The CRF1000L Africa Twin problem thread
Discussion in 'Japanese polycylindered adventure bikes' started by twinrider, Mar 18, 2016.
  1. Nihon Newbie
    Nihon Newbie Weirdo
    Dec 13, 2012
    478
    SLO Cal
    That's what I thought. Bummer, I hate system faults like this. Thanks for the feedback, I'll report if I find a solution.
  2. Dillo
    Dillo Almost Awesome
    Aug 7, 2014
    1,067
    Massachusetts
    Similar story here. My dad dabbles in hobby carpentry but is utterly clueless with machines. I taught myself to fix bicycles in high school using a book from the library so I could get a job (and the included sweet discount) at a bike shop. Years later after i had just graduated engineering school I taught myself to work on my car using service manuals and Google because we were too broke to afford a mechanic. By the time I got into motorcycles doing all the work on my machines was just the norm.
    windowto likes this.
  3. Greg the pole
    Greg the pole There are no stupid questions, only stupid people
    Mar 1, 2011
    2,223
    Calgary, AB
    yep. It's the way to do it. But it's not for everyone. Some people aren't inclined, or interested in doing the work. Just riding. When something does go wrong, in the middle of no where...then..well shit.
  4. Lost Cartographer
    Lost Cartographer Been here awhile Super Supporter
    Feb 7, 2011
    756
    AZ and CA
    Amy update on this issue? Does your front abs still work? It's easy to test on grass fyi.
    If you accidentally figure out how to disable the rear abs there are a lot of us who would be interested in recreating your issue.
    Nihon Newbie and Amphib like this.
  5. Nihon Newbie
    Nihon Newbie Weirdo
    Dec 13, 2012
    478
    SLO Cal
    Disabling rear ABS is what the (pictured) button on the dash does. My issue is that regardless of what the indicator says, my rear ABS is not preventing wheel lock.
    I don't actually know if my front ABS is working, haven't actually tested it yet, but I'll do that today.
  6. michaelkozera
    michaelkozera Long timer
    Jan 11, 2015
    1,434
    calgary
    Are u sure u are doing if right? Like sure the rear was "harder" to change then the front but 2 good tire spoons and i had the rear changed in less then 5 mins. Add another 5 mins to balance the rear and back on she went.
  7. leethal
    leethal 3 wheel Monarch #37
    Oct 14, 2008
    438
    Mornington peninsula, Melbourne
    The walls of the new Shinko were so stiff it was difficult to keep the bead pushed onto the well. I needed clamps to squash the beads together and the force required to lever the tyre on was excessive. Felt like I was fitting a 17.5 tyre onto an 18 rim. Getting too old to put up with that crap on the side of the track somewhere.
    michaelkozera likes this.
  8. Muddler
    Muddler Long timer
    Dec 12, 2008
    1,128
    Dardanup, Western Australia
    Will a 140/80 x18” tyre tube work as a backup for the rear wheel? I have a couple of spare 140/80 tubes in the shed and I’m wondering if it would be folly to pack them as spares for a bush trip?
  9. Junglejeff1
    Junglejeff1 Long timer
    Oct 20, 2016
    4,621
    Upper Michigan
    5 minutes lol.Do you drink a lot.Between your outrageous milage you say you get and 5 minute tire change on this bike you must be one special person.
  10. michaelkozera
    Jan 11, 2015
    1,434
    calgary
    Would u like a video? Its not exactly rocket surgery lol
    To be more specific. 5 mins was just to change the tire, as mentioned above. Add an additional 5 mins to remove and install wheel. And after the 5 mins balancing aprox total time of 15 mins.
    as for the mileage. ive already provided photographic evidence of this "best case" fuel consumption. so please read the full post before you start commenting on something. as i will not be making a video of that.........Jesus.
  11. Junglejeff1
    Oct 20, 2016
    4,621
    Upper Michigan
    Yup,i want to see a video from breaking the bead on old tire to to putting air in new one.No way you do it in 5 minutes.No editing breaks with a timer running.Also just use tire irons.
  12. michaelkozera
    Jan 11, 2015
    1,434
    calgary
    Im happy to show inexperienced people how to change a tire. Ill be changing my tires on my crf500l in a few weeks here. Ill make a quick video.
    Glad to help out! Cheers.
  13. Junglejeff1
    Oct 20, 2016
    4,621
    Upper Michigan
    I hope i can learn how you could do it that fast.I only have 43 years experience working on bikes and need to learn.
    yokesman, leethal and michaelkozera like this.
  14. Wayward Gypsy
    Wayward Gypsy Been here awhile Supporter
    Jan 31, 2018
    179
    Texas
    Hearing a noise from the chain after switching out chain and sprockets. Chain isn’t too tight. What am I missing ?
  15. leethal
    Oct 14, 2008
    438
    I have 53.......and still happy to learn...........when I read it only took 5 minutes I thought he was talking about sex.
  16. Drum Dog
    Drum Dog Been here awhile
    Oct 18, 2015
    511
    Colorado
    Did you use oem parts. If not a OEM front sprocket that could be it.
  17. Greg the pole
    Mar 1, 2011
    2,223
    Calgary, AB
    Why do you say that? if the aftermarket sprocket is in line (both sides are typically symmetrical).
    I've run a 15T (twice), and I'm on to a new 16t Sustar sprocket.
    Do lube your splines with moly though!
  18. Wayward Gypsy
    Jan 31, 2018
    179
    Texas
    I'm not using OEM. Just a little unnerving. I only hear it around 30 MPH or so. It's a whirl/wizz, and no clunks or clangs.
  19. MikefromNL
    MikefromNL Long timer
    Dec 31, 2017
    1,228
    Vancouver
    I like to think I'm pretty darn quick at changing tires by hand. I change all my tires by hand, I've got a good method and lots of practice. I am quite happy if I can do a rear on my AT in 30 minutes on a hot day with warm tires and flat ground. Hell, every now and then I spend 10 minutes just trying to get the rear wheel and that damn spacer to fit in the swingarm.
    I would be very impressed to see a tubed tire change by hand from flat to rolling again in 15 minutes on AT rims and with cold proper stiff walled ADV tires.
    If you've got a better method, I would love to see it (no sarcasm here, changing tires is a pain in the ass).
  20. Drum Dog
    Oct 18, 2015
    511
    Colorado
    IT is just a thought. Most aftermarket fronts don't have the rubber and can create more noise.
    Nihon Newbie likes this.
