The CLUNK gremlin...
Discussion in 'Hard. Core. (1090/1190/1290)' started by BuffHunter, Sep 6, 2015.
Does your 1290SA clunk when topping out or crossing speed bumps? Check all that apply.
  1. Yes; when topping out.
    68 vote(s)
    42.5%
  2. Yes; when crossing speed bumps.
    92 vote(s)
    57.5%
  3. No; Clunk? What's a clunk?
    40 vote(s)
    25.0%
Multiple votes are allowed.
  1. paidoutcomes
    paidoutcomes Long timer
    Jul 30, 2014
    1,423
    Fargo, ND
    Mine is more of a click than a clunk on my 1290. I swapped bikes with an 1190 owner and he noticed the click right away. No issues so far so I am not too worried about it. If the cartridge fix is proven then I may hit my dealer up on it.
    #21
  2. BuffHunter
    BuffHunter Been here awhile
    Apr 11, 2014
    763
    Parker, CO
    The clicking went away on mine after they tightened the stem bearings. Sorry, but I can't remember if you've had that done yet. But I guess one man's click could be another man's clunk.
    #22
    paidoutcomes likes this.
  3. jrc58
    jrc58 Been here awhile
    Jun 21, 2015
    365
    Spain
    Mi KTM 1290 ADV tiene el apriete exacto, 50 Nm, y hace un "clic" en el tenedor al pasar una pequeña Baden.
    [​IMG]Subido en imagenes Subir
    #23
  4. BuffHunter
    Apr 11, 2014
    763
    Parker, CO
    I think that's a clunk! :-)
    #24
  5. Latebraking
    Latebraking Been here awhile Supporter
    Feb 28, 2015
    162
    SoCal
    I just got a call from my dealer / service manager. He says the replacement cartridge has finally exorcised the clunk from the fork. I'll pick it up after work tonight & experience it first hand.
    I'm jazzed!
    #25
  6. Latebraking
    Feb 28, 2015
    162
    SoCal
    I noticed from the first day the issue about the clunk in the fork. It has been a long process that required analysis, much trial and error and a set of forks overnighted directly from KTM. None of these efforts yielded a solution, but did make clear what the root of the problem was. Something in the fork was not right. Every step of the way, my dealer who sold me the bike - Ken & Joe's Honda, Kawasaki & KTM - were on the issue and in constant communication with KTM NA. They were always proactive, calling whenever there was new information or a new approach to the issue. As of yesterday, the issue has finally been laid to rest. Installing the right side fork cartridge from the 2016 1290 Super Adventure is the answer. Finally, I have a motorcycle that feels whole! I no longer have to think to myself how great the bike is - except for the forks....
    If you're looking for a dealer who understands the problem and knows how to fix it, give them a call at 661-254-2929. Ask for Jim in Service. Jim & the service dept are switched on. Even if you're not in the area and your dealer could use some direction on the problem, have your dealer call my dealer.
    #26
    hanskter2 and SURFINASPHALT like this.
  7. jrc58
    Jun 21, 2015
    365
    Spain
    OK.
    When you say "right cartridge" he is sitting on motorcycle ???
    #27
  8. Bundu
    Bundu KTM 1290SA
    Aug 5, 2010
    976
    Pretoria, South Africa
  9. jrc58
    Jun 21, 2015
    365
    Spain
    I know that is the reference 48SAF1P26R.
    But you know as you look?
    Sitting on the motorcycle?
    Standing in front of the motorcycle?
    #29
  10. Bundu
    Bundu KTM 1290SA
    Aug 5, 2010
    976
    yes, right is right as when seated on motorcycle
    #30
  11. MUDHWY
    MUDHWY Simple Math
    Jun 4, 2014
    13,317
    The Edge Of Town
    Going to be looking into this with KTM since my dealer needs help. What's the contact number you guys in NA are using?
    #31
  12. Latebraking
    Feb 28, 2015
    162
    SoCal
    Yes, jrc58, it would be rider's right, as you sit on the motorcycle.
    #32
  13. Latebraking
    Feb 28, 2015
    162
    SoCal
    Call my dealer, MUD. 661-254-2929, ask for Jim in service, he can steer you or your dealer in the right direction. We're in SoCal.
    #33
  14. woodsguy
    woodsguy KTM Aficionado
    May 25, 2008
    145
    Huntsville, Tx
    Well, is problem actually solved? thanks
    #34
  15. Latebraking
    Feb 28, 2015
    162
    SoCal
    Yes, it is actually solved. Please refer to post # 26 above. Thanks.
    #35
  16. Veteran1
    Veteran1 Been here awhile
    May 18, 2014
    155
    Could you ask your dealer if the forks must be removed, or if the RHS cartridge can be removed and replaced from the top in situ ?
    There is one bolt holding the cartridge in at the bottom.
    Ps, mine clunks a lot.
    #36
  17. gsuks
    gsuks Long timer
    Oct 13, 2014
    1,600
    wilnis de ronde venen nederland
    One thing I would like to know
    Did your bike suffer from high speed weave before your clunk was fixed?
    If so
    Has the clunk fixed it?
    Verstuurd vanaf mijn SM-N910F met Tapatalk
    #37
  18. MUDHWY
    MUDHWY Simple Math
    Jun 4, 2014
    13,317
    The Edge Of Town
    +1. Another interested owner here.
    #38
  19. Latebraking
    Feb 28, 2015
    162
    SoCal
    My dealer removes the fork from the bike. I don't think it could be done with the upper tube remaining on the bike, due to the length of the cartridge and clearance to the floor. Getting the fork oil level correct also would be impossible during the assembly, if it goes by mm from the top, because the fork needs to be vertical to measure oil level accurately. If it goes by quantity, then it maybe could be done this way, but I doubt it.
    #39
  20. DirtJack
    DirtJack Adventurer Supporter
    Aug 12, 2007
    3,326
    395 miles South East of Orla, Texas
    And the spring must be removed and the fork completely collapsed.
    #40
