button on the DCT actually do? I can't tell the difference.
  8. NorskieRider
    Mar 19, 2011
    1,294
    Minnesota
    Regarding LiFe / LiIon batteries ... I was about to put one in and decided against it. I'm not an electrical engineer, but it was explained to me by a 'battery expert' that charging systems need to be tailored for the correct type of battery to get the best life out of it. So, my KLX and AT (2016) came with AGM batteries and their charging systems are set up for that, which means lithium-whatever batteries will not be optimally charged. So I decided to forgo the $180 (and 6 pounds lighter) batteries in favor of the tried and true and much cheaper AGM batteries.
    That being said ... we did run a Shoria 6+ years ago in my wife's old SV650 and it lasted about 4 years; the last year it was hit-miss whether it would start. It really didn't like starting below 60F.
  9. procycle
    procycle Long timer
    Jun 7, 2007
    7,486
    Center of the DualSport Adventure universe
    As I understand it, the G button shortens the time it takes to shift from one gear to the next.
    I can't tell much difference either.
  10. windowto
    windowto Long timer
    Jun 18, 2012
    3,081
    NJ
    It also holds on to gears a bit longer. The easiest way to tell is in D mode on the road. Try regular mild acceleration in D and note the shift points (MPH). Try the same with the G button ON and see the difference.
  11. Reidy008
    Reidy008 I,m in if we go fast
    Jan 6, 2010
    4,184
    Peoria, AZ
    G Mode changes how much slip in is the clutch. The S modes are the part that is working gear changes shorter or longer and holding gears under higher RPM.
    Best way to tell how G mode works is leave it in D and from a dead stop feed in the throttle slowly.. as if you just want to edge the bike forward a foot or two, you will notice how the rpm's increase and the clutch is slow to engage. Same thing but hit the G Mode and you will see how it now engages quicker and stronger then before.
    DCTFAN likes this.
  12. windowto
    windowto Long timer
    Jun 18, 2012
    3,081
    NJ
    I agree with everything you say, but try it and you'll see what I mean. Easiest to check in D mode since it changes the gears so early. I can't tell you why it does it, but you can see for yourself that it does change with the G button.
    Cheers
  13. DCTFAN
    DCTFAN 2019 CRF1000LD | 2016 CRF1000LD | Supporter
    Mar 17, 2016
    1,977
    GA
    DCT before the AT did not have the G-mode, in fact, it's only available on the AT right now.
    The AT is the only bike considered to be off-road capable- because it has the G-mode.
    You could use it for everyday riding, but you're not using it for its intended purpose.
    Without going into too much technical detail the summary description of "feel" that it gives you is
    that it enables you to ride the bike more like a dual sport than a scooter.
    PS. nothing wrong with riding a scoot off-road :)
  14. Junglejeff1
    Junglejeff1 Long timer
    Oct 20, 2016
    4,657
    Upper Michigan
    I noticed that.I have been thinking about getting a DRZ400 but crazy prices.Most likely just get a used 500 katoom as that is what will truly satisfy me.Going to be a long winter to think about it.
  15. Yooper_Bob
    Yooper_Bob Insert witty saying here....
    Aug 31, 2005
    4,894
    Da UP, eh! (Marquette, MI)
    Don't you think you have enough bikes already???? :hmmmmm
    Junglejeff1 likes this.
  16. Junglejeff1
    Oct 20, 2016
    4,657
    Upper Michigan
    Trying to own 1 of each before I die.Setting myself up to live in a box under a bridge when I retire.
    mike54 and twinrider like this.
  17. WalterMitty2
    Sep 11, 2019
    210
    Chicagoland Area
    They say dying penniless is awesome budgeting AND timing.
    PistolPetey, Muddler and Junglejeff1 like this.
  18. twinrider
    twinrider Pass the catnip
    Aug 20, 2002
    17,445
    日本
    My AT was also plagued with problems so consider it a 3 off. Honda is now run by the bean counters who focus on cutting costs everywhere possible.
  19. twinrider
    Aug 20, 2002
    17,445
    日本
    Imagine how many Suzuki would sell if they just updated the carb to FI. Mind-boggling that they don't.
  20. Junglejeff1
    Oct 20, 2016
    4,657
    Upper Michigan
    Big thing to me is less weight and more responsive power with better over rev.I tried a guys DR400 last week and damn that thing is old school.
