The CLUNK gremlin...
Discussion in 'Hard. Core. (1090/1190/1290)' started by BuffHunter, Sep 6, 2015.
Does your 1290SA clunk when topping out or crossing speed bumps? Check all that apply.
  1. Yes; when topping out.
    69 vote(s)
    41.8%
  2. Yes; when crossing speed bumps.
    93 vote(s)
    56.4%
  3. No; Clunk? What's a clunk?
    44 vote(s)
    26.7%
Multiple votes are allowed.
  1. BuffHunter
    BuffHunter Been here awhile
    Apr 11, 2014
    763
    Parker, CO
    Do they really ALL do that?
    KTM Customer Care number 1-855-215-6360,
    Leave your VIN and name or it does not count.
    jrc58, MUDHWY and Rob barnes like this.
  2. NewToMe
    NewToMe safety 3rd
    Apr 2, 2014
    1,863
    Big D
    Only when the steering head bearing is not snug.
    AlexHawnPhoto likes this.
  3. Sparc145
    Sparc145 '14 1190 ADV
    Mar 18, 2014
    301
    Washington
    What he said.
  4. Katoum
    Katoum Adventurer
    Feb 26, 2004
    760
    British Columbia, Canada
    My 1290 continues to transfer a metallic clunk (topping out) and I have adjusted the head bearing twice, 11500 km and its done it since new.
  5. Latebraking
    Latebraking Been here awhile Supporter
    Feb 28, 2015
    165
    SoCal
    My service department has run the gauntlet three times while trying to address / fix this clunk issue. Steering head bearing tension, remove & hang upside down the forks overnight, ECU / software checks, and KTM even overnighted a set of forks they said were tested to be 'in proper working order'. No change, as 'the clunk' is still there. One other thing I also noticed is that 'the clunk' all but disappears when the 'offroad' damping selection is activated. It is all documented in their maintenance system. In the meantime, while I don't hold my breath while waiting for a solution, I ride. "Clunkily"......
  6. KTM 1190advR
    KTM 1190advR Enema of the state Supporter
    Aug 2, 2015
    3,419
    Somewhere in Norway
    Perhaps on the side but I have a clunky front end on my 1190r as well. I've traced it to come from the floating brake-discs...
    Al
  7. Latebraking
    Feb 28, 2015
    165
    SoCal
    Mine definitely has nothing to do with brake discs.
  8. BuffHunter
    Apr 11, 2014
    763
    Parker, CO
    Ditto, sounds like the damping mechanism has vertical clearance inside the tube.
    #8
  9. KTM 1190advR
    Aug 2, 2015
    3,419
    Somewhere in Norway
    Aha, clearly different from mine then.
    Best of luck to all of you with solving an annoying issue!:baldy
    Al
    #9
  10. Korndogg
    Korndogg Been here awhile
    May 30, 2012
    403
    I hear it on mine, but I'd say it's pretty rare. Not something I'm hearing all the time. Damping mode seems to make a difference too. I'm often in Comfort but many have reported it's more pronounced with other settings.
    I'm most likely to hear it if I'm on a curb and ride off. I think I hear it as the suspension maxes out. Lifting the front wheel doesn't have the same effect though - strange.
    #10
  11. IgorBorisenko
    IgorBorisenko adventurer
    Jan 20, 2014
    101
    Ljubljana
    Had a 1290 for test ride. It surely did clicking sound from the forks. Looks like an active suspension feature =)
    #11
  12. Cactusbasher
    Cactusbasher Adventurer
    Jan 15, 2016
    22
    Litchfield Park, AZ
    My dealer adjusted my head bearing yesterday, but now it's WAY too tight. Is this a user-adjustable deal and if so, is it as simple as removing the big nut on the top of the triple clamp then loosening the stearing head nut?
    #12
  13. BuffHunter
    Apr 11, 2014
    763
    Parker, CO
    Yahoo!
    KTM NA just called me back. He says they have a fix - replacing the right side rebound cartridge.
    They got the fix from Austria, and are testing it on 2 NA customer bikes right now. If the fix seems reliable there, they'll call me back and arrange the warranty work. Fingers crossed!
    My bike has already had the steering stem bearing tightened and the front rim straightened, so I guess they figure I'm another good test case.
    #13
    Toy hauler likes this.
  14. sflash868
    sflash868 Been here awhile
    Jun 26, 2008
    197
    Yeah last time I spoke to KTM NA about the clunk in the forks that results form the forks topping out, they said it's something that all the bikes do (referencing 1290s) and is part of the active suspension design. I was told they were working on a fix and would issue a "service bulletin". Like the issue with the fuel sensor.. even though the part is defective, they aren't going to email you to bring the bike in and change it. Mine crapped out at 2K miles and only then was I told there was an updated part. Some people seem to not notice the clunk or aren't riding in a manner that causes the forks to exhibit the issue so I imagine only a hand full of bikes would get a rebound cartridge if that was the fix. I sure as shit notice it though..
    #14
  15. BuffHunter
    Apr 11, 2014
    763
    Parker, CO
    Yeah, and my fuel gauge is currently stuck at a FULL.
    #15
  16. airwater
    airwater Been here awhile
    Jul 16, 2005
    728
    N 41°39'42.51" W 4°44'03.34
    :fpalm
    #16
  17. Latebraking
    Feb 28, 2015
    165
    SoCal
    I think mine is the other getting this part in NA, then. My bike is going in to the shop on Tuesday, so Wednesday, I will know if it's a fix, or not. KTM would not give any details on how it is different, only that its a 2016 part.
    #17
  18. BuffHunter
    Apr 11, 2014
    763
    Parker, CO
    Yep, the 2016 detailed parts list shows new tubes in both sides of the forks, but they seem to be trying to cheap out the warranty fix by replacing one. If it fixes the apparent problem I guess I'll be happy, but I can't help but wonder how much better it'd be with both new parts installed. Going by history their willingness to put one in under warranty is outside the norm.
    #18
  19. Latebraking
    Feb 28, 2015
    165
    SoCal
    It makes sense to do it this way, since the rebound stroke is where the problem is. If it fixes the problem, then I'm happy. If not, then we keep trying to find the source of the issue.
    #19
  20. jrc58
    jrc58 Been here awhile
    Jun 21, 2015
    374
    Spain
    Please let me know when you know something.
    joaquinrichter@gmail.com
    #20
    BuffHunter likes this.
