The Africa Twin XRV650 & XRV750 thread
Discussion in 'Japanese polycylindered adventure bikes' started by iswoolley, Aug 23, 2004.
  1. jethrocephus
    jethrocephus His Honorable Right Minister of Flying Monkeys Supporter
    Nov 6, 2004
    700
    In the Bonus Round
    Greetings all, very close to having my new/ used AT ready for the road.
    My cowl has a couple sketchy repairs, any chance of anyone having or knowing the whereabouts of one? Looks like this:
    ExplorerFrog and US7IGN like this.
  2. US7IGN
    US7IGN HAM radio n00b
    May 3, 2014
    307
    Ukraine
    Many of us have it in worse condition, but who cares...
    Andreim92 likes this.
  3. Andreim92
    Andreim92 Lost
    Dec 10, 2016
    125
    RO
    I would not even bother haha, it looks great!
  4. North Thai Biker
    North Thai Biker Been here awhile
    Oct 18, 2004
    255
    Hawaii, Las Vegas
    Ebay
  5. andrius7
    andrius7 n00b
    Jun 9, 2020
    4
    Vilnius
    Had a nice trip in estonian TET
    2383DC42-BFDA-4C12-AC8A-7569E679303C.jpeg 548FC25B-9C79-491C-99BE-6B98525CBD5A.jpeg 548FC25B-9C79-491C-99BE-6B98525CBD5A.jpeg
  6. AllBlackPearl
    AllBlackPearl Alpoholic
    Nov 9, 2008
    834
    (working on getting out of) London, UK
    andrius7 likes this.
  7. teddy750
    teddy750 Adventurer
    Jan 17, 2012
    56
    THESSALONIKI GREECE
    thanks i'll give it a go some time next month
  8. xVampear
    xVampear n00b
    Jun 27, 2020
    1
    Poland
    You mean exhaust? Figaroli. I have it. Sounds really nice :) IMG_20190716_082613.jpg
    PedroCH, jethrocephus and US7IGN like this.
  9. mxersraz
    mxersraz Adventurer
    Jun 9, 2010
    14
    Crete, Greece
    Finally... There we go
    AT Club Hungary, Joz, PerGrus and 3 others like this.
  10. Andreim92
    Andreim92 Lost
    Dec 10, 2016
    125
    RO
    :photog
    Now thats more like it , it seems like it can really take a beating, the suspension seems very good and seems to have really high bottoming resistance. Btw , post some of the pictures you took , like the one in the thumbnail.
    P.S. Thank you very much , I appreciate it :beer
    mxersraz likes this.
  11. PedroCH
    PedroCH King of Kings
    Jun 18, 2015
    261
    Switzerland
    Getting ready for Albania and whatever other countries are open :clap:clap
    Geschütz geladen! :y0!
    Joz, boboneleg, US7IGN and 5 others like this.
  12. andrius7
    andrius7 n00b
    Jun 9, 2020
    4
    Vilnius
    Joz, boboneleg, US7IGN and 3 others like this.
  13. Hodgo
    Hodgo TWIN Cylinder ADV
    Jul 2, 2009
    1,794
    Brisbane
    Hello Fellow Old AT riders. I have removed the circlips but......
    Anyone know the part number to stop this from leaking ? and or the procedure to stop it from leaking ?
    RD07 1995 S Model.
    cheers
  14. mrfixit54016
    mrfixit54016 Wisconsin Dual Sporter
    Jan 19, 2008
    879
    Hudson, WI
    Hodgo.
    You need 2 O-rings:
    91306KK4003
    OEM Honda O-Ring 18x2.6 - RD03/04/07/07A (1988 - 03)
    £2.63
    You can order these from Rugged Roads and then just use a long screwdriver to slide that metal tube coupler to one side and then use a small dental pick to remove the old O-ring and install the new O-ring. Apply just a small amount of lithium grease or petroleum jelly on the new one. Next you would slide the coupler to the other side and replace the second O-ring the same way. Then move the coupler back to the center and replace your clips. Done!
    Good Luck!
    Joz, jethrocephus and DunkingBird like this.
  15. plumer1kt
    plumer1kt Adventurer
    Feb 11, 2015
    1,346
    Hellas
  16. mrfixit54016
    Jan 19, 2008
    879
    Hudson, WI
    A Video? That is like cheating!
    Just kidding. Nice Job plumer1kt.:clap
    stavrouliasp and plumer1kt like this.
  17. Hodgo
    Jul 2, 2009
    1,794
    Brisbane
    that is awesome thanks guys. Really appreciate the help.
  18. VACommuter
    VACommuter Long timer
    Jul 11, 2009
    5,516
    King George, Virginia
    Camping trip over the holiday weekend.
    Fully loaded.
    All set up.
    Joz, Andreim92, US7IGN and 2 others like this.
  19. EemilH
    EemilH n00b
    Jan 31, 2020
    5
    Finland
    Hi guys.
    I'm having a weird issue with the bike not running smoothly. On idle it pops a somewhat louder sound intermittently, and when riding at a steady pace at low speeds the running is not steady and at high speeds it intermittently almost like stalls for a half a second, somewhat like stepping on the rear brake a bit. Also it's losing power on higher rpm.
    I've traced the issue to the rear cylinder getting too much fuel or bad spark. The front spark plugs seem fine but rear plugs are all black and sooty (not oily).
    Here's what I've done already with no effect on the symptoms:
    • fuel filter bypassed momentarily
    • fuel pump bypassed momentarily
    • Air filter removed momentarily
    • Fuel lines seem to be OK with no kinks or obstructions
    • Carbs:
      • First, a comprehensive clean
        • Floats seem to move fine
      • Second, vacuum pistons and seals replaced (one seal was a bit tired and worn looking) (new)
      • Third, rebuild kit with jets, main and pilot, pilot adjustment screws, springs and washers, and the float valves with seats (new)
      • pilot adjustment set to OEM
      • None of these had any effect
    • Spark plugs replaced (new)
    • Ignition coils and spark plug wires replaced. Not to new ones, but to a different set from a parts bike.
    • CDI unit replaced (new)
    • Valve clearances adjusted to tolerance
    • Signal generators read the same amount of resistance on both cylinders
    Has anyone battled it out with these kind of issues and come out on top?
    I'm running out of ideas and so are the mechanics I have used as phone consultants over the weeks.
    -Eemil
    AllBlackPearl likes this.
  20. plumer1kt
    Feb 11, 2015
    1,346
    Hellas
    Three things you didn't check.
    • Vacuum hoses -check for leaks/replace
    • Carb intake boots-use silicon or wd40 and spray on them while engine working.Any difference?
    • Air-cutoff valve -If stuck or leaking produces symptoms like yours.Check the Haynes manual and/or google it for more help.
    DunkingBird, PerGrus and EemilH like this.
