The Africa Twin CRF1000L Owners' Thread
Discussion in 'Japanese polycylindered adventure bikes' started by erey, Dec 20, 2015.
  1. Junglejeff1
    Junglejeff1 Long timer
    Oct 20, 2016
    6,061
    Upper Michigan
    I had to pop the rubber grommet thing out of the brake hose holder on my 2016.Hose just made it then.Some readjusting was needed to wires and such.
    Getnout and Dale402 like this.
  2. nsfw
    nsfw Death Valley Noobs Rally Super Supporter
    Feb 20, 2007
    30,579
    Burbank SoCal
    a few days ago, almost got taken out twice, 5 minutes apart by inattentive motorists.
    normally, to announce or let them know my presence, i will pull the clutch in and rev the engine a couple of times. on my DCT can't do it. i'm starting to teach myself to keep the left thumb next to the horn as an alternative.
    i think a louder exhaust would improve the situation.
    ride safe and never keep your guards down.
    neanderthal, Barron and Junglejeff1 like this.
  3. Dale402
    Dale402 The holder of what's unused Supporter
    Sep 24, 2015
    259
    So Ill
    Thanks, B. I’ll pm you on the Rod risers.
    Dale
  4. Capt CF
    Capt CF Pontificating Nobody
    Jul 1, 2013
    1,493
    Northern Virginia
    I threw a soundbomb on mine. That gets their attention.
  5. chittyrox
    chittyrox Been here awhile
    Dec 20, 2013
    165
    Midwest-ish
    Added the soundbomb and that seemed to wake up the neighborhood after that...safe riding!
  6. swimmer
    swimmer armchair asshole
    Oct 9, 2007
    23,564
    Tucson, AZ
    Where did you guys mount your soundbomb horns at?
  7. Capt CF
    Jul 1, 2013
    1,493
    Northern Virginia
    I used the Denali mount for the compact soundbomb. Worked out well, but in a bad drop on the left I am a little worried about the crashbars bending into the horn and damaging the threads since the mount utilizes two bolts/holes from the crankcase cover on the left side. The horn itself almost touches my SW Motech crashbars, but hopefully the mount would just bend toward the cylinder and/or the horn plastic break and not damage the holes/cover. Not too worried about the horn (easy to replace), but having to easyout/drill out and then helicoil/timesert those holes would kind of suck.
    https://denalielectronics.com/collections/horn-mounts/products/hmt-01-10200
    You didn't ask, but I'll throw in a plug for the Eastern Beaver PC8 and Powerlink system. Wiring stuff into that battery compartment is the stuff nightmares are made of so running one set of leads to the PC8 and never touching it again unless the battery needs to be replaced beats the hell out of the alternative (stuffing a bunch of connections into that box). I used the powerlink AT battery leads and then the powerlink splitter (one side to the PC8 and one side to the soundbomb) and then ran EB's high power horn kit to the soundbomb. While I was in there I went ahead and replaced the battery ('16 model) so I can go the maximum amount of time without touching it again. I'm also running an SAE tender plug (non-switched), Oxford grips, Denali DR1s, a Gerbing's heated gear pigtail and a dual USB/voltmeter (switched) through the PC8. Nice bit of kit.
    Lost Cartographer and Getnout like this.
  8. Ed
    Ed Shunpiking Supporter
    Oct 24, 2009
    852
    Prineville, Oregon
    I installed a pair of Hella high low tone disks in place of the stocker. 114db gets cagers attention. Sounds like. German rally car. Wired through a relay and a PC8 fusebox. Looks like a stock installation.
  9. chittyrox
    Dec 20, 2013
    165
    Midwest-ish
    Lost Cartographer likes this.
  10. swimmer
    Oct 9, 2007
    23,564
    Tucson, AZ
  11. chittyrox
    Dec 20, 2013
    165
    Midwest-ish
    It has been awhile since I have done it, and the bike is not with me right now. But I do not think I had to splice into wires at all. It plugged right in with blade-style electrical terminals and mounted right up. Don't quote me on that, as I have drank and slept since! The mini soundbomb or the hella horn were the only two options that seemed to work better for my riding style.
    Lost Cartographer and swimmer like this.
  12. Capt CF
    Jul 1, 2013
    1,493
    Northern Virginia
    Also, nothing saying you have to use the Denali mount. I just did because I am lazy and don't ride my AT off-road very often. I installed a Denali split soundbomb horn on another bike and it tucks up nicely under the plastics so you can't even tell it is there. The split model splits the compressor and the horn into two separate components that are a bit easier to mount/hide and includes a length of rubber hose that you use to connect the two. Just another option to consider.
    chittyrox likes this.
  13. Motociclo
    Motociclo Long timer
    May 18, 2017
    1,305
    The Hunter.
  14. twinrider
    twinrider Pass the catnip
    Aug 20, 2002
    18,752
    日本
  15. bbanker
    bbanker Been here awhile Supporter
    Feb 24, 2011
    673
    Beautiful NC
    He doesn't really ride it off road, but with all of those miles he has done no suspension work or maintenance and reports no problems with function. :hide
    Junglejeff1 likes this.
  16. Junglejeff1
    Oct 20, 2016
    6,061
    Upper Michigan
  17. SSunklug
    SSunklug Adventurer
    Nov 9, 2019
    54
    Burgos (Spain)
    A small photoshop
    ROYMACNIC, nsfw, chittyrox and 6 others like this.
  18. SSunklug
    SSunklug Adventurer
    Nov 9, 2019
    54
    Burgos (Spain)
    nsfw and redneckmech like this.
  19. SSunklug
    SSunklug Adventurer
    Nov 9, 2019
    54
    Burgos (Spain)
  20. SSunklug
    SSunklug Adventurer
    Nov 9, 2019
    54
    Burgos (Spain)
