The Africa Twin CRF1000L Owners' Thread
Discussion in 'Land of the Rising Sun: ADV Bikes from Japan' started by erey, Dec 20, 2015.
  1. michaeln
    michaeln What're YOU lookin' at?
    Jul 30, 2007
    3,584
    Avery, State of Jefferson
    I used them on my AT too. I think it is prudent to put a small drop of LocTite 242 or 243 on the allen head setscrew threads after arriving at the final fastening of the weights.
    windowto and ya(x2) like this.
  2. procycle
    procycle Long timer
    Jun 7, 2007
    5,034
    Center of the DualSport Adventure universe
    :-) Yeah, I've had a few moments. This setup is not by choice. I needed a rear tire when I was at the AIMExpo in Columbus a week ago and the Motoz guys were kind enough to comp me their only tire in the correct size. I packed it 1000 miles to New Mexico to squeeze every last bit out of the stock rear and give the Tractionator a fighting chance to get me home to Oregon.
    ya(x2) likes this.
  3. blalor
    blalor Been here awhile
    Sep 13, 2015
    424
    RVA
    How'd it fare? I've heard great things about the mileage of those tires…
  4. Zave
    Zave ******
    Jun 16, 2014
    1,424
    BC Canada
    Great timing i need some yesterday i just order a set from Good Bang only $30 canadian hope they come as ordered
    ya(x2) likes this.
  5. procycle
    procycle Long timer
    Jun 7, 2007
    5,034
    I can't say yet. I have 1000 miles on it and need another 1500 to get me home. I did promise the Motoz guys I would give them a full report back with photos at the end. I've been making a tread depth (knob height) measurement every 3 fillups. The first 500+ miles it barely wore at all. Like 0.020". I thought wow this thing is wearing like iron! The second 500 miles it lost a good 1/8" and now I'm a little concerned about it going the distance. 90% of that mileage is 2-lane paved roads, 60-65 mph and 90 degree temperatures.
    If you want mileage the Tractionator Adventure is a much better choice than the Desert H/T.
  6. -mek-
    -mek- Been here awhile
    Jul 21, 2009
    194
    Oulu, Finland
    The bars of my AT has also been twisted, allready from purchasing this former dealer demo bike a year ago. I tought it's the forks that are twisted when the dealer had changed the Karoo 3's under it and I could correct it when changing tires. I Changed new tires on summer, following the manual and carefully humping the forks before tightening the front wheel axle. No help. I've been busy at work and used my scarce free time for riding, so I've almost got used to the bars being twisted to right, about 1" measured at the bar end. I've got very long arm's ("ape index" + 4", also my fathom is 4" longer than my lenght) so twisted bars bothered me not so much. A week ago I got my bike to the first, 12 000 km service and also asked them to check the fork alignment, no help either.
    However, then I saw this thread on AT-Forum and began to investigate the problem a little bit closer. When looking the bars of my bike on the top and comparing the bars to upper fork bridge, it's clear that the bar is twisted in relation to upper fork bridge, also the reason must be on the lower bar holders or their bolts. I looked the rubber grommets under the bar holders, but the niche between the bar holder and the bridge is even, so I guess the bolts are not bent. I'm thinking to dissassemble the bars and holders during the winter and investigate the problem closer, but it's allready clear that the reason for twisted bars is between the bars and the upper fork bridge.
    I've dropped my bike only once, when making U-turn on soft sand, and it had not any dropping marks after being a demo bike, so the bars being twisted may just be the nature of these bikes. :hmmmmm
  7. craighkzn
    craighkzn Been here awhile
    May 8, 2016
    822
    South Africa
    Just loosen the main clamp bolts under the top triple (that go through the rubber mounts), as well as the bar clamp bolts, re-align, and re-torque....mine have been straight now for the past 20 000km
    -mek- likes this.
  8. windowto
    windowto Long timer
    Jun 18, 2012
    2,885
    NJ
    Mek,
    Just go to the left steering stop and force the bars further left with a moderate force. You'll be surprised, but you can reposition them that way. The rubber mounts do allow some movement there.
  9. craighkzn
    May 8, 2016
    822
    South Africa
    I found this only worked for a while and the bars would slowly go out of alignment again (you're just twisting the bars in the top clamp, putting the rubber bushes under load....)....once the main mounts are loosened and re-aligned, problem has gone for good...But your method works great to re-align when you crash in future..
  10. arrcrussell
    arrcrussell Gimme Dirt
    Sep 8, 2005
    1,140
    NE OH, USA
    Dang - :baldy - I was crashing on the other side just to tweak the bars back straight!
    Black99S, blalor, CrStep and 2 others like this.
  11. windowto
    windowto Long timer
    Jun 18, 2012
    2,885
    NJ
    Make sure you crash an even amount of times on both sides and at the same speed:D:lol3:muutt
  12. Reidy008
    Reidy008 I,m in if we go fast
    Jan 6, 2010
    3,686
    Peoria, AZ
    If you loosen the bots on the bar clamps and then get the bars where you want them you will be set. The bars can seem twisted just by not being straight in the clamps.
  13. dwj - Donnie
    dwj - Donnie Long timer
    Apr 26, 2006
    19,099
    North Carrollton, MS - Traveling on the Moto
    I hope it is OK that I post this here!
    We are on a one month plus into a two month trip and the tires I expected to last till I arrived to my daughter's house in the Dallas, Texas area where I have another set waiting, looks like they aren't going to last that long! We are currently in the San Francisco, California area and looking for tires. Ideally, I want Shinko 705s, 90/90-21 and 150/70-18 tubeless. Continental TKC70s or the OEM tires for the African Twin will work as well. For the record, at 8,453 miles, the rear TKC70 has little life left and the front is badly cupped. The rear has not seemed to show any wear in the last 500 to 600 miles, but I still have 2,000 miles to go! The OEM tires were replaced at 10,297 miles and had at least another 500 miles in them, which is why I expected the TKC70 to last till Texas.
  14. Reidy008
    Jan 6, 2010
    3,686
    Peoria, AZ
    Wish you were close you would be welcome to my stock tires.
    neanderthal likes this.
  15. lqgsrider
    lqgsrider Been here awhile
    Dec 22, 2009
    803
    Lower CA Desert
    I just purchased a 2017 AT in the red/black/white.
    Will post some pics later
    I'm 6'2" and looking for a larger windscreen and larger foot pegs.
    Has anyone bought the Givi windscreen?
    Any suggestions?
  16. lqgsrider
    Dec 22, 2009
    803
    Lower CA Desert
    Anyone have any experience with this product?
    Givi Trekker Outback 42 Liter Top Case
    What adaptor do I need to attach it to my OEM rack?
  17. FTWeather
    FTWeather KISS army 1976
    Mar 18, 2010
    26
    Fresno, CA
    Got a set of stockers with about 5k on them in Fresno, CA you are welcome to?
    Tiger-Mike, sick_boy and dwj - Donnie like this.
  18. neanderthal
    neanderthal globeriding wannabe
    Nov 26, 2006
    3,611
    Here, but lost. Am I lost if i know i'm here?
    If you're looking to get rid of them i'm taking all comers.
    While I managed 15k with my first set last year, the new bike, one month old now, already with 8500 miles on it, may not make it to 15000 miles on the OE tires.
    Cheers.
  19. neanderthal
    Nov 26, 2006
    3,611
    Dealer trying to tell me they recommend an oil change every 4000 miles today.
    Do I look like I was born yesterday? Nah fam, i'll take it elsewhere.
    twinrider, NSFW and windowto like this.
  20. mcmann
    mcmann Motorcycle ADV enthusiast
    Nov 17, 2006
    3,784
    Jefferson, GA
    Why not change it yourself?
    You can recycle your oil at most Auto Parts facilities etc.
    For riders that ride under 8,000 miles/year . . . they still should change their oil/filter annually . . .
