The CRF1000L Africa Twin problem thread
Discussion in 'Land of the Rising Sun: ADV Bikes from Japan' started by twinrider, Mar 18, 2016.
  1. twinrider
    twinrider pass the catnip
    Aug 20, 2002
    15,509
    日本
    That's what they're doing but it's still not fixed after a year of intermittent tries.
  2. Motociclo
    Motociclo Long timer
    May 18, 2017
    1,091
    Oz.
    Has Tech given you a break down on what has been done? just curious.
    Guessing only happening when hot?
  3. craighkzn
    craighkzn Been here awhile
    May 8, 2016
    822
    South Africa
    Cush drive rubbers is total non-issue.....mines been the same for 1000s of miles
    Drum Dog and Motociclo like this.
  4. twinrider
    Aug 20, 2002
    15,509
    日本
    ECU/DCT resets for the first three times. The last time they did that plus gave the bike an overall inspection, valve clearances set, spark plug wires checked (one replaced).
    Always happens when it's warmed up, and only stalls when pulling away from a standstill when I start to open the throttle. Sometimes it can happens several times in a week, other times it can be 1,000 km or a lot longer between stalling episodes.
  5. Motociclo
    May 18, 2017
    1,091
    Oz.
    They are persistent with ecu reset. Clearly not problem. Does it restart straight away or need time to sort it self? If taking a while to start again, possibly coil issue. I would check a few connections as well.
    I am guessing it runs fine when up and running?
    It could be the things I mentioned earlier. If running ok when going, unlikely fuel issue, leads me towards tps or a connection issue.
    Tps can be adjusted. I have seen bikes run odd with tps out of adjustment and not throw a code. But if it is failing replacement only option.
    Other option is MAP sensor.
  6. Motociclo
    May 18, 2017
    1,091
    Oz.
    Dodgy battery or a parasitic drain. Need to test for both.
    Parasitic drain can be hard to track down though if it is the case.
  7. kokos79
    kokos79 Nomad
    Apr 13, 2009
    801
    Greece
    Do you measure low voltage at the battery posts or is it discharged because it won't start the bike? If it is the former then as Motociclo says it is a faulty battery or some parasitic drain. If it is the latter then it's just a matter of loose connections. You will need a simple multimeter anyway, to check the battery voltage (don't rely on the onboard voltmeter as a loose connection will provide a false reading) and to troubleshoot any parasitic drain.
  8. mcmann
    mcmann Motorcycle ADV enthusiast
    Nov 17, 2006
    3,777
    Jefferson, GA
    Due to Hazmat regulations, many mfgs have switched to Factory Activated (sealed) batteries. In place of acid pack batteries (sealed after activating). The longer a FA battery sits without a charge . . . the weaker the battery etc.
    I have purchased new FA batteries that had set in the warehouse too long and were dead on arrival (not accepting a charge). I prefer acid pack batteries. . . which are more expensive to ship . . . but fresh after activating.
    Here is some battery info:
    http://www.yuasabatteries.com/pdfs/TechManual_2014.pdf
    Junglejeff1 and michaeln like this.
  9. dwj - Donnie
    dwj - Donnie Long timer
    Apr 26, 2006
    19,099
    North Carrollton, MS - Traveling on the Moto
    Not a moto problem, but maybe some of those folks that took the OEM tires off and refuse to use them live in the San Fransisco, California area.
    We are on a one month plus into a two month trip and the tires I expected to last till I arrived to my daughter's house in the Dallas, Texas area where I have another set waiting, looks like they aren't going to last that long! We are currently in the San Francisco, California area and looking for tires. Ideally, I want Shinko 705s, 90/90-21 and 150/70-18 tubeless. Continental TKC70s or the OEM tires for the African Twin will work as well. For the record, at 8,453 miles, the rear TKC70 has little life left and the front is badly cupped. The rear has not seemed to show any wear in the last 500 to 600 miles, but I still have 2,000 miles to go! The OEM tires were replaced at 10,297 miles and had at least another 500 miles in them, which is why I expected the TKC70 to last till Texas.
  10. Pipe dreams
    Pipe dreams Adventurer
    Sep 18, 2016
    86
    Are you coming through southern California?
    I have a set of low mileage OEM's you can have.
    dwj - Donnie likes this.
  11. LeeGro
    LeeGro Adventurer
    Jun 4, 2016
    43
    Texas
    My bike will not start. I turn the key to the on position, everything lights up like normal. No indication that it is low on battery but then when I press the start button it just clicks repeatedly. Its like something is preventing it from starting. I disconnected the positive terminal on the battery to reset the ECU but that did not fix it either.
    Any ideas?
  12. Motociclo
    May 18, 2017
    1,091
    Oz.
    What is battery voltage? Just sounds like flat battery. Generally no indication battery is flat until you try to start. The dash read out probably only uses 5 volts to light up, unless battery is a rock, it will likely still run through start cycle.
    If not that, check connections from battery through to solenoid to starter. Voltage drop test these things will show up problem. Check earth circuit also.
    Sometimes solenoids go bad, but rarely.
    windowto and chrshale like this.
  13. Pipe dreams
    Sep 18, 2016
    86
    My bike had a similar issue.
    Sometimes I would get a sluggish turnover when starting or instrument display would flicker while riding.
    Found that one of the battery terminals had buggered threads.
    although the connector bolt felt tight, I noticed I could move the cable and cause the lights to flicker.
    Ran a tap through the terminal and was able to properly tighten cable. problem solved.
    Wasn't sure if it was faulty since new or since I installed battery tender leads.
  14. michaeln
    michaeln What're YOU lookin' at?
    Jul 30, 2007
    3,584
    Avery, State of Jefferson
    Clean and tighten battery connections, including where the negative terminal goes to frame ground.
  15. alpergurevin
    alpergurevin n00b
    Oct 8, 2017
    1
    Uskumruköy
    I have same problem
    How did you fix this problem ?
    Tapatalk kullanarak iPhone aracılığıyla gönderildi
  16. Peke
    Peke Been here awhile
    Sep 14, 2007
    304
    The Netherlands
    Yes should be straight but they tend to bend.
    Ive got issues now with the starterbutton, starter disangages while I keept the starterbutton pressed. Happend twice today.
    And de set button appeared to be sticky once.
    Oh yeah and the spokes offcourse
    2017 model. Not very happy with the bike atm.:ace
  17. Rodooo
    Rodooo Been here awhile
    Mar 31, 2013
    143
    uk
    I’ve had that all changed on my 2016 model.
    Honda are useless at sorting out issues.
    Same issues on 2017 models
  18. LeeGro
    LeeGro Adventurer
    Jun 4, 2016
    43
    Texas
    Guys, is this normal? Could this be the reason my battery is not starting my bike? I watched the voltage on the battery go from 12.8v to 8v in a minute with the headlights on.[​IMG][​IMG]
    Sent from my SM-G930P using Tapatalk
  19. Squily
    Squily Squily
    Sep 18, 2006
    2,789
    Esperance WA (Down Under)
    Could be. If the plates bend/distort on the inside of the battery, the battery has an internal short. If memory servers correctly, most batteries have 6 cells of 2V each. If 2 cells short out, you are immediatly down 4V
    Motociclo likes this.
  20. michaeln
    Jul 30, 2007
    3,584
    So far, I see no evidence they even try.
