THE BIGWHEEL THREAD!!! Yamaha BW350, BW200
Discussion in 'Thumpers' started by Mr. BigWheel, Feb 4, 2011.
  1. dbarale
    dbarale Squiddly slow
    Oct 20, 2008
    2,977
    Western NC
    Thanks, the one I am considering looks like it has PW plastics on it (blue), which I am sure don't fit well. I need to go see it "in person".
    What size tires fit?
  2. greasyfatman
    greasyfatman Long timer
    Oct 18, 2014
    5,008
    19 to20.5 6x10 front
    18 7x7 rear may go bigger if you move the shock mount
    also can chang rim size but it’s not worth it. 3752AB37-0A46-4FCD-B90A-0ACD6B8C42C7.jpeg B72D81E8-DE8B-46AB-B8C4-6B6C27200821.png 75A9088D-B9E7-4C3B-BDC8-835F51D1B8F8.jpeg
    dbarale likes this.
  3. terriblemog
    terriblemog Been here awhile
    Oct 23, 2009
    129
  4. greasyfatman
    Oct 18, 2014
    5,008
    Pro taper xr50 I think I will double check when home.
    also using the klx 110L what ever the taller klx is brake cable. The old one fits but should you have to replace it.
    terriblemog likes this.
  5. carramrod
    carramrod n00b
    May 1, 2019
    1
    Canada Eh'
    Hi guys! I am hoping to get your opinions on a deal I am considering for a BW200 (non electric start).
    I'll be going some time next week to have a look at this unit, it is currently not running (I will check to see if it is seized when I see it in person)
    From the pictures I can see that it is missing:
    -Handle bars
    -Front Forks
    -Front Brake assembly
    -Front Hub
    -Front wheel & tire
    -Chain guard
    -Rear tail light lens
    -Both side panels
    -Looks like the clutch lever is there but it is missing the perch
    -Jack shaft chain
    -Will need a new seat cover and possibly foam
    With all the above in mind the seller wants $500 for it.
    Do you guys think this is a money pit given the amount of parts that are missing and the state of the bike?
    Do you think $500 is a reasonable price given the state it is in?
    Is this thing a better parts bike?
    Since the front end is missing it almost seems like the best route to go is to put the front forks from the Honda ATC250R since they are the same price on ebay and I will get the benefit of a disc brake upgrade at the same time, thoughts on going that route?
    PS - The seller claims that running units are selling for $5,000.... I don't believe that one bit am I wrong?
    Thanks in advance!
      File size:
      117.3 KB
      32
      File size:
      113.3 KB
      32
      File size:
      286.6 KB
      32
      File size:
      86 KB
      32
  6. terriblemog
    Oct 23, 2009
    129
    He's smoking something good. Now as for the 500, may not be too bad. As long as the motor at least is free and not locked up. good odds it isn't far from running.
    Nathan_66 likes this.
  7. greasyfatman
    Oct 18, 2014
    5,008
    @dbarale
    did you get that BW80? Looks like another one popped up near you.
  8. Nathan_66
    Nathan_66 Been here awhile
    Dec 30, 2018
    287
    Riding There...
    The xr50 handlebars are great, I definitely recommend them on the bw80
    The black bike looks fantastic with the blue/white decals! I been busy with work but expect to do some more modding soon. The clutch hub bearing was shot, thanks for the heads up on that. I ended up cleaning the original hub. The new one wasn't exactly the same and I like the shiny silver look better anyway.
  9. greasyfatman
    Oct 18, 2014
    5,008
    I did some clutch tuning. And removing balls doesn’t help. I have added springs to all available slots and will add extra balls. With the stock amount of balls it locks up and will power wheelie. It climbs a little better. Will try more balls than stock.
  10. GarlicGreg
    GarlicGreg n00b
    May 19, 2020
    8
    Gilroy Ca
    Cleaning out my parts bin. I have a pretty decent condition BW200 fuel tank. Some weather checking but serviceable with good color. No leaks. Thought I would offer up here before going to auction site. 20210307_165715.jpg
  11. terriblemog
    Oct 23, 2009
    129
    how much are you wanting for it?
  12. GarlicGreg
    GarlicGreg n00b
    May 19, 2020
    8
    Gilroy Ca
    Because of size, shipping is around $40. So I'm at $225 Shipped ConUs.
  13. Squamch
    Squamch n00b
    Oct 22, 2018
    5
    Vancouver island
    Well my 3 year old was bugging me to bring my motorcycle out riding with him on his KDX50. So I dug the old BW out from behind the shed, welded a kdx200 muffler on, cleaned the carb and we headed to the gravel pit.
    After riding for a bit, I remembered that I'd parked and tarped it because of the bad oil leak from behind the swingarm pivot.
    So I brought it home and started disassembling. I have an air filter, front drive sprockets and chain, in my shopping cart, just gotta flash it up tomorrow after work and see where she leaks from, then I'll know what I'm dealing with as far as parts needed to keep the oil in the case.
    I've always said that when it comes to vehicles for fun, if it's not old, weird, or broken, I'm not interested.
    Bucho and greasyfatman like this.
  14. Squamch
    Squamch n00b
    Oct 22, 2018
    5
    Vancouver island
    So...are the case gaskets for these obtainable? Or can I get away with a tube of RTV?
  15. terriblemog
    Oct 23, 2009
    129
    Yes. :)
  16. Nathan_66
    Dec 30, 2018
    287
    Riding There...
  17. stewart1353
    stewart1353 n00b
    Jan 2, 2016
    6
    North Carolina
    I am sure there are discussions on here about starter motors but clearly, I am not doing the search the right way.
    I have an 87 350 and it looks like the starter motor has crapped out, good battery, new relay, and when I tap on the motor it tries to go. If there was a reasonable aftermarket I would just try that but the OEM is a pricey roll of the dice. Have people had these rebuilt or is there an aftermarket that is reliable? it also looks well buried in there.
  18. Doink!
    Doink! 54 ATV bikes since 2002
    Jan 5, 2012
    170
    central SC
    Stockers.com has new units for the 200 and 350. You'll have to call them, their search doesn't list the BW by model.
    greasyfatman likes this.
  19. sixpepper
    sixpepper Been here awhile
    Jan 25, 2013
    201
    atlanta ga
  20. sixpepper
    Jan 25, 2013
    201
    atlanta ga
