The Albatross: 1150GS Sidecar Build
Discussion in 'Hacks' started by PowderMonkey, Jun 2, 2018.
  1. PowderMonkey
    PowderMonkey Been here awhile
    Jun 13, 2015
    315
    Maine
    Mike,
    Not my subframe. That part was DMC, as it saved me some fab time. There’s so much adjustability there, I’m not sure that it matters? I never would have thought of that, if it were to be a better mousetrap.
    Seth
    rg sw wa. likes this.
  2. arbalest
    arbalest Long timer
    Mar 19, 2009
    1,148
    Windham, Maine
    Seth,
    Not the subframe. I misspoke. I would think the sidecar frame would need to be level when the bike is laden
  3. PowderMonkey
    Jun 13, 2015
    315
    Maine
    Oh! Of course! This is all mock-up. It’ll be done the right way when it goes together for good. I figured it was close enough for now. Half of what I do seems to be one step forward, and two steps back.
  4. REBORN
    REBORN Adventurer
    Nov 27, 2014
    85
    estern Ontario
    I went in front of the cylinder on my 95 gs just posted picture on the aluminum 95 build thread
    rg sw wa. and PowderMonkey like this.
  5. PowderMonkey
    Jun 13, 2015
    315
    Maine
    Where does that put your offset on the sidecar wheel?
  6. REBORN
    REBORN Adventurer
    Nov 27, 2014
    85
    estern Ontario
    12" ahead
  7. PowderMonkey
    Jun 13, 2015
    315
    Maine
    That’s about where mine is too.
  8. REBORN
    REBORN Adventurer
    Nov 27, 2014
    85
    estern Ontario
    image.jpeg Here is a picture of my setup the frame has a mounting point for the strut extending about 2 1/2"
    Hi-De-Ho, PowderMonkey and rg sw wa. like this.
  9. PowderMonkey
    Jun 13, 2015
    315
    Maine
    Does anyone know what the bmw hardline connections are? Are they 10mm x 1.0 like the banjo bolts? Or are they some sort of BST/NPT nonsense?
  10. davebig
    davebig Another Angry Hun !
    Jan 19, 2004
    11,643
    Minnesota
    The ones I just replaced on one of the K's was 10 mmx 1.0 I think that is the regular Euro brake thread.
  11. PowderMonkey
    Jun 13, 2015
    315
    Maine
    That’s the answer I was hoping for.
  12. DRONE
    DRONE Dog Chauffeur
    Oct 1, 2007
    9,755
    Tacoma - ish, WA
    Hardline connections? What are you talking about -- the brake line connections to the ABS pump? If yes, then just ordinary metric. I don't recall the diameter and thread pitch (though 10x1.0 sounds about right).
    Hi-De-Ho and rg sw wa. like this.
  13. PowderMonkey
    Jun 13, 2015
    315
    Maine
    Yessir.
  14. Old Mule
    Old Mule Long timer
    Mar 24, 2013
    1,575
    Overland Missouri, home of 1950s sidecar tech.
    I think that that connection could be straightened and simplified- just my opinion.
    rg sw wa. and brstar like this.
  15. PowderMonkey
    Jun 13, 2015
    315
    Maine
    Alright. So, some progress has been made. I bought some shocks off the fleamarket for an RT, gas charger stockers with springs for a sidecar setup. Everything seems legit after install, but I don’t know if it’s just my mind playing tricks, but that shit seems super low. I’m at 6” even for ground clearance at the rear portion of the skid plate. Honestly, I didn’t measure with what I started. All I can say, is it looks low. Interestingly enough, the front shock is exactly the same length as what came off the front . Anyone have any measurements from their bash plate? Maybe it’s worth getting just the rear shock?
    Meanwhile, I forged ahead with the forward mount fabrication. I found some sw Motech crash bars on eBay for cheap, and thought I might be able to repurpose them for the front mount. It work d out better than I imagined. I still have the lower mount to connect to the lower subframe, but I think this will be super solid. IMG_4041.jpg IMG_4044.jpg IMG_4043.jpg IMG_4046.jpg
    Hi-De-Ho likes this.
  16. PowderMonkey
    Jun 13, 2015
    315
    Maine
    Also, I bought a new welder to get used to:
  17. PowderMonkey
    Jun 13, 2015
    315
    Maine
    Can any of you GS based sidecar owners tell me what kind of clearance you have under you subframes? I probably should have measured this before I swapped out the shocks....
  18. davebig
    Jan 19, 2004
    11,643
    Minnesota
    I have to believe lower is better for the tug , I'm not in favor of where the front upper attaches to the sidecar frame even DMC quit doing that so it must be a problematic idea.
    I would consider losing the SW Motech bars , building a curved front adjustable bar to the front mount it would need to be moved to adjust valves and if at all possible the threaded bits need to go at the bottom. Just my .02 DB
  19. PowderMonkey
    Jun 13, 2015
    315
    Maine
    Dave, thanks for the input on height. The crash bar will be used for the forward mount of the sidecar. It’s gonna get a middle brace to the other side. It attaches to all the same points that a forward subframe would, and is 1/8” tube, so I’m gonna use it.
    rg sw wa., Hi-De-Ho and davebig like this.
  20. PowderMonkey
    Jun 13, 2015
    315
    Maine
    Finished up the crash bars and forward mount. I may still make a brace forward, below, or above the telelever. IMG_4050.jpg IMG_4058.jpg IMG_4056.jpg
    I also mounted the other side, and attached everything to the lower subframe. Seems rugged.
    triumphsidehack and davebig like this.
