The Africa Twin CRF1000L Owners' Thread
Discussion in 'Japanese polycylindered adventure bikes' started by erey, Dec 20, 2015.
  1. William Wolfen
    William Wolfen Long timer
    Dec 5, 2015
    4,376
    Cypress, TX
    Off the top of my head, the Protaper Adventure bars. Not sure if you'd want the high ones it not. Check the measurements.
    lqgsrider likes this.
  2. William Wolfen
    Dec 5, 2015
    4,376
    Cypress, TX
    I can't say I'm looking forward to doing it, but I don't have the $1000 to pay someone for work I can do, nor do I trust anyone else to do it properly. I've been under the tank, but never any further. It'll be an adventure, I'm sure. Hopefully my knuckles survive.
  3. DaleE
    DaleE TransAlp Adv
    Jan 13, 2006
    792
    Boulder, CO
    Just do yourself a favor and drain/remove the radiators. The official procedure just calls for moving them slightly out of the way, but the suggestion on a detailed procedure here to remove them eventually was the right way to go.
    windowto and Honda-50 like this.
  4. Veeblefetzer
    Veeblefetzer Been here awhile
    Mar 1, 2019
    181
    Squornshelous Zeta
    It'd definitely do-able. I think I listened to the commenters on the internet (Gah!) who said the valves at 16K are usually fine and convinced myself I didn't really need to pry the cover open to find that out. As it turned out the exhaust valves were a bit out at 18K mi., but those I think are screw adjusters? I don't have the manual with me to look that up.
    Here's my incomplete checklist of the steps (missing the parts about the radiators, throttle bodies) needed for just getting to the valve check. Also at 16 / 32K mi. there's all the other periodic maintenance; spark arrester, oil change, yadda
    (Page numbers refer to my copy of the shop manual.)
  5. William Wolfen
    Dec 5, 2015
    4,376
    Cypress, TX
    Oh I'll be doing it, easy or not. Just not for another 12k miles or so!
  6. leethal
    leethal 3 wheel Monarch #37
    Oct 14, 2008
    566
    Mornington peninsula, Melbourne
    One hose off and move radiators aside...easy. My bike I removed the coil tray without removing the throttle bodies....hard to do. On my sons bike I removed the throttle bodies....easy peasy.
    Not a hard job but a slow and tedious one. Hardest part is connecting a couple of hoses.
    Most dangerous part is relocating the valve cover.........get it on the dowls or break it.
  7. Olde Phart
    Olde Phart Olde Phart
    Mar 3, 2018
    776
    Land of Oro y Plata
    In the "Just because you can doesn't mean you should" department, I poached this pic from over in the https://advrider.com/f/threads/over...olorado-aug-27-29-2021.1515434/#post-42914818 thread:
    :fpalm
    So many problems here ... note the chafing from interference on the top of the front fender and the complete lack of bracing on the 90 degree angle bends. It'll fatigue crack there and the whole thing will fall off in short order if it doesn't roach the battery first.
    Any one of the rope/block/tackle/pulley self rescue kits are far superior to this mess.
    Good keeping it simple to ya!
    DCTFAN and Amphib like this.
  8. lqgsrider
    lqgsrider Been here awhile
    Dec 22, 2009
    887
    Lower CA Desert
    After 4 years and 16K miles my right front fork seal is leaking. I have an extended warranty from Honda is this something that would be covered?
  9. bbanker
    bbanker Been here awhile Supporter
    Feb 24, 2011
    599
    Beautiful NC
    Probably not. A few have had luck with that under warranty, but mostly they are considered consumables...
    moparren and lqgsrider like this.
  10. Olde Phart
    Mar 3, 2018
    776
    Land of Oro y Plata
    Most likely considered a wear item and not warrantable ... as @bbanker remarked some have had success but their seal failure occurred in the first few thousand (or even a few hundred in my case) miles of ownership. I limped it along by cleaning the seals periodically but finally bit the bullet and replaced them myself. Some folks have gone with other than OEM seals preferring other brands.
    For reasons mysterious to me, the local dealer gave me pushback on trying to order the factory spring compression tool so I bought the Race Tech Spring Compression Tool along with the correct size seal driver and seal bullet. That dealer meritoriously earned a spot on my shit list and lost my business to online parts suppliers.
    With these tools, the job is not that difficult and can be performed in a few hours.
    Good DIY'ing to ya!
    windowto and lqgsrider like this.
  11. Black99S
    Black99S Been here awhile
    Dec 30, 2012
    531
    Vancouver, Canada
    Read your warranty document - it will state what is covered and what is considered a 'wear' item.
    Good luck!
  12. PistolPetey
    PistolPetey Been here awhile Supporter
    Dec 17, 2009
    367
    Wild West BC
    This is good advice.
    Warranty or not, I recommend a fork service and swap both seals at the same time. I’ve had great results with SKF seals on my twin, through lots of mud, dust, etc. I think it also makes a big difference to clean your forks regularly when they get dirty to prevent the bad stuff from migrating up into the seals themselves.
  13. swimmer
    swimmer armchair asshole
    Oct 9, 2007
    19,918
    Tucson, AZ
    Where did you get your SKF seals from?
  14. William Wolfen
    Dec 5, 2015
    4,376
    Cypress, TX
    I used some Kawasaki seals on my first Twin. Much easier to source than SKF and double sided, unlike the stock ones. Worked great until I killed the bike. I also use full length forksavers to keep the inners clean.
    Veeblefetzer likes this.
  15. PistolPetey
    Dec 17, 2009
    367
    Wild West BC
    I got them through my local shop. I can’t remember if they had them in stock or they had to order them. This was pre-COVID so I’m not sure if supply chain problems might be an issue to get them now.
    swimmer likes this.
  16. mentolio
    mentolio King of the island of unwanted toys...
    Jul 14, 2016
    1,490
    I second the Kawasaki seals. Way better than stock!
  17. swimmer
    Oct 9, 2007
    19,918
    Tucson, AZ
    My OEM seals aren't leaking, I just want to swap them out for something else to try to get rid of the stiction problem I have. I was under the impression that the SKF seals were more likely to help with this problem. I believe some people also had to shim their bushings to get rid their stiction problem. Being a lighter rider I feel like my weight is making the feeling of a sticking fork more pronounced. On the street the best ride I get is with zero preload on the front.
  18. Nomadic_adv
    Nomadic_adv Been here awhile
    Oct 31, 2019
    232
    N GA
  19. swimmer
    Oct 9, 2007
    19,918
    Tucson, AZ
  20. Bike Guy
    Bike Guy Long timer
    May 20, 2005
    1,411
    sierra foothills, hwy 49
    A few months ago I had a leaky fork seal. The serví writer said it was a consumable item. I told him i disagreed and then I told him it was a safety issue. It was replaced without a charge
    windowto likes this.
