The CRF1000L Africa Twin problem thread
Discussion in 'Japanese polycylindered adventure bikes' started by twinrider, Mar 18, 2016.
  1. Black99S
    Black99S Been here awhile
    Dec 30, 2012
    500
    Vancouver, Canada
  2. xtbiker
    xtbiker Adventurer
    Dec 7, 2014
    49
    Hello,
    Oil topic :-). Manual says 10w30.
    10w40 is still suitable for long term use?
    I usually change oil and filter 6-8000 km.
  3. Amphib
    Amphib A mind is like a parachute....
    Sep 19, 2018
    3,925
    Wnc
    Personal preference. Lots of guys are running 10w40. My preference is to stick with the recommended 10w30. I'm running the hp4s 10w30.
    xtbiker and windowto like this.
  4. NorskieRider
    NorskieRider Ultracrepidarian
    Mar 19, 2011
    1,666
    Minnesota
    I think the viscosity is more important when running a DCT than a manual, and as I have a DCT I'm running 10w30 - Rotella T5 works for me.
    xtbiker, randallz2002 and windowto like this.
  5. William Wolfen
    William Wolfen Long timer
    Dec 5, 2015
    3,702
    Cypress, TX
    I was running 5W40 synthetic in my '17 and am going to be doing the first change on my '19 using the same stuff by the end of the weekend. I'm not dead set in it, but with a W40 oil I don't have to worry about it being resource conserving for the clutch. The one I use also happens to be labeled as JASO MA. I guess not than anything it's just what I was running in my DR650 as well, so a bit of just habit too. Feel free to convince me to use some other inexpensive oil.
    xtbiker likes this.
  6. enzo972
    enzo972 Adventurer
    Jan 6, 2021
    20
    Martinique
    Hello,
    I have an africa twin 2016 and in the morning cold, it starts and the idle makes stall or stall. Sometimes it also stalls when I brake or accelerate suddenly. The fuel consumption has increased a lot and I have the impression that there is a loss of power. I have already changed the IACV but it hasn't changed anything. Do you have an idea please? Thanks for your help.
  7. bbanker
    bbanker Been here awhile Supporter
    Feb 24, 2011
    567
    Beautiful NC
    Your valves may need to be adjusted.
  8. enzo972
    enzo972 Adventurer
    Jan 6, 2021
    20
    Martinique
    the valves were checked at 44,000 km and now the bike is at 51,000 km, how is that possible ?
  9. bbanker
    Feb 24, 2011
    567
    Beautiful NC
    I had a similar problem, and it ended up being the IACV, and a cracked spark plug. The valves were just an idea. Does it do it all of the time, or just when cold?
  10. enzo972
    enzo972 Adventurer
    Jan 6, 2021
    20
    Martinique
    So the callage after starting is done cold only, once hot, it does not stall and the idle is stable. On the other hand, I have a loss of power at high revs as if the bike is hesitant to accelerate, or as if it is going back and forth. And I lost nearly 50 km on the usual range
    it may happen that it stalls hot when braking or starting at a green light.
    Sorry for my englisn, i'm french. Thx for your help
  11. bbanker
    Feb 24, 2011
    567
    Beautiful NC
    No worries. I would also check the tank vents, and the spark plugs. Has it only done this since the valve check? Maybe they did it wrong or pinched the tank vent hose putting the tank back on?
  12. enzo972
    enzo972 Adventurer
    Jan 6, 2021
    20
    Martinique
    I changed the spark plugs and also checked that all the pipes were properly in place myself. On the other hand, I don't know how to check if the spark plug wires or the anti parasite are good. I said to myself, maybe the fuel pump or the ignition switch, since the idle fluctuates when cold and goes out, I have to accelerate. I had this problem after washing the engine. motorbike.
  13. leethal
    leethal 3 wheel Monarch #37
    Oct 14, 2008
    518
    Mornington peninsula, Melbourne
    Air filters and air box drains.
  14. enzo972
    enzo972 Adventurer
    Jan 6, 2021
    20
    Martinique
    I have already checked the drains and the filters are nickel
  15. Olde Phart
    Olde Phart Olde Phart
    Mar 3, 2018
    693
    Land of Oro y Plata
    Surging and loss of power under high load demand hints at fuel starvation. I'd pull the tank and inspect the condition of the fuel pump pickup filter for debris and clogging.
    Good DIY to ya!
  16. windowto
    windowto Long timer
    Jun 18, 2012
    3,157
    NJ
    ...or, air leak...:)
  17. Appalachian Twin
    Appalachian Twin Adventurer
    Apr 2, 2017
    48
    Flat Rock NC, USA
    2016? Ignition switch until proven otherwise.
    But broken plugs are not unheard of. Plugs are EXPENSIVE !!!!!
    windowto likes this.
  18. bbanker
    Feb 24, 2011
    567
    Beautiful NC
    I had one.
  19. NorskieRider
    Mar 19, 2011
    1,666
    Minnesota
    I'm starting to hear about fake spark plugs on Ebay and Amazon. The symptom is that they break apart after not many miles. To be safe I've resorted to buying spark plugs only from well known sources, despite the cost.
  20. bbanker
    Feb 24, 2011
    567
    Beautiful NC
    It was the original from factory. They thought it was probably just a defective plug.
