The CRF1000L Africa Twin problem thread
Discussion in 'Japanese polycylindered adventure bikes' started by twinrider, Mar 18, 2016.
  1. twinrider
    twinrider Pass the catnip
    Aug 20, 2002
    17,920
    日本
    Post all your reports, solutions and questions regarding problems and concerns related to the new Africa Twin. :lurk
    Oeths, MrKiwi, krussell and 2 others like this.
  2. mcmann
    mcmann Adventure Rider Junkie Supporter
    Nov 17, 2006
    4,295
    Jefferson, GA
    Suggestion:
    If you live or ride near sea air or, where they salt the roads in the winter . . . and are concerned about corrosion (especially spokes) coat with cosmoline . . .
    http://www.cosmolinedirect.com
    http://www.cosmolinedirect.com/mili...otector-heavy-duty-long-term-rust-preventive/
    MILITARY GRADE - RUST PREVENTIVE (BIG 14oz AEROSOL CANS)
    Corrosion Preventive Compound, Solvent Cutback, Cold Application
    We use to reserve the sales of of our MILITARY-GRADE METAL PARTS PROTECTOR to Military and Government Institutions, but now offer it to anyone looking for a Long-Term, Extremely Durable Rust/Corrosion Preventative. Very similar to our popular Cosmoline Weathershed Aerosols, MILITARY-GRADE METAL PARTS PROTECTOR creates a Dry-to-the-Touch, Amber, Translucent, Petroleum Wax-based Coating that can stand up to the harshest, most extreme rust/corrosion-causing environments for years*. MILITARY-GRADE METAL PARTS PROTECTOR is an extremely resilient, fast-drying coating with a high melting point and self-healing/abraiding characteristics. MILITARY-GRADE METAL PARTS PROTECTOR is also highly resistant to salt water and salt spray (this product repels water and does not wash off in salt water environments.). MILITARY-GRADE METAL PARTS PROTECTOR will remain flexible over time and can protect any metal surface for years*.
    COMMON USES INCLUDE:
    Provides long-term rust and corrosion protection (indoors and outdoors) for:
    * Parts & equipment storage * Overseas transportation * Packaging * Heavy machinery & equipment * Farm implements * Vehicle undercarriage / undercoating (cars, buses, trucks, etc.) * Boat shafts and propellers * Marine fittings * Garden tools * Lawn mower blades * Battery terminals * and any other surface or part that might rust on you...
  3. jon t
    jon t n00b
    Dec 11, 2015
    3
    Greece
    Which product of cosmoline ....
  4. Maggot12
    Maggot12 U'mmmm yeaah!!
    Feb 21, 2010
    20,502
    Canada's ocean playground
    So when you're new honda shows up in June, you'll be ready with corrosive preventative liquid. I think i'd plastic dip the spokes red.
  5. BRAVADO77
    BRAVADO77 n00b
    Mar 18, 2016
    2
    California
    Most riders will use the wax version of Cosmoline. You can get it in concentrated form or aerosols which is a lighter coat. Both forms completely dry leaving a clear wax coating. Cosmoline Rust-Veto 342
    The other version you might consider is the Military Cosmoline Grease 11796. It also protects forever, but obviously doesn't dry...stays greasy.
    I've used this stuff since the 1980s. Not cheap, but nothing works better.
    WAX VERSION: http://www.cosmolinedirect.com/cosmoline-rust-veto-342-industrial-grade/
    GREASE/MILITARY VERSION: http://www.cosmolinedirect.com/mil-spec-grease-mil-c-11796c-class-3/
  6. amaunu
    amaunu Been here awhile
    Aug 29, 2007
    136
    Nokia, Finland
    Tectyl Glass Shelder. Count on it.
  7. DockingPilot
    DockingPilot Hooked Up and Hard Over
    Mar 24, 2004
    11,468
    Andover, N.J.
  8. vgreno2000
    vgreno2000 vgreno2000
    Dec 12, 2014
    237
    Huesca, Spain
    Spokes rust also happened on my S-10, and with only 4000kms and being very carefully.
    I think the only way to have them shining is to go with stainless ones.
    Enviado desde mi Nexus 5 mediante Tapatalk
    #8
    TeepS likes this.
  9. twinrider
    Aug 20, 2002
    17,920
    日本
    Mine stayed clean for 60,000 km but they don't salt roads much in Japan where I am.
    A few S10 riders went with stainless and ended up with broken spokes. They have to be a lot bigger in diameter to be strong enough, like the ones Woody sells on his custom wheels.
    #9
    SmittyBlackstone and vgreno2000 like this.
  10. Capt CF
    Capt CF Pontificating Nobody
    Jul 1, 2013
    1,299
    Northern Virginia
    I don't much care about the spoke issue, but there are a lot of reports on the Africa Twin facebook group of problematic switchgear. Nothing like the out of control wheelie problems, but a lot of reports of buttons sticking and requiring replacement. I haven't seen any specific posts yet if the part numbers are the same, but I would anticipate this being a recall item at some point if it is as widespread as it seems.
    #10
  11. mcmann
    Nov 17, 2006
    4,295
    Jefferson, GA
    Sounds like silicone spray helps with the sticky set button issue:
    http://www.africatwinforum.com/foru...neral-discussion-forum/4585-sel-buttom-2.html
    "I have a manual gearbox, so to me it was only the "set" buttom that got stuck. It is a doubtfull construction of the plastic stuff which gives too much friction when there is some water or dirt run in. The silicone spray lubricates the plastics. Much better than WD40 or Castrol DWF as, these products have a lot of solvents. They lubricate only a very short period, and afterwards the plastic parts become even more sticky. That's why a silicone-based lubricant is more apropriate to my opinion. Works fine !"
    #11
  12. twinrider
    Aug 20, 2002
    17,920
    日本
    I've been keeping up with this on various forums and have only read of a few cases out of the thousands of bikes sold. Mine has been fine and I ride in the rain.
    #12
    Capt CF likes this.
  13. Capt CF
    Jul 1, 2013
    1,299
    Northern Virginia
    Good to hear. It's probably just the reposting over and over again to every forum and then reposting those to the Facebook group that make it seem so widespread then. I'm still in line with my deposit so it hasn't scared me off, but electrical or transmission gremlins are one category of issue that definitely would concern me and have me second guessing it. If I wanted those kinds of problems I'd stop waiting for an AT and just go get an 1190R. :rofl
    #13
    zxrider11 likes this.
  14. dduelin
    dduelin Prone To Wander, Lord, I Feel It
    Oct 17, 2006
    2,991
    Shaft City
    The throttle looks and sounds like it was at idle during this entire incident but I cannot understand why at 0:8 he inexplicably turns the bars left and hits the blue wagon. After that the engine sounds like it remains at idle until revved at the very last moment.
    <iframe width="640" height="390" src="" frameborder="0" allowfullscreen></iframe>
    #14
    fjrden likes this.
  15. Mikemm
    Mikemm Long timer
    Feb 15, 2011
    2,986
    SE Florida
    maybe that white line/stripe is thick and he stopped on the edge, in which it kinda followed the contour of it? Was he bumped/pushed from behind? is there any backstory? I cant read that language....
    #15
  16. Cruz
    Cruz Lost but laughing.
    Nov 3, 2008
    14,113
    Northside Brisbane, Qld Australia
    Watching the video makes little sense of what may have happened.
    What was reported to have happened there?
    #16
  17. Mojo73
    Mojo73 Adventurer
    Nov 6, 2007
    34
    Brisbane, Australia
    Looks to me like he slowed to a halt feet up, started to roll backwards, then tried to gas it.
    #17
  18. cuss
    cuss Adventurer
    Nov 28, 2006
    64
    uk
    From google translate comments under the vid, Near. Rain cover for the shoe is implicated in the footrest and I could not take off her feet.
    So think he went to put his foot down and his waterproofs were caught on something and over he went?
    #18
  19. dduelin
    Oct 17, 2006
    2,991
    Shaft City
    This is what I understand the narrative was: "His left boot's rain cover has entangled in the foot peg and he couldn't put down his foot.
    (Google translate from: - "Ochraniacz przeciwdeszczowy na buta się wplątał w podnóżek i nie mogłem zdjąć nogi.")"
    #19
    Karpinero and cuss like this.
  20. bozo92
    bozo92 Been here awhile
    Aug 14, 2015
    103
    F-Paris
    My biggest problem is that, to date, I didn't experience any of those exposed here. I hate arriving at destination because DCT is so much fun and seamless.:happay
    #20
    artbone, GOTSIG, squonker and 2 others like this.
