The Albatross: 1150GS Sidecar Build
Discussion in 'Hacks' started by PowderMonkey, Jun 2, 2018.
  1. cycleman2
    cycleman2 Long timer
    Jan 18, 2010
    1,544
    Alberta, Canada
    I can relate. My wife said the same thing a few years ago when I brought home my sidecar rig. Since then every year we've gone on a trip and last year on our sidecar trip out west she fell asleep in the car, twice in the same day. So never doesn't always mean never.
    squizzy likes this.
  2. Ridn3
    Ridn3 Lopsidd
    Feb 18, 2015
    442
    S.W. Virginia
    I was told that also so I spent a couple of months with a friend building a subframe for the airhead. My friend passed away and another friend helped me finish it. After it was finished, the very same day, she said " if you want me to ride in it, you need to put it on the other bike (oilhead). I spent hundreds of dollars and another few months moving it to the Oilhead. At least she rides with me, now on a Kbike rig.
  3. davebig
    davebig Another Angry Hun !
    Jan 19, 2004
    11,039
    Minnesota
    Damn ! I was wondering why I never got married :hmmmmm
  4. GerardW
    GerardW Adventurer
    Apr 2, 2019
    80
    Port Elizabeth
    Now I can relate to what PM said earlier. Last night I installed the actuator. Its mesmerizing. Sat playing with it for about 5 minutes.
    PowderMonkey and rg sw wa. like this.
  5. GerardW
    GerardW Adventurer
    Apr 2, 2019
    80
    Port Elizabeth
    just can't help myself
    [youtube]
    [/quote]
  6. GerardW
    GerardW Adventurer
    Apr 2, 2019
    80
    Port Elizabeth
    Hey PowderMonkey, are your spots direct connected to battery with external switch or did you wire it into the ignition ? If the latter, from where did you pick up the power ?
    I usually pic
    k up from the taillight, but am already running the cars taillight direct from it so do not want to over load it.
    FLYING EYEBALL and rg sw wa. like this.
  7. FLYING EYEBALL
    FLYING EYEBALL out of step
    Mar 18, 2008
    12,424
    north of seattle
    #trimlyfe
    Bobmws likes this.
  8. Gestalt
    Gestalt Been here awhile
    May 6, 2018
    871
    China/Thailand
    I wanted to ask has anyone ever taken a Ural and fitted modern BMW parts to a Ural sidecar unit. Engine, drivetrain, wheels pretty much everything to a modified frame ? I ask as I know the Ural has reliability issues and build quality issues (Opinions vary I know) but the Ural is a good looking bike and a modern BMW can be purchased for reasonable money ? A bike which is basically a BMW in a Ural frame would be sort of a reliable cool looking side car unit ?
  9. Bobmws
    Bobmws Curmudgeon At Large
    Jun 6, 2005
    4,280
    Same trailer, different park, FL
    Ask PowderMonkey: https://advrider.com/f/threads/r100-powered-ural-6k.1412052/
    rg sw wa. likes this.
  10. PowderMonkey
    PowderMonkey Been here awhile
    Jun 13, 2015
    315
    Maine
    Bobmws and rg sw wa. like this.
  11. GerardW
    GerardW Adventurer
    Apr 2, 2019
    80
    Port Elizabeth
    Boot frame came out very nicely
  12. PowderMonkey
    Jun 13, 2015
    315
    Maine
    I swapped my wire wheels for a used set of ohlins that I intend to rebuild and re-spring.
    @twintwin graciously shared info on the shocks he had built for his 1100gs rig. I’m probably going to follow his path, unless steered in another direction. Obviously, no height increase in the front.
  13. PowderMonkey
    Jun 13, 2015
    315
    Maine
  14. PowderMonkey
    Jun 13, 2015
    315
    Maine
    Spots are on a separate circuit, using an eastern beaver relay setup. I don’t see why you couldn’t use the tail to trigger a relay? The voltage draw would be negligible.
  15. GerardW
    GerardW Adventurer
    Apr 2, 2019
    80
    Port Elizabeth
    Tub is done welded. Still have to do a neat finish, but that an wait for next year. I have to get it on the bike by this weekend and certified next week to be ready for our year end tour. All the stuff around it is ready to be installed.
  16. DRONE
    DRONE Dog Chauffeur
    Oct 1, 2007
    8,995
    Tacoma - ish, WA
    About that rear Ohlins, the one I used for my 1150GSA was set up to "Adventure" length and the spring was a 79/190 -- which in "Ohlins-speak" means 1085 lbs/inch, or 19.36 kg/mm. Of course now, I'm a big guy, but I don't carry as much stuff as a lot of guys when I'm fully loaded for camping, so maybe it evens out. Anyway, I liked my 79/190 set up the way I described it in that post you drudged up from above.
    PowderMonkey, davebig and rg sw wa. like this.
  17. davebig
    Jan 19, 2004
    11,039
    Minnesota
    Though I laughed at DRONE several years ago about his spring rate, after weighing my r1150gsa at each wheel and consulted Klaus at EPM Perf and ended up with the same sort of spring.:-)
  18. PaulRS
    PaulRS Dutch fool
    Apr 15, 2008
    1,508
    Holland, land of tulips and wooden shoes
    Just for the record.
    I ended up with a rear spring by Hyperpro, progressive spring rate 250-380 N/mm.
    I myself measure 190 cm, 110 kg.
    Paul.
    rg sw wa. and PowderMonkey like this.
  19. DRONE
    DRONE Dog Chauffeur
    Oct 1, 2007
    8,995
    Tacoma - ish, WA
    I was around 110kg in my 50's, and I'm not too far off from that now, but can that 250-380 N/mm be right?
    The rear HyperPro on my R1200GSA had a 198-292 N/mm spring. That makes your 1100 spring 25% heavier than my 1200 spring.
    rg sw wa., brstar and PowderMonkey like this.
  20. PaulRS
    PaulRS Dutch fool
    Apr 15, 2008
    1,508
    That’s what the man said.
    Paul.
    PowderMonkey and brstar like this.
