THE BIGWHEEL THREAD!!! Yamaha BW350, BW200
Discussion in 'Thumpers' started by Mr. BigWheel, Feb 4, 2011.
  1. greasyfatman
    greasyfatman Long timer
    Oct 18, 2014
    5,017
    You can start one here or in Some assembly required. I get to NC a few times a year hope to see your build, dig me some two strokes.
    https://advrider.com/f/forums/some-assembly-required.83/
  2. greasyfatman
    Oct 18, 2014
    5,017
  3. 1enick72
    1enick72 n00b
    Jan 14, 2012
    1
    BW 225 project started. My vision is to match my YZ with new Yamaha colors and graphics. Plastics will be blue with white and black graphics. TTR 225 engine 6 speed. Hope to be finished by the end of winter. Has anyone upgraded the rear shocks on a 200? I'm only 150 lbs and could use a little softer ride without letting too much air out of the tires.
    RebelYell, Bucho and terriblemog like this.
  4. bikerbill2021
    bikerbill2021 Adventurer
    Oct 10, 2014
    26
    Phoenix AZ
    Well that was fast, got me a BW80 coming to me from a friend back east, he actually was able to find two of them, but they are ROUGH to say the least lol. However I have been spending a ton of time researching them and will get mine back to former glory with some neat little hop ups. My buddy will build his back east so kind of having a fun little build off, albeit a slow one lol
  5. sixpepper
    sixpepper Been here awhile
    Jan 25, 2013
    201
    atlanta ga
    Hey 1enick72, I also did a 225ttr in a BW frame, wondering what kind of boot you used to connect the air box to the carb. any pics of the area?
    dkom95 likes this.
  6. greasyfatman
    Oct 18, 2014
    5,017
    Was that sold out of GA? I think I looked at them.
    I am down for some BW80 solo cup racing? Keep us up to date on your build. I have just put another one together.
  7. terriblemog
    terriblemog Been here awhile
    Oct 23, 2009
    129
    Nice! I saw your post on one of the facepage bigwheel groups!
  8. bikerbill2021
    Oct 10, 2014
    26
    Phoenix AZ
    lol yup, my buddy in NC was looking for one for me and found those, like i said they are rough, total resto, really not much to them left, but the important bits like the extended out put shaft, swingarm, front end, side cover etc are all there
  9. Quick10
    Quick10 n00b
    Nov 30, 2020
    3
    North carolina
  10. dkom95
    dkom95 KLRk Kent
    Jul 14, 2012
    112
    Columbus, OH
    I'm using a piece of straight EPDM radiator hose with 1-3/4" ID. It fit nicely onto the Blaster carb inlet. Hole sawed a new hole in the BW airbox lower than the original so the hose had a straight shot from the airbox to the carb. Took the piece of plastic I cut out, trimmed it to size, and used it to patch the original hole with the help of some JB weld plastic epoxy.
  11. bikerbill2021
    Oct 10, 2014
    26
    Phoenix AZ
    Got my BW! Total POS, but it'll be a good little project to tinker on. Got too many irons in the fire at the moment so trying to get these other bikes/machines done, but not totally deplete my project cache, this will give me something to play with after dinner for during the week nights
    Kind of weird how it showed up, my buddy put everything in a big heavy duty bin, and it showed up with everything in that box and the frame just on its own. Nothing damaged or lost, just odd, maybe the crate broke and UPS re-boxed it? Idk, but I'm happy that whoever at UPS did repack took the time to do it right, have had bad experiences with them in the past fucking up packages, as I'm sure most of us have
  12. greasyfatman
    Oct 18, 2014
    5,017
    Box O Bee Dubs nice.
  13. dkom95
    dkom95 KLRk Kent
    Jul 14, 2012
    112
    Columbus, OH
    She lives. Hooked the wiring up and had no trouble getting spark. We were off to the races from there.
    Completed:
    -Cut and reset the downtube. Welded up some front brackets. Build to ride, not to win pageants.
    -Installed 12mm ID / 16mm OD bushings at the rear engine mount / swingarm bolt. They went in without issue.
    -Made a spacer to fill the 8mm empty space remaining on the rear mount bolt. Pushing the engine all the way right aligns the output shaft sprocket with the inner jackshaft sprocket.
    Trouble spots remaining:
    -Switched primary chain and sprockets from #50 to 530. Swingarm adjustment is worthless, and mine is seized anyway. Need to find the right sprocket combo for chain tension. Can make tooth count adjustments at the final drive.
    -Carb needle valve refuses to stop pissing fuel despite cleaning, checking, and calibrating following protocols on Blaster forums. Ordered a new one for install.
    -Exhaust is going to scorch my leg unless I wrap it up
  14. terriblemog
    Oct 23, 2009
    129
    50 and 530 are pretty much the same, 530 higher quality or more refined I guess. If you have new chain and sprockets, tension should be fine. Not looking for guitar string tight.
    dkom95 likes this.
  15. dkom95
    dkom95 KLRk Kent
    Jul 14, 2012
    112
    Columbus, OH
    Totally agree. Problem is it's either too tight to connect, or so loose it's dragging on the frame. I hear the issue is fairly common.
    Has anyone heard of a Honda ATC tank fitting a BW200? Something like this <--
    I believe I saw someone on a BW fbook page claiming a stock ATC tank of this era fits right up.
  16. greasyfatman
    Oct 18, 2014
    5,017
  17. onnalee
    onnalee n00b
    Feb 20, 2021
    1
    gatineau quebec canada
    Hey there all. We are in process of rebuilding our 4th BW200 and have run across a snag. We are looking for a Voltage regulator for the electric start model part #1RL-81960-90-00. Does anyone know where we can find one? Thanks.
  18. dbarale
    dbarale Squiddly slow
    Oct 20, 2008
    2,982
    Western NC
    Sooooooo, I just rebuilt my son's PW80 and I just might could be picking up a BW80 project soon.
    Two main issues: are there any replacement plastics available? Are there any tires (doesn't have to be stock) available?
  19. greasyfatman
    Oct 18, 2014
    5,017
    Yes to both plastics and tires are out there. White and black plastic are available. Off the top of my head things that are a problem. Seat pan, gas tank, air boot, any of the chain guard, left side cover.
  20. greasyfatman
    Oct 18, 2014
    5,017
    I am not far from western NC if you decide to pass on it give me a heads up. A dirt nasty one popped up here I may grab for parts.
    dbarale likes this.
