1. Livestream NOW at 11AM PST / 2PM EST!
    Baldy Interviews + Noraly "Itchy Boots" from Youtube YouTube Live Chat here
    Dismiss Notice
The CRF1000L Africa Twin problem thread
Discussion in 'Japanese polycylindered adventure bikes' started by twinrider, Mar 18, 2016.
  1. Greg the pole
    Greg the pole There are no stupid questions, only stupid people
    Mar 1, 2011
    2,220
    Calgary, AB
    The popping is normal to the AT. My staintune slip on pops, with the OEM headers.
    I believe the AT has air injection, and that's what causes it. @Motociclo can confirm.
    Mine sounds about the same. With the baffle out, it's a touch too loud, but with the baffle in it sounds like a gopher farting through a pvc pipe.
    It's substantially lighter, and it was on the shelf, so cost me $50 to get the welding done for it, and never needs repacking. Win win.
    I don't know about their claim for no re-tuning. I'm running a pcv and it works well. I think it's a must for a full system.
    MiamiMotorcyclist and DCTFAN like this.
  2. Motociclo
    Motociclo Long timer Supporter
    May 18, 2017
    1,082
    Oz
    Popping is just fuel lighting off in exhaust.
    Air injection puts air in exhaust, mixes with any fuel present and lights it off. Emissions thing ti stop fuel screwing cat converter.
    It isn't really injection, air is sucked in.
    High speed, hot gas draws the air into exhaust. Venturi effect.
    DCTFAN likes this.
  3. DCTFAN
    DCTFAN 2019 CRF1000LD | 2016 CRF1000LD | Supporter
    Mar 17, 2016
    1,946
    GA
    Confirmed and agree.
    Just came back from a twisty ride and "like a gopher farting through a pvc pipe" mixed with all the popping sound will get old real fast.
    I just know I am going back to the OE slip-on but leave the cat-free piping.
    Don't think I can tell the weight loss contributing much to the ride.
    PS> put the carbon finish muffler up 4sale in Fleamarket $120 shipped
  4. Dillo
    Dillo Almost Awesome
    Aug 7, 2014
    1,067
    Massachusetts
    Mine does the same thing. I did the starter switch fix but that didn't resolve the issue. Anybody figured it out yet? My only guess so far is piston slap (Link)
  5. swimmer
    swimmer armchair asshole
    Oct 9, 2007
    16,674
    Tucson, AZ
    My '18 will sometimes have one or two stumbles within the first minute after a cold start. They are very short, like one cylinder misfire, and not something I think would cause a stall. The bike has about 1500 miles on it.
  6. Motociclo
    May 18, 2017
    1,082
    Oz
    Unlikely to be piston slap.
    These things run pretty lean. May just be on the too lean side for start up.
    I find only real time now, if going to stumble and stall, is if i haven't riden for a couple of weeks. Maybe a start and stall, then next fire, idling ok.
  7. Junglejeff1
    Junglejeff1 Long timer
    Oct 20, 2016
    4,509
    Upper Michigan
    Mine has always stumbled when cold cleans up pretty quick after it hits 1 bar on heat gauge. Today wifey and me were hitting a back road we like I was thinking how much I like the g2 throttle grip I put on because of the low end lean condition.Thing really helps when running on the low end torque.
    Gemel likes this.
  8. Motociclo
    May 18, 2017
    1,082
    Oz
    Never used a G2. No doubt good in tight slow work.
    A cough and a fart when cold no biggy.
    Junglejeff1 likes this.
  9. Amphib
    Amphib A mind is like a parachute....
    Sep 19, 2018
    3,453
    Wnc
    I think that would be highly unlikely. It's just something I noticed on mine... Same experience as Jeff and motociclo. If that's all yours is doing, I wouldn't worry about it at all.
  10. twinrider
    twinrider Pass the catnip
    Aug 20, 2002
    17,347
    日本
    Mine ran better once I installed the booster plug.
  11. Junglejeff1
    Oct 20, 2016
    4,509
    Upper Michigan
    Mine still hick ups a bit when cold even with plug.It does run better with booster plug.
  12. Lost Cartographer
    Lost Cartographer Been here awhile Super Supporter
    Feb 7, 2011
    752
    AZ and CA
    You're a lot better at tire swaps than I'll ever be.
    I'm not the original poster, but yes way too much. Yooper genetics dontcha know.
    Tire on the rim (but I already broke the bead) at 5:33pm and 56 seconds:
    5:36.13- Old tire off in 2 minutes and 17 seconds:
    5:40.33s - New tire on ready for air 4 minutes 20 seconds later (that 705 is a surprisingly stiff tire):
    Total time: 6 minutes 37 seconds of actual work + 2 beers + surfing ADVrider instead of balancing the assembly = about 2 hours or so....
    :photog
  13. swimmer
    Oct 9, 2007
    16,674
    Tucson, AZ
    That's a hell of a lot faster than I can do it.
  14. leethal
    leethal 3 wheel Monarch #37
    Oct 14, 2008
    418
    Mornington peninsula, Melbourne
    .........and a lot more rim damage than when I do it !
    Drum Dog and Lost Cartographer like this.
  15. HerrDeacon
    HerrDeacon Been here awhile
    Oct 15, 2013
    198
    Have to ask, what's up with all the weights on the rim/spokes?
  16. Damian_74
    Damian_74 Been here awhile
    Feb 4, 2008
    772
    Brisbane, Australia
    More to the point - why have weights opposite each other!
  17. Lost Cartographer
    Feb 7, 2011
    752
    AZ and CA
    You should see the rest of the bike....
    gve.mcmlxxiv and DCTFAN like this.
  18. Lost Cartographer
    Feb 7, 2011
    752
    AZ and CA
    Believe it or not there is a method to the madness.
    I swap tires often. Really often:
    I have a "primary" set of tires, the Conti Attack Trails. If there are a lot of twisty roads and no sand then I'll be on those tires.
    I have the wheels perfectly balanced with that particular set of tires. Those weights never come off the wheel.
    Let's say I'm going somewhere with a bit more offroad so I'll spoon on some shinko 804/805s. I'll rebalance the assemblies ONLY ADDING WEIGHT, so sometimes I'll end up with new weights opposite of other exisiting weights.
    The new weights that I add get marked with an "805" on them, and the spot on the wheel gets marked too with how much weight I added.
    Offroad trip over, I'm going to be riding back and forth to work, so I'll spoon the Contis back on (carefully lining up the stem valve stem with the mark I put on the tire). Only takes 30-40 minutes or so to do the tire swap, and then I peel off the weights marked "805" and voila the wheel is ready to go, it doesn't need to be re-balanced.
    Sometimes I get punctures.... OK I get a lot of punctures:
    This one took 2 ropes to plug the hole, then another 2 ropes thru the inside loop to keep it from pushing out.
    It also shook so bad that I had to add ~40grams of weight to counter the vibe. And by weight I mean rocks.
    You can balance on the road by pushing the brake pads back and dropping the chain off the sprocket (rear) or popping the calipers off (front) and then duct taping flat stones to the rim as needed. It works in a pinch.
  19. IndiBiker
    IndiBiker Been here awhile Supporter
    Nov 15, 2012
    449
    Atlanta, GA
    Have ridden the bike for only 2000 miles but finally getting the chance to ride everyday - commuting.
    But I notice now that shifting up from 1 to 2 seems clunky. Same goes for 2 to 3. After that, it all seems ok. Am I not shifting at the right RPMs?
    I've owned CBRs and their gear shifting has always been butter smooth. This machine is clunky when shifting. Help!
  20. Lost Cartographer
    Feb 7, 2011
    752
    AZ and CA
    Mine was a bit clunky too (with the occasional false neutral between 4th and 5th) but it has improved significantly with mileage. It's no supersport bike, but I can't remember the last time I had a false neutral.
