    Dismiss Notice
The Africa Twin CRF1000L Owners' Thread
Discussion in 'Japanese polycylindered adventure bikes' started by erey, Dec 20, 2015.
  1. DCTFAN
    DCTFAN 2019 CRF1000LD | 2016 CRF1000LD | Supporter
    Mar 17, 2016
    2,024
    GA
    FYI, DCT parking brake needs TLC too.
    Found the caliper seized and not moving making rear wheel installation almost impossible.
    In the pic below the moving parts are left and right of the piston.
    Caliper needs to move at least half an inch to do it's job.
    PS. I forgot to mention that the pad spring is inserted wrong in the pic, as I found out later. The two small 'teeth' need to go to the opposite side from the piston. ie. the outside pad is fixed and the pad against the piston needs to move a bit with it.
    procycle likes this.
  2. CopyCat
    CopyCat I am NOT like the others Supporter
    May 16, 2015
    784
    behind the cheddar curtain
    Forgive a new 2019 AT owners ignorance, Ive searched for answer without luck. I am very tall and understand that the Adventure Sport model uses a taller seat, bars, and windscreen. My research indicates in '18 a blue/blk seat was used which matches my '19. A search of Partzilla fiche shows MANY AT models. I don't know which of these would be the blue/blk model. Why so many model numbers? All list the same VIN numbers so that's not it. Can anyone please help me get lined out?
  3. NSFW
    NSFW basecamp4adv Super Supporter
    Feb 20, 2007
    25,467
    Burbank CA
    is that how it was installed since new? never got serviced? mine is due for new rear brake pads and will inspect the handbrakes. thanks DF for the alert.
  4. DCTFAN
    Mar 17, 2016
    2,024
    GA
    No, I popped it out to clean the caliper and realized there was a correct way to put it back.
    As it always happens, it went in the wrong way at first :)
    But overall, the parking brake was an annoyance from the start- single purpose and works,
    but not the best solution IMO.
    I'd much rather they would design the rear brake caliper do the "parking" bit and loose the extra parts.
  5. Smittyrunner
    Smittyrunner Been here awhile
    Jan 13, 2019
    199
    Orange county ca
    Wait you can do the rear tire installation with out taking the parking brake off?
    I can see it can be done but I always just remove the 2 bolts and get it out of the way. On my bike atleast its always a bitch to do the rear tire.
  6. DCTFAN
    Mar 17, 2016
    2,024
    GA
    I usually stick the brake disc into the parking pads and raise the wheel into the main brake pads.
    The tricky part is to keep both wheel spacers in place :)
  7. Smittyrunner
    Jan 13, 2019
    199
    Orange county ca
    Haha I know the keeping the wheel spacers in place mess. I can't tell you how many times I have got it in place just to realize the chain side one fell out.
  8. Veeblefetzer
    Veeblefetzer Adventurer
    Mar 1, 2019
    56
    Squornshelous Zeta
    Is the parking brake active during regular braking? I've had to adjust my parking brake cable a bunch and I can't figure out where the wear is at, unless the pads are wearing down, or the cable is stretching. The cable isn't under much tension when parked, though it's under tension for a long period of time. I'm flummoxed, and a flummoxed veeblefetzer is a sorry thing to see.
  9. DCTFAN
    Mar 17, 2016
    2,024
    GA
    There are two adjustment point for the p-brake.
    You can make minor adjustments at the lever.
    Major adjustments are made at the caliper:
    Veeblefetzer likes this.
  10. playinatwork
    playinatwork Been here awhile
    Jul 30, 2010
    791
    Jacksonville FL
    I've seriously considered removing my parking brake apparatus. In 40k miles I've only used it to slow the wheel speed while lubing the chain. Anyone ever removed theirs?
  11. Dudley
    Dudley Long timer Supporter
    Nov 22, 2006
    1,053
    Chaska, Minnesota, Palm Desert, California
    I'm thinking that there must be away to disable the ABS both front and back. My KTM 690 enduro allows me to disable both ends. I'm not a champion off road rider and I like no aids in the dirt. Riding down a dirt road you may have difficulty stopping.
    Dudley
  12. bbanker
    bbanker Been here awhile Supporter
    Feb 24, 2011
    524
    Beautiful NC
    I really don't find the front ABS intrusive offroad. If I get to that point in the dirt, I'm already overextending myself...
  13. sheath
    sheath Adventurer
    Aug 12, 2020
    50
    Utah
    I like front ABS on hard pack, and light gravel. Didn't take much to get the feel of it.
    Seems faster and with better control, than me trying to figure out threshold in a critical situation.
    Having a trigger, like is used for traction control, would be great for those times it really helps to have it turned off quickly.
    For me, probably better than 90% of the time, the front ABS can stay on.
    The bike is really heavy, and very beautiful. Would be nice not to drop and scratch it up. :-)
  14. NSFW
    Feb 20, 2007
    25,467
    Burbank CA
    and IGNORE the factory manual. it shows the spacers being REVERSED.
    i never trust the parking brake, and don't want to park my bike downhill unless the front tire is wedged to a berm or sidewalk.
    Smittyrunner likes this.
  15. leethal
    leethal 3 wheel Monarch #37
    Oct 14, 2008
    462
    Mornington peninsula, Melbourne
    9DE14E31-7E98-4166-9BB5-70AB05BCE450.png Wire a switch to this fuse.......abs off - abs on.
    Todd157k likes this.
  16. Smittyrunner
    Jan 13, 2019
    199
    Orange county ca
    Now you have me worried that I have mine on the wrong side... but im assuming it only goes together one way.... hopefully.
  17. Todd157k
    Todd157k Long timer Supporter
    Aug 14, 2012
    3,232
    Ventura, CA
  18. DCTFAN
    Mar 17, 2016
    2,024
    GA
    Are you guessing that will work or have you done the mod?
    My experience with ABS problem is different, expecially with DCT.
  19. gve.mcmlxxiv
    gve.mcmlxxiv 2016 Africa Twin DCT No.272
    Sep 5, 2017
    453
    Arkansas
    Can the tubeless wheels on the CRF1100 be used interchangeably with the CRF1000? I think its been asked before but I didn't see an answer.
  20. windowto
    windowto Long timer
    Jun 18, 2012
    3,111
    NJ
