The Africa Twin CRF1000L Owners' Thread
Discussion in 'Japanese polycylindered adventure bikes' started by erey, Dec 20, 2015.
  1. Northwoods Snowman
    Northwoods Snowman Been here awhile
    Apr 30, 2019
    206
    Cloquet, MN
  2. Northwoods Snowman
    Apr 30, 2019
    206
    Cloquet, MN
    Any recommendations for a skid plate that's compatible with Heed crash bars on an adventure sports?
  3. Veeblefetzer
    Veeblefetzer Been here awhile
    Mar 1, 2019
    181
    Squornshelous Zeta
    Loose Gravel, Uneven Pavement Surface, 14 foot wide road with deadly precipices on alternating sides for 30 miles, corners with the apex at the top of hill you can't see over.
    This is an Africa Twin in its Happy Place. (In this case, the inland motorcycle route between Petaluma and Sea Ranch, Sonoma County California; 86 miles that aren't the Pacific Coast Highway or US 101.)
  4. DCTFAN
    DCTFAN 2019 CRF1000LD Supporter
    Mar 17, 2016
    2,280
    GA
    Anyone know of an aftermarket clutch pack for the DCT?
  5. procycle
    procycle Long timer
    Jun 7, 2007
    9,111
    Center of the DualSport Adventure universe
    Did you wear yours out?
  6. DCTFAN
    Mar 17, 2016
    2,280
    GA
    It seems OK, how can I tell for sure?
    I also ran out of stuff to replace, lol
    Jkng, of course, let's call it preventative maintenance.
    Don't want to end up without a bike to ride, one day.
    Also, a follow up question: Both clutch packs are identical as you know each handling odd and even gears.
    would a swap help iwth things?
    My thinking is that the 1st gear 'startup' clutch is the one getting most wear.
  7. Junglejeff1
    Junglejeff1 Long timer
    Oct 20, 2016
    5,518
    Upper Michigan
    Very unlikely you have much clutch wear.All you have to do is measure the plates with a caliper and compare them with the spec in the book.clutch packs(expecially honda,Yamaha,and ktm) are pretty bullet proof.With those 3 brands I use stock clutch packs as there top of the line.
  8. DCTFAN
    Mar 17, 2016
    2,280
    GA
    Thanks for the reply.
    Would you swap the packs? May as well if they're identical after measuring.
    I have to replace the cover and while it's open intend to check everything accessible water pump, seals etc.
    https://www.partzilla.com/catalog/honda/motorcycle/2016/crf1000d-ac-africa-twin-dct/clutch-2
  9. motocopter
    motocopter Long timer
    Oct 5, 2012
    3,997
    mid-TN
    Agree with using OEM clutch plates.
    Also, now having a Goldwing DCT I've been thinking about what you're asking with regards to swapping the packs @DCTFAN
    Waa thinking that the clutch pack for first gear is the one that gets the slipping as a result of accelerating from a stop. So, in theory, the other clutch pack would always be fully engaged when utilized. A swap could freshen-up the first gear clutch pack, but what is then put into the other pack is probably not worth the effort.
    DCTFAN likes this.
  10. Junglejeff1
    Oct 20, 2016
    5,518
    Upper Michigan
    1. I would not swap anything.The dct clutch is actually easier on plates than a Manuel user.I would not even waste my time on it unless you have over 100k on the bike.Even at 100k it is unlikely you would find much if any wear.
    DCTFAN and procycle like this.
  11. DCTFAN
    Mar 17, 2016
    2,280
    GA
    Thanks for all the great advice, guys.
    I'll post up what I may find as there is a good chance I will pass the 100k mile mark by end of the year.
    My clutch side cover needs replacement no matter what. I'll peek and poke internals while she's opened up.
    @88k currently, with a trip out west planned next month.
    bbanker and belrix like this.
  12. DCTFAN
    Mar 17, 2016
    2,280
    GA
    I must confess, I did try to loft the front on occasion.
    That's mostly in 1st gear.
    But your point is taken as I have manually downshifted from 6th thru 3rd plenty, just to hear the engine revving.
  13. Wood1
    Wood1 Long timer Supporter
    Jan 8, 2014
    2,779
    Osceola
    I’d do the same thing. :D
  14. belrix
    belrix Adventurer
    Oct 10, 2014
    34
    Wow! 88,000 miles, congrats!
    Makes my 46,000 seem paltry
    DCTFAN likes this.
  15. Iowa_ADV
    Iowa_ADV I like pie Supporter
    Oct 2, 2014
    1,011
    NE Iowa
    It has been great hanging out here with you guys. But at the age of 61, with at least two surgeries on the horizon to repair my neck and my shoulder, it is time for me to get off of a 550lb ADV bike and to "put my feet up".
    I sold my AT to a guy on the forum and bought my very first cruiser.....I was pretty concerned it was going to be a mistake. I was wrong.......I love this Lazy-Boy on wheels. It's like cheating. So easy and so comfy. I already miss the AT, but it was time. I'll still lurk here occasionally, just to keep up. All for now........
  16. belrix
    belrix Adventurer
    Oct 10, 2014
    34
    Sweet looking rides!
    Good luck on the surgeries and have fun cruising around on the new wheels.
    Iowa_ADV likes this.
  17. Iowa_ADV
    Oct 2, 2014
    1,011
    NE Iowa
    Thanks to Procycle for collaborating with Warp 9 on an effective solution....Added another bearing, as it should have been done.
    procycle likes this.
  18. Junglejeff1
    Oct 20, 2016
    5,518
    Upper Michigan
    Well that sucks but getting old sucks.I will keep mine to ride wife around but I picked up my new main bike over a month ago.
  19. Anatoli
    Anatoli Pale rider
    Nov 6, 2016
    3,117
    Skagit Valley, Washington
    I haven’t checked in for a year or so..nothing has broken on the AT and all I do for maintenance is change oil, filters, and occasionally tires. This one is a keeper.
    Took a solo ride up on the borderline today. A giant log completely blocked the road. I was able to perform a kickstand 180 degree pivot turn without dropping the bike. A good trick to remember when riding alone.
  20. Gunslinger1
    Gunslinger1 GIVE'R
    Aug 22, 2006
    665
    Rolla, MO
    Set of IMS Rally pegs in flea market off 2016
