The Africa Twin CRF1000L Owners' Thread
Discussion in 'Japanese polycylindered adventure bikes' started by erey, Dec 20, 2015.
  1. SuperCubic
    SuperCubic Adventurer
    Apr 12, 2018
    18
    Spain
    Now that I have the bike disassembled all over the garage, I have the opportunity to thoroughly clean and grease all parts.
    I has been said that the grease in the rear wishbone and wheel bearings is insufficient from factory, and that some say that they grease it properly. I've looking at it and those are sealed bearings.
    How someone it's applying grease to those joints? Are they breaking the seals? Perhaps the bearings are different?
  2. Black99S
    Black99S Been here awhile
    Dec 30, 2012
    382
    Vancouver, Canada
    For the suspension linkage Clean around Seals then push the centre hollow spacer /race through. I just add grease to the inner needles. Honda spec is 3% moly I believe. Couldn’t find any so used BellRay blue.
    No idea about the wheel bearings.
  3. SuperCubic
    Apr 12, 2018
    18
    Spain
    Thanks pal. I'm doing it right now and both the wishbone and the damper "bones" have sleeves and can be greased. Not the wheel though.
    I'm just thinking... Those needle bearings are not supposed to see high revs or heat. Should not be better putting marine great on them? I mean the sticky green/blue one.
    This thing is used underwater and keeps moisture out while still lubricating.
    FASTRacing and windowto like this.
  4. windowto
    windowto Long timer
    Jun 18, 2012
    3,073
    NJ
    Dare I say Dupont Molykote 111? Lubricates seals and withstands some pressure... This thing is used in water pumps even. Pretty good stuff:)
  5. Black99S
    Dec 30, 2012
    382
    Vancouver, Canada
    Honda spec is for high moly content because of the small movement and high load.
  6. Moshaholic2
    Moshaholic2 PCUT
    Apr 16, 2018
    230
    Utah
    Still snowing. Figured it was a good time to throw on some new rubber and get in and start cleaning the hard to reach places.
    Hope I can get more than 2500 miles out these like the Anakee Wilds (which were great but wore super fast)
  7. TiuSo
    TiuSo Adventurer
    Jul 30, 2014
    23
    Kangasala, Finland
    I did exactly the same for my -18. I have zumo on touratech cradle and it still vibrates a lot (long arm between ram balls I guess). Needs further modifications..
  8. TiuSo
    TiuSo Adventurer
    Jul 30, 2014
    23
    Kangasala, Finland
    I think that is the best location for my zumo, I used to keep in bars (left side). Just to get rid of the vibrations/shaking..
    procycle likes this.
  9. NorskieRider
    NorskieRider Long timer
    Mar 19, 2011
    1,285
    Minnesota
    I have about 5k on mine, and am at the point most would change it, and I would if I were going to do anything significantly off-pavement. But I think I can squeeze another 1k road-miles out of it. Excellent tire for the price.
  10. chittyrox
    chittyrox Been here awhile Supporter
    Dec 20, 2013
    165
    Midwest-ish
    On wheel bearings, you can use a fine pick to carefully remove the rubber seal, pack the bearings, put the seal back and install.
    Nihon Newbie and SuperCubic like this.
  11. Greg the pole
    Greg the pole There are no stupid questions, only stupid people
    Mar 1, 2011
    2,223
    Calgary, AB
    Finally got out for a 1st ride of 2020 on the AT.
    Gutted cat will be entertaining...
    This might help. I'm guessing you're referring to the linkage.
    https://thetenerist.wordpress.com/2...e-and-shock-bearing-inspection-and-grease-up/
    SuperCubic likes this.
  12. Greg the pole
    Mar 1, 2011
    2,223
    Calgary, AB
    got out on the AT, and the SV yesterday.
    AT sans baffle...its quick
    working out a few bugs on the SV...
    Need better mirrors. The wide upright bars have me seeing elbows...and nothing else,
  13. SuperCubic
    Apr 12, 2018
    18
    Spain
  14. Greg the pole
    Mar 1, 2011
    2,223
    Calgary, AB
    no worries.
    all your torque values are there.
    Be careful with some of the bearing rollers as they might not be captive. Slide the spacer out partially, so it holds them in place.
    But i might be thinking about my BETA swing arm...as I was missing a few rollers there
  15. Greg the pole
    Mar 1, 2011
    2,223
    Calgary, AB
    wow wee! I've seen fire, and I've seen rain...but I have never seen that before!
    Good on you for making it work. Desperate times call for a hyundai 3 cyl diesel! :1drink
  16. Greg the pole
    Mar 1, 2011
    2,223
    Calgary, AB
    Looks like you had the place all to yourself! nice.
  17. jojitsu
    jojitsu Adventurer
    Oct 15, 2017
    13
    Uk
    Great info, cheers.. I have ended up removing my givi trekker outback racks and fitted touratech ones instead.. I now how the option of an old set of touratech zega panniers that are light, simple and sturdy as well as being only slightly wider that the bars with barkbusters, and also an old set of ortlieb/touratech endurance click that attach very quickly and easily and are very light and narrow, and can accommodate a full set of my camping gear.. Could also easily use my magadan panniers if I so wish without any modifications.
    Veeblefetzer likes this.
  18. BikesR2Funn
    BikesR2Funn Adventurer
    Aug 28, 2019
    28
    Winnipeg
    Who has the 2020 AT?? How much better is it??
    BRUSHCREEK likes this.
  19. SkipD
    SkipD That looks stickey
    Aug 19, 2010
    454
    Gold Coast
    I have seen some strange shit in my life but I think you deserve some sort of award for that. My mind is still comprehending not only the disassembly and placement required but also moving a 230+kg object (the said AT) into the small tin can, then being able to remove it without the aid of a can opener.
    I think that deserves 100 out of 100 for effort never mind the bonus points that should be awarded for coming up with such a cunning plan
    chittyrox, poqomchi, 1litre and 3 others like this.
  20. SuperCubic
    Apr 12, 2018
    18
    Spain
    It wasn't 230kg as it was disassembled, except engine from the frame and related parts. Like coolant circuit and underfairings.
    Then it was slided in by "strong man"
    At destination I used something like an engine crane.
    I still haven't found any scratches. Fingers crossed.
    I must say that in my country, I was 1 day to a closure of all roads for non essential traffic. And I was pulled out and asked where I was from and why I was out of home.
    The car was sitting in a shop, near a family house that was abandoned for more than a year and half due to decease. I was recluded there for a week and half when I heard the incoming state of alarm and road closure.
    The house was completely emptied for safety, so no beds or working kitchen. I had almost consumed my resources so I had to go.
    A wife and a 1yr baby where awaiting for me. Strange measures for strange times, I suppose.
    PS: motorcycle travel was not justified/allowed. And with everything closed, leaving the bike alone was the same as seeing it on fire.
