The Compleat Yamaha TY80 Thread!!
Discussion in 'Trials' started by Brewtus, Apr 28, 2010.
  1. lineaway
    lineaway Long timer
    Oct 1, 2011
    12,115
    nm
    Hate to tell you, but that is a GT80. Not a Ty 80.
  2. Brewtus
    Brewtus Buffoonery, Inc.
    Jul 30, 2008
    7,546
    Portales, New Mexico
    GT tank, seat, bars and pipe anyway. Maybe a "bitsa", but can't really tell.
    Norman Foley likes this.
  3. UstaKood
    UstaKood Been here awhile
    Feb 5, 2016
    538
    Michigan
    Yep . Frame /motor should have #451 prefix .
    Brewtus likes this.
  4. upperleft
    upperleft Been here awhile
    May 17, 2015
    132
    pnw
    Yeah I guess it must be a gt80 or mx80? The vin is 367-1007xx. Anyone know what that means? Sounds like all these models share the same engine parts. What are the differences? Just the frame?
    This engine needs a complete rebuild and has a crack on one of the engine cases. I think I have everything I need on order. Just need to find a local shop to bore out my cylinder. Does anyone know what CCs a +1.50mm (48.5mm) bore would be?
    Is there anything I should do or look at while doing the rebuild? Plan to clean and inspect everything and maybe some paint on the cases. I will work on getting it running like it should then move on to the suspension making it look half decent.
  5. Brewtus
    Jul 30, 2008
    7,546
    367 prefix is a GT80. :thumb
    upperleft likes this.
  6. upperleft
    May 17, 2015
    132
    pnw
    Thanks. Do you know of the gt and ty engine cases are the same?
  7. Brewtus
    Jul 30, 2008
    7,546
    Dunno. Probably. Never had a GT80. We've had a couple of TYs that had GT80 top-ends on them, so they probably are. As far as primary and gear ratios go..... :dunno
  8. UstaKood
    Feb 5, 2016
    538
    Michigan
    Far as I know ( which admittedly is well .. ) Most parts are interchangeable .
    Trans ratio's different and I suspect different cylinders ( a good gt ,"gitz' pretty good )!
    Frame / triple clamps are different .
    But , if nothing else you'll have a good pit bike ! :thumbup
  9. upperleft
    May 17, 2015
    132
    pnw
    Thanks for the info. I also found a mx80 in my area I might pick up of they come down on the price a little. Really I would like to eventually have 2 of these bikes. One for me and one for the fiance. It is always helpful to have 2 bikes that share spare parts.
    It would be great if anyone could list out all of the differences between the ty, dt, and mx.
    I am a little disappointed this isn't the ty but I think it will still make a fun play bike.
    Pm me if any of you are trying to get rid of extra parts. I could probably be talked into buying a bunch of stuff I don't need.
    Thanks again for all the info.
  10. Brewtus
    Jul 30, 2008
    7,546
    'Nudder top end ready to go. Piston and cylinder will be sent to Albuquerque Monday morning for bore work. Fabbed up a crank seal driver out of PVC since I had the lathe all fired up.... :D
    Norman Foley, Junglejeff1 and Huzband like this.
  11. Ymirtrials
    Ymirtrials Long timer Supporter
    Jan 12, 2012
    1,351
    Ymir BC Canada
    I often worry when I see a carbide in the die grinder next to what likely was a good cylinder....:hmmmmm
    :D
    jonnyc21 and Brewtus like this.
  12. Brewtus
    Jul 30, 2008
    7,546
    Just knocking down some casting "gravel", that's all. Nothing too outrageous going on here, nothing to see, move along now..... :brow
  13. Brewtus
    Jul 30, 2008
    7,546
    Picking up the above top end on Friday at the MWVTA event in Colorado. In the meantime, another crankshaft/crank bearing replacement. The top end of this one was done just a couple of years ago, and the newfound compression made the old crank bearings very unhappy so......
    :D
  14. Brewtus
    Jul 30, 2008
    7,546
    One done, one to go.
    Top end assembled on the first one, fired it up in the chassis shown above, new crank and top end happy!! Discovered a wrist pin bearing falling apart in the second one, and the wrist pin was pretty unhappy. :confused Piston still fit in the bore nice but....
    New piston ordered to go on the fresh crankshaft/rod assembly. Hone the cylinder, and chuck it up in the lathe to take a nice shallow "skim" off the gasket surface that always makes the beer can gaskets smile -
    Everything going along just fine when ALL OF A SUDDEN the cut didn't sound so happy. The cutting edge of the tool decided to chip just then, making the rest of the pass look like an old Iron Butterfly album. Damn. Dressed the tool as well as I could, and a "skim" pass across the failure point made it.....better. Do I have another facing tool for the lathe? Hell no, why would I? Since I have several other bikes begging bench time, I went with an old standby. 220 grit sandpaper on a plane of glass, some Bel Ray 6 in 1, and time.
    Went ahead and planed the head too. Why not? There's no real rush, but I did want to get this one assembled and running by tomorrow (or thereabouts). After all if this bike doesn't run by tomorrow, we LOSE THE SHOP!! :rofl
    Both surfaces happy, and head gasket material ready for fab. :D
    Gotta get 'em ready to sit around this year after all. :thumb
    Lutz, LemmeTry, Huzband and 4 others like this.
  15. motobene
    motobene Motoing for 49 years Supporter
    Mar 9, 2013
    7,487
    ABQ NM & Wichita Mountains OK
    Nice work, Brewtus! Interesting your orientation the red carbide cutting tool in the tool post. It's faced in instead of the usual up. How the heck does it cut that way? Or is it a test to see who is paying attention?:y0!
    Beer can gasket. Interesting! I've used nothing but a mere skin of Silicone 1 if the squish isn't too narrow without a gasket.
    Brewtus and jonnyc21 like this.
  16. Brewtus
    Jul 30, 2008
    7,546
    Sharp eye. It was to see if I was paying attention when I threw it in the tool holder. Took the pic, went to start work, and "what the...." :eek7 What the heck, I wanted a set of indexable carbides anyway. :D
  17. motobene
    Mar 9, 2013
    7,487
    I just thought maybe I was missing some machining trick like skimming cross ways with the cross slide :-)
    Brewtus likes this.
  18. Brewtus
    Jul 30, 2008
    7,546
    Nope. The tool had been used the "other way" in the past, I think I just slapped it together wrong looking at the hold-down prints. In all honesty that tool wasn't in the best of shape to begin with, and my "dressing" of the bit didn't help one damn bit (I don't have a green wheel). Hey, it came with the lathe, and it was the only 1/2" tool I had to work with. Yeah, I fucked up. I'm man enough to admit it, who cares? :dunno
    :D
  19. jonnyc21
    jonnyc21 Trials Ninja
    Feb 8, 2011
    4,095
    Boise aria
    What’s life without a bit of self inflicted pain once in a while? :1drink
  20. Brewtus
    Jul 30, 2008
    7,546
    If it ain't smokin'..... :evil
    'Nudder teammates spare bike done. :thumb
    Huzband, jonnyc21, Lutz and 1 other person like this.
