The CRF1000L Africa Twin problem thread
Discussion in 'Japanese polycylindered adventure bikes' started by twinrider, Mar 18, 2016.
  1. Natyfour
    Natyfour n00b
    Jun 16, 2020
    2
    Temecula
    Hey guys,
    My Africa twin runs great, starts right up, dies after 5-10 minutes. Won't start again for about an hour... Any ideas where to start?
    I haven't touched anything repair wise so I'm not sure why this is randomly happening. Any help is appreciated.
  2. Motociclo
    Motociclo Long timer Supporter
    May 18, 2017
    1,129
    Check your breather hoses and fuel cap aren't blocked.
    Natyfour and OzCr0w like this.
  3. swimmer
    swimmer armchair asshole
    Oct 9, 2007
    17,126
    Tucson, AZ
    Has anyone experienced what appears to be fuel starvation issues following several thousand foot descents? Twice, after coming from an altitude of about 9000' down to about 2500' over the course of about 26 miles my bike started to stumble once down the hill. Even though I have only done this route twice, the stumbling lasted longer and was worse with a low tank of fuel vs. a 3/4 tank of fuel. In the worse situation the problem lasted for about 5 or 6 miles. Bike never stalled, just some surging. Temperature gain from top to botton was about 30 degrees (60's t0 90's) both times. '18 AT. Not a significant issue, just wondering if this is common.
  4. William Wolfen
    William Wolfen DR Guy
    Dec 5, 2015
    3,123
    Cypress, TX
    Maybe try popping the gas cap to see if there's pressure or a suction that might be causing a problem?
  5. swimmer
    Oct 9, 2007
    17,126
    Tucson, AZ
    Yeah, I felt it likely that venting the tank would resolve it but wanted to see if the situation would resolve itself which it did. Just curious if anyone else had experienced this. Although unlikely, it's possible I pinched a vent hose the last time I reinstalled the tank.
  6. windowto
    windowto Long timer
    Jun 18, 2012
    3,089
    NJ
    One way to confirm would be if, hopefully not, it happens again, instead of waiting an hour, open/close the tank cap and try again...
  7. Black99S
    Black99S Been here awhile
    Dec 30, 2012
    397
    Vancouver, Canada
    US bike. Do you have the EVAP system with canister under the seat? Possible this is the cause??
    Gas cap has a small screw & plate which retains a small spring and rubber plunger. Check if clean and freely moving.
  8. RustySpokes
    RustySpokes Ordinary average guy Supporter
    May 13, 2004
    1,908
    Between here and there.
    I want to know what road drops 6,500 ft in 26 miles!
    Cuchulainn and windowto like this.
  9. swimmer
    Oct 9, 2007
    17,126
    Tucson, AZ
    Elevation of Tucson is about 2500' and a mountain just outside of town is about 9000' at the top.
    Blaise W likes this.
  10. Natyfour
    Natyfour n00b
    Jun 16, 2020
    2
    Temecula
    Ok drained the tube front of battery box. Other 2 tubes were clear. Removed air filters, opened gas tank lid. Same issue. Any other tips? Thanks!
  11. Motociclo
    May 18, 2017
    1,129
    Long shot.
    Coil/s may be faulty.
    Have had vehicles in past with a coil that when hot, would stop, then once cooled would run again until hot. Like i said, very long shot.
    Give the starter button contacts a clean and start to check a few conections. Battery inclusive.
  12. playinatwork
    playinatwork Been here awhile
    Jul 30, 2010
    771
    Jacksonville FL
    @Natyfour IF you have an Adventure Sport model you likely have the fuel tank problem. It is fairly common.
    blrfjr, Winger57 and Cuchulainn like this.
  13. pepebayeta
    pepebayeta Been here awhile
    Dec 18, 2007
    630
    Spain
  14. pepebayeta
    Dec 18, 2007
    630
    Spain
    I have noticed really weird behaviour with the "engine brake" in signifficant and sudden height/temperature changes. After going up and down several mountain passes from 400m to 3500m and from 32ºC to 0ºC, the engine was pushing uphill with fully closed throttle. Something as when you hit a "resume cruise" button.
    (Edit) Sorry for the unit measures.
  15. moparren
    moparren Been here awhile
    Apr 6, 2009
    708
    Tucson AZ
    Yep, every summer (except this year) I go up the control road and come down Catalina Highway at least once.
    Never had the issue you're describing.
  16. swimmer
    Oct 9, 2007
    17,126
    Tucson, AZ
    I've had the tank lifted up a couple of times, maybe I have a partially pinched vent tube or something. Not going to bother with anything until I have another reason to lift the tank.
  17. ameen
    ameen Adventurer
    Sep 29, 2011
    75
    out of curiosity, when/how did you resolve it when you were riding?
    I had something very similar. It would lose power and even with the clutch pulled in not rev over 5k rpm. Oddly, I could turn it off and back on a few times (even while riding) and it would fix it, at least for a while.
    The issue for me only happened at elevation. Primarily when over 4500m or more for a longer period of time. Checked the fuel filter, pump, hoses and even vale clearances etc. with no issues. Runs fine once I could get down to realistic altitudes and haven't spent the time to dig deeper.
    My current hunch is it could be some sensors at one end or the other of their tolerance ranges. Getting to thinner air might be just enough to throw it off. Im back in the States now and it will be hard to test rides over with 5000m or so of elevation so I kinda am just letting it go for now.
  18. swimmer
    Oct 9, 2007
    17,126
    Tucson, AZ
    It just resolved itself after a few minutes of riding.
  19. Anjin455
    Anjin455 Riding on the company dime
    Oct 18, 2015
    105
    Freedom Land
    Is anyone else seeing a lot of wear on the drive shaft splines for their 2016 standard? I am running a 14 tooth front sprocket, lots of highway miles with a good amount of gravel and forest roads in between. The wear on the splines is causing quite a bit of slop in the drive gear as it mates to the output spline shaft. It's going to have to be replaced. I am sitting right around 50k miles on the bike...FML
  20. Black99S
    Dec 30, 2012
    397
    Vancouver, Canada
    Noticed some red rust dust on my 2017 under the bolt / washer that retains the sprocket at ~23,000km. Replaced sprockets with Honda OEM.
    Applied plenty of Moly Paste (Honda expensive stuff) to the splines with the new sprocket.
    I think if you keep the splines lubed with Moly Paste and use good quality sprockets wear should be minimized.
    That sounds like an expensive repair - engine out and split the cases?
