    Dismiss Notice
The Africa Twin CRF1000L Owners' Thread
Discussion in 'Japanese polycylindered adventure bikes' started by erey, Dec 20, 2015.
  1. Sundude901
    Sundude901 Adventurer
    Oct 1, 2018
    48
    Memphis, TN, USA
    Anyone used one of the Givi rack/support kits with a Non-Givi top rack? I'm looking at the SR1162, but can't really tell if it would work to support the rack. Mounting an SW Motech adventure rack with a DrySpec H35 top case.
  2. DCTFAN
    DCTFAN 2019 CRF1000LD | 2016 CRF1000LD | Supporter
    Mar 17, 2016
    2,024
    GA
    It works with any carrier on 2016/17 models but 2018 forward, they won't do much good
    due to the redesign of the rear rack.
  3. Sundude901
    Oct 1, 2018
    48
    Memphis, TN, USA
    Gotcha! I appreciate it!
  4. McBoab
    McBoab Fast side of farty
    Jun 7, 2003
    625
    Blighty
    Had my ATAS in the dealers for its 2 year service, whilst there I enquired about warranty cover for corrosion on on the wheel spoke nipples, as mine have tarnished though the stainless spokes are ok. What I was told was Honda wont cover it . Moderately disappointed in that tightening of Hondas coverage given the replacement of wheels on the earlier (non-stainless spoke) bikes. Anyone else had same /similar here in Blighty?
  5. gve.mcmlxxiv
    gve.mcmlxxiv 2016 Africa Twin DCT No.272
    Sep 5, 2017
    451
    Arkansas
    Very good! I have the same year bike but you have way more miles. I’m coming up on 16k miles Did you do your own valve service In the engine? How was it?
  6. Mudslingr
    Mudslingr Been here awhile
    Aug 10, 2016
    162
    2016 standard. I just hit 20k trouble free miles. Changed chain, sprockets,rear brake pads, brake fluid and wheel bearings. Rear bearing looked worn but not terrible fronts looked fine but changed them anyway for piece of mind.
  7. swimmer
    swimmer armchair asshole
    Oct 9, 2007
    17,624
    Tucson, AZ
    20k miles isn't much for wheel bearings so for them to not look good is a bit concerning but I've have read about other AT owners experiencing the same, or worse. https://advrider.com/f/threads/help-needed-near-bozeman-mt.1458921/
    I wonder if it's just a cheap bearing spec causing these issues or something in the tolerances of the bike design contributing to short bearing life.
  8. Mudslingr
    Aug 10, 2016
    162
    The bearings weren't bad. I could have gone another 20k on the fronts probably. The rear ones were dirty so maybe another 10k on those.
  9. Anjin455
    Anjin455 Riding on the company dime
    Oct 18, 2015
    105
    Freedom Land
    I didnt tear down the bike for valves myself, had some help with it. The intake valves didnt require any adjustment the first time, only the exhaust valve was set a little bit too tight from the factory. Second valve job I took to a shop since I was out of town st the time, again no adjustment on the intake valve but the exhaust on one side was a bit loose.
    Im not going to open it up for the next interval, unless i hear some clatter.
  10. Mikeeep
    Mikeeep Adventurer
    Nov 25, 2019
    42
    USA
    A tight valve can damage a motor. They don't clatter.
    Wind_Rider likes this.
  11. procycle
    procycle Long timer
    Jun 7, 2007
    7,726
    Center of the DualSport Adventure universe
    As @Mikeeep said. The danger comes from running with a valve too tight. They typically tend to tighten up with wear as the valve slowly embeds itself into the valve seat. It won't give any audible warning before things go expensively wrong. If anything it will get quieter.
  12. Moshaholic2
    Moshaholic2 PCUT
    Apr 16, 2018
    279
    Utah
    Just a heads up for anyone planning the Utah BDR anytime soon.
    Took the 450L out for what should have been a pretty easy ride on the mid section of the UT BDR which is normally big bike easy cruisin (most of the BDR's are)
    This section is below a big burn scar from last year and since then has been subject to numerous flash floods and landslides.
    Be prepared to pick your bike big bike up alot or have broken parts unless you are an expert rider.
    The track simply does not exist anymore. Gone. Washed away.
    97707, NSFW, redneckmech and 4 others like this.
  13. redneckmech
    redneckmech No burrito left behind!
    Jan 31, 2010
    788
    Somewhere up shift creek sans paddle..
    Anyone have a good lead on an inexpensive Africa twin? I just got back from another section of the IDBDR and one of the guys I rode it with is looking to replace his 650 Strom with something more dirtworthy. He doesn't care if it is a dealer holdover or has miles on it.
    If you have a lead on one go ahead and send me a PM and I can pass it on so as to prevent cluttering up the thread. IMG_20200801_182816.jpg IMG_20200801_220046.jpg
    NSFW and Moshaholic2 like this.
  14. RossTheRed
    RossTheRed Adventurer
    Sep 5, 2008
    50
    Everett, WA
    I picked up a Tusk side stand foot last fall. Worked fine until a couple months ago when it just flipped off when I kicked the stand up.
    I tried putting it back on, but it didn't want to stay, so I gave it a couple whacks with a hammer. That did it until about a week ago when I kicked up the stand and the foot didn't go with it.
    Anybody have any experience with other brands? I ride every day, but I think something like this should last longer than ten months.
    Additional question:
    Is anyone producing any good shorty levers yet? Last time I looked there wasn't much.
    666, Bors, NSFW and 1 other person like this.
  15. Black99S
    Black99S Been here awhile
    Dec 30, 2012
    416
    Vancouver, Canada
    Camel ADV for a side stand.
    Zeta for levers. CRFs only has them.
  16. Noillek
    Noillek Nomada Portugues
    Mar 24, 2008
    31
    Netherlands
    Decided to make my 2017 AT a bit more racing, rally type seat, DPM license plate holder and cut the hand grips for the passenger. Now just need to get it dirty. 36D13D4E-B17B-4A7B-A95C-FCF534DD5C58.jpeg
    PhaseShifter, N0madic and Aces 6 like this.
  17. N0madic
    N0madic Been here awhile
    Oct 31, 2019
    107
    Appalachians
    Nice! Any more photos of the Race Seats seat and how is the overall quality? Being one piece, how does it attach in the back? Thanks!
  18. NSFW
    NSFW basecamp4adv Super Supporter
    Feb 20, 2007
    25,431
    Burbank CA
    on the OR coast
    same here, got 20k on mine but i will inspect them when i get home. if still good, i will wait for a big trip before replacing them. long list of new parts to buy. battery, rear brake pad, chains, c. s. , rear sprocket, and a bunch of other wear or broken items.
    have to do my first valve adjustment, fluid replacement. head bearing and swing-arm lube job, etc. my AT DCT never let me down.
    hello from Powers OR
  19. procycle
    procycle Long timer
    Jun 7, 2007
    7,726
    Did you take the road south of Powers to (or from) Agness?
  20. Noillek
    Mar 24, 2008
    31
    Netherlands
    will drop a picture as soon as I get home, the seat is pretty comfortable if you like hard... I do find it comfortable, wider in the back and narrower in the front so standing is never compromised and to get a bit wider I need to slide backwards a bit... arms go to stretched.
    quality is good, but needed to get a spacer on the seat lock so it keeps it snug otherwise moved to much for my taste, on the back has 2 metal teeth that slide into a part of the rear fairing to keep in place.
    advice I got the +2cm above stock if I would order again I would do +4cm than stock, gets to be more parallel to the ground while now does a V shape and you always slide against the gas tank even with suspension adjusted to low all the way.
    Pcfly and N0madic like this.
