The Africa Twin CRF1000L Owners' Thread
Discussion in 'Japanese polycylindered adventure bikes' started by erey, Dec 20, 2015.
  1. rustynut2
    rustynut2 Been here awhile
    Feb 28, 2010
    834
    illinois
    Going to Buena Vista next week. Tin Cup, Haggerman, Tomichi, Hancock Pass, but I'll be on the drz, yep I'ma puss
    motocopter likes this.
  2. Blaise W
    Blaise W Long timer Super Supporter Supporter
    Jan 19, 2010
    1,550
    Tucson, AZ
    The Hotchkiss ride is from a friend's new place, so I can't comment yet on what's available. We will be exploring to some extent, all on big bikes, so much may be on new-to-us routes. However, if you look at the map, Hotchkiss is right in the middle of "everything", with mountains and forests all around. I'll try to do a RR afterwards.
    Tires: Front is a Golden Tyre 723 "Fatty", and the rear is a MotoZ Rall Z. The fat front definitely gives more "float" than a typical 90/90 and you need a few miles to get used to the light feel. But, grip is fine, the cushioning is great, and if you get onto any sand or soft gravel the front end stays up instead of knifing in. I used this combination going across the northern forests of the Sierras in CA and it was good. The front does have tall knobs, so no knee dragging!
    I am using the 723 fatty on my CRF450L too. I think there is a new number for that tire now as Golden Tyre has made a few improvements. 725? Not sure.
  3. Todd157k
    Todd157k Long timer Supporter
    Aug 14, 2012
    3,742
    Ventura, CA
    Tin Cup is still a handful on a DRZ. Looking forward to the ride report. :beer
    (I pussed out even more than you cuz I blew off Tin Cup completely. I was 2up on a DR though)
    rustynut2 likes this.
  4. Northwoods Snowman
    Northwoods Snowman Been here awhile
    Apr 30, 2019
    207
    Cloquet, MN
    Mitas e07
  5. motocopter
    motocopter Long timer
    Oct 5, 2012
    3,997
    mid-TN
    I'm in the area now with the AT. Tomorrow, I'll ride old Monarch Pass then to Pitkin and Tin Cup. Will attempt Tin Cup Pass too, but have to see how that goes.
    I rode up Hancock with the former 690ER and felt a complished afterwards. :lol2
    After Tin Cup, I'll continue up to Taylor Reservoir and over to BV. Then back to camp.
    Collecting some passes for a challenge in the Rever app.
    rustynut2 and DCTFAN like this.
  6. motocopter
    Oct 5, 2012
    3,997
    mid-TN
    Black Sage Pass after riding Old Monarch Pass. The AT is sporting the spare black wheels with Motoz Tractionators.
    ROYMACNIC, belrix, Olde Phart and 2 others like this.
  7. sailorjerry13
    sailorjerry13 Adventurer
    Apr 27, 2015
    30
    SoCal
    Just found this vid. Pretty interesting.
    Cuttin, moparren and bentlink like this.
  8. RBMann
    RBMann Been here awhile
    Aug 17, 2006
    305
    North of Seattle
    End of life for my 804 with 8500 miles on it. The double blocks wear faster than the big single block but the wear is not even around the tire. Looking down while riding, the tire looks like it is mounted straight and appears round. Noisy as hell the way it is now. Air pressure was 28-36 PSI. I have a tire pressure monitor system and was surprised how much the pressure changed with altitude and temperature. IMG_1187.JPG IMG_1190.JPG IMG_1191.JPG IMG_1192.JPG
    Bhart89 likes this.
  9. SkipD
    SkipD That looks stickey
    Aug 19, 2010
    513
    Gold Coast
    I think thats about normal if thats in mls, There is no magic if you use a brake or throttle you are going to burn up tyres. The rear Motoz are taller than most so tend to last quite well, ones like the TKC80 or Shinko 805 only need to do a lap of the car park and they are done. Softer suspension is less harsh on tyres (but may not be more grip), same for low traction (wet roads) softer is normally less stress on the tyre. My bike loaded for a typical ride is 250kg add 100kg for me starting and stopping that at any speed is going to be a bad day for a tyre, if you can get 6k km to 10k km I think you have done an exceptional job.
    simmons1 likes this.
  10. sitz
    sitz Been here awhile
    Sep 3, 2011
    192
    I’m working on a project bike and am considering using the gear shift lever from an Africa twin on it. I’ve spent a fair amount of time searching and have come up empty. Is the OEM shift lever steel or aluminum?
  11. motocopter
    Oct 5, 2012
    3,997
    mid-TN
    Aluminum
  12. sitz
    Sep 3, 2011
    192
    Thanks. Does that seem like an odd choice? I was under the impression that steel was preferred since it would bend rather that break, which seemed like a better option for an adventure bike which would actually get used. Or is my info out of date? (LMK if this has already been discussed to death somewhere).
  13. Northwoods Snowman
    Apr 30, 2019
    207
    Cloquet, MN
    I don't know when the last time I saw a steel shift lever was. Aluminum is lighter and they don't design the bike's to be crashed.
  14. motocopter
    Oct 5, 2012
    3,997
    mid-TN
    An aluminum shifter will bend as experienced on the former 690ER. I carried a spare shifter and installed on the trail. Straightening one is a different story. Seems doable; but, back at the garage.
  15. DCTFAN
    DCTFAN 2019 CRF1000LD Supporter
    Mar 17, 2016
    2,279
    GA
    If the rear brake lever is made of the same aluminum as the gear shifter (DCT, here)
    You have no worries.
    My brake lever bent 120 deg backwards and I was able to bend it back, without breaking it.
  16. edw_rider
    edw_rider n00b
    Aug 15, 2021
    3
    Asia
    2019 Crf1000L MT adv
      File size:
      762.8 KB
      54
      File size:
      538.7 KB
      54
      File size:
      418.3 KB
      53
  17. combustion cycles
    combustion cycles Action Jansen
    Feb 4, 2008
    108
    Durham, NC
  18. sitz
    Sep 3, 2011
    192
    I have a bit more research to do, but for a bike which I plan to use for multi-week trips, I’m definitely leaning towards steel. It’s good to know that folks have managed to bend the aluminum back without issue, but to my mind it seems easier/less risky to bend back steel in the field, and almost certainly easier to find a welder if I manage to break it entirely.
    Thanks for all the responses; they were helpful.
  19. William Wolfen
    William Wolfen Long timer
    Dec 5, 2015
    4,286
    Cypress, TX
    If you're that concerned about those specific parts, carry spares. They're not that big or heavy.
    sitz and Northwoods Snowman like this.
  20. mrbighead
    mrbighead Been here awhile
    Nov 18, 2009
    836
    Just north of nowhere
